wAP ac LTE6 - LTE connectivity issues
Hello
We have installed wAP ac LTE6 outside on the roof. It experiences LTE connectivity issues, like every few hours lte1 connection is gone for some reason and lte1 interface has to be restarted (it has netwatch script to restart lte1 interface when it’s down + watchdog timer with ping).
LTE firmware is R11e-LTE6_V036 (currently latest).
RouterOS version is 6.49.11 (stable).
> system routerboard print
       routerboard: yes
        board-name: wAP R ac
             model: RBwAPGR-5HacD2HnD
          revision: r3
     serial-number: HDG08RCSSCW
     firmware-type: ipq4000L
  factory-firmware: 6.49.7
  current-firmware: 6.49.11
  upgrade-firmware: 6.49.12
> interface lte info
number: 0
           pin-status: ok
           pin-status: ok
  registration-status: roaming
        functionality: full
         manufacturer: "MikroTik"
                model: "R11e-LTE6"
             revision: R11e-LTE6_V036
     current-operator: Telia
              roaming: yes
                  lac: 10005
       current-cellid: 53819167
               enb-id: 210231
            sector-id: 31
           phy-cellid: 332
    access-technology: LTE (CA2)
       session-uptime: 13m21s
                 imei: ***removed****
                 imsi: ***removed****
                 uicc: 8935801230087243468
         primary-band: B3@20Mhz earfcn: 1344 phy-cellid: 332
              ca-band: B7@20Mhz earfcn: 3050 phy-cellid: 130
                 rssi: -57dBm
                 rsrp: -90dBm
                 rsrq: -10dB
Feb/09/2024 18:41:15 bridge,info hardware offloading activated on bridge "bridge" ports: ether1,ether2
Feb/09/2024 18:41:17 interface,info ether1 link up (speed 100M, full duplex)
Feb/09/2024 18:41:23 lte,async lte1: sent ATE0
Feb/09/2024 18:41:23 lte,async lte1: rcvd OK
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CGMI
Feb/09/2024 18:41:23 lte,async lte1: rcvd +CGMI: "MikroTik"
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CGMM
Feb/09/2024 18:41:23 lte,async lte1: rcvd +CGMM: "R11e-LTE6"
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CGMR
Feb/09/2024 18:41:23 lte,async lte1: rcvd R11e-LTE6_V036
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CGSN
Feb/09/2024 18:41:23 lte,async lte1: rcvd 356662102211544
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CFUN?
Feb/09/2024 18:41:23 lte,async lte1: rcvd +CFUN: 4
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CMEE=2
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CREG=2
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CGREG=2
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CEREG=2
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CGEREP=2,0
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CMGF=0
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CNMI=1,1,0,1,0
Feb/09/2024 18:41:23 lte,async lte1: sent AT+EEMOPT=1
Feb/09/2024 18:41:23 lte,async lte1: sent AT*MRD_SN?
Feb/09/2024 18:41:23 lte,async lte1: rcvd *MRD_SN:HDB01K88A5A
Feb/09/2024 18:41:23 lte,async lte1: sent AT+CPIN?
Feb/09/2024 18:41:23 lte,async lte1: rcvd +CPIN: READY
Feb/09/2024 18:41:27 lte,async lte1: sent AT+CPMS="SM","SM","SM"
Feb/09/2024 18:41:27 lte,async,event lte1: +MMSG: 1, 1
Feb/09/2024 18:41:27 lte,async lte1: rcvd +CPMS: 20,20,20,20,20,20
Feb/09/2024 18:41:27 lte,async lte1: sent AT+CFUN?
Feb/09/2024 18:41:27 lte,async lte1: rcvd +CFUN: 4
Feb/09/2024 18:41:27 lte,async lte1: sent AT*ICCID?
Feb/09/2024 18:41:27 lte,async lte1: rcvd *ICCID: 8935801230087243468
Feb/09/2024 18:41:27 lte,async lte1: sent AT+CNUM
Feb/09/2024 18:41:27 lte,async lte1: sent AT+CIMI
Feb/09/2024 18:41:27 lte,async lte1: rcvd 244915452884840
Feb/09/2024 18:41:27 lte,async lte1: sent AT+CPIN?
Feb/09/2024 18:41:27 lte,async lte1: rcvd +CPIN: READY
Feb/09/2024 18:41:27 lte,async lte1: sent AT*BAND?
Feb/09/2024 18:41:27 lte,async lte1: rcvd *BAND: 15, 78, 147, 480, 50923735, 0, 2, 2, 0
Feb/09/2024 18:41:27 lte,async lte1: sent AT*BAND=15,78,147,480,50923735,1,2,0
Feb/09/2024 18:41:28 lte,async lte1: rcvd OK
Feb/09/2024 18:41:28 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
Feb/09/2024 18:41:29 lte,async lte1: sent AT+ZGDCONT=5,"IP","opengate",0
Feb/09/2024 18:41:29 lte,async lte1: rcvd OK
Feb/09/2024 18:41:29 lte,async lte1: sent AT+ZGPCOAUTH=5,"","",0
Feb/09/2024 18:41:29 lte,async lte1: sent AT+COPS=0
Feb/09/2024 18:41:29 lte,async lte1: sent AT+COPS=3,0
Feb/09/2024 18:41:29 lte,async lte1: sent AT+CFUN=1
Feb/09/2024 18:41:29 lte,async,event lte1: +CPAS: 2
Feb/09/2024 18:41:29 lte,debug lte1: config ok
Feb/09/2024 18:41:29 lte,async,event lte1: *RADIOPOWER: 1
Feb/09/2024 18:41:31 lte,info lte1: registered roaming
Feb/09/2024 18:41:31 lte,async,event lte1: +CPAS: 0
Feb/09/2024 18:41:31 lte,async,event lte1: +CEN1: 1, 248, 01
Feb/09/2024 18:41:31 lte,async,event lte1: +CGEV: EPS PDN ACT 5
Feb/09/2024 18:41:32 lte,async,event lte1: *COPN:0,Telia EE
Feb/09/2024 18:41:32 lte,async,event lte1: *COPN:1,Telia EE
Feb/09/2024 18:41:32 lte,async,event lte1: +ZNITZ: 2024,02,09,18,46,38,32,0
Feb/09/2024 18:41:32 lte,async,event lte1: +NITZ: 0,+8,24/02/09,16:46:38
Feb/09/2024 18:41:35 lte,async lte1: sent AT+ZGACT=1,5
Feb/09/2024 18:41:36 lte,async lte1: rcvd OK
Feb/09/2024 18:41:38 lte,async,event lte1: +ZCONSTAT: 1,5
Feb/09/2024 18:41:38 lte,async,event lte1: +ZGIPDNS: 5,"IP","193.210.228.44","193.210.228.44","192.89.123.230","192.89.123.231","","","",""
Feb/09/2024 18:41:38 interface,info lte1 link up
Feb/09/2024 18:42:00 script,info NETWATCH/LTE/OK
Feb/09/2024 18:47:14 system,info sntp change time Feb/09/2024 18:42:09 => Feb/09/2024 18:47:14
Feb/09/2024 18:48:06 script,info NETWATCH/LTE/UP/sendLteIpAddress
Feb/09/2024 18:48:07 e-mail,info sent <MikroTik wAP LTE side aktiivne> to:
Feb/09/2024 19:29:57 lte,async,event lte1: ^MODE:3
Feb/09/2024 19:29:57 lte,async,event lte1: +MSRI: 1
Feb/09/2024 19:29:57 lte,async,event lte1: +MPBK: 0
Feb/09/2024 19:29:57 lte,async,event lte1: +MMSG: 0, 0
Feb/09/2024 19:29:57 lte,info lte1: not registred, state: 0
Feb/09/2024 19:29:57 lte,async,event lte1: +CPAS: 5
Feb/09/2024 19:29:58 lte,async,event lte1: *SIMDETEC:2,NOS
Feb/09/2024 19:29:58 lte,async,event lte1: *SIMDETEC:1,SIM
Feb/09/2024 19:29:59 lte,async,event lte1: *ICCID: 8935801230087243468
Feb/09/2024 19:29:59 lte,async,event lte1: *EUICC: 1
Feb/09/2024 19:29:59 lte,async,event lte1: *RADIOPOWER: 0
Feb/09/2024 19:29:59 lte,async,event lte1: *ADMINDATA: 1, 2, 1
Feb/09/2024 19:29:59 lte,async,event lte1: +CPIN: READY
Feb/09/2024 19:29:59 lte,async,event lte1: *ECCLIST: 5, 31, 000, 31, 08, 31, 112, 31, 110, 31, 911
Feb/09/2024 19:30:00 script,info NETWATCH/LTE/DOWN
Feb/09/2024 19:30:00 lte,account lte1 session: 2596s 14854952/435453632 bytes 211543/636043 packets
Feb/09/2024 19:30:00 interface,info lte1 link down
Feb/09/2024 19:30:00 system,info device changed
Feb/09/2024 19:30:01 lte,async lte1: sent ATE0
Feb/09/2024 19:30:01 lte,async lte1: rcvd OK
Feb/09/2024 19:30:01 lte,async lte1: sent AT+CFUN=0
Feb/09/2024 19:30:01 lte,async lte1: rcvd ERROR
Feb/09/2024 19:30:05 script,info NETWATCH/LTE/RESTARTED
Feb/09/2024 19:30:05 system,info device changed
Feb/09/2024 19:30:06 lte,async lte1: sent ATE0
Feb/09/2024 19:30:06 lte,async lte1: rcvd OK
Feb/09/2024 19:30:06 lte,async lte1: sent AT+CFUN?
Feb/09/2024 19:30:06 lte,async lte1: rcvd ERROR
Feb/09/2024 19:30:06 lte,async lte1: sent AT+CFUN=4
Feb/09/2024 19:30:06 lte,async lte1: modem hung up
Feb/09/2024 19:30:40 watchdog,error,critical watchdog cannot ping address 1.1.1.1, rebooting
Feb/09/2024 19:30:42 system,error,critical System rebooted because of ping watchdog timeout
Feb/09/2024 19:30:42 system,info router rebooted
Feb/09/2024 19:30:44 script,info NETWATCH/LTE/DOWN
Feb/09/2024 19:30:52 bridge,info hardware offloading activated on bridge "bridge" ports: ether1,ether2
Feb/09/2024 19:30:54 interface,info ether1 link up (speed 100M, full duplex)
Feb/09/2024 19:31:00 lte,async lte1: sent ATE0
Feb/09/2024 19:31:00 lte,async lte1: rcvd OK
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CGMI
Feb/09/2024 19:31:00 lte,async lte1: rcvd +CGMI: "MikroTik"
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CGMM
Feb/09/2024 19:31:00 lte,async lte1: rcvd +CGMM: "R11e-LTE6"
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CGMR
Feb/09/2024 19:31:00 lte,async lte1: rcvd R11e-LTE6_V036
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CGSN
Feb/09/2024 19:31:00 lte,async lte1: rcvd 356662102211544
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CFUN?
Feb/09/2024 19:31:00 lte,async lte1: rcvd +CFUN: 4
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CMEE=2
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CREG=2
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CGREG=2
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CEREG=2
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CGEREP=2,0
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CMGF=0
Feb/09/2024 19:31:00 lte,async lte1: sent AT+CNMI=1,1,0,1,0
Feb/09/2024 19:31:01 lte,async lte1: rcvd OK
Feb/09/2024 19:31:01 lte,async lte1: sent AT+EEMOPT=1
Feb/09/2024 19:31:01 lte,async lte1: sent AT*MRD_SN?
Feb/09/2024 19:31:01 lte,async lte1: rcvd *MRD_SN:HDB01K88A5A
Feb/09/2024 19:31:01 lte,async lte1: sent AT+CPIN?
Feb/09/2024 19:31:01 lte,async lte1: rcvd +CPIN: READY
Feb/09/2024 19:31:05 lte,async lte1: sent AT+CPMS="SM","SM","SM"
Feb/09/2024 19:31:05 lte,async lte1: rcvd +CPMS: 20,20,20,20,20,20
Feb/09/2024 19:31:05 lte,async lte1: sent AT+CFUN?
Feb/09/2024 19:31:05 lte,async,event lte1: +MMSG: 1, 1
Feb/09/2024 19:31:05 lte,async lte1: rcvd +CFUN: 4
Feb/09/2024 19:31:05 lte,async lte1: sent AT*ICCID?
Feb/09/2024 19:31:05 lte,async lte1: rcvd *ICCID: 8935801230087243468
Feb/09/2024 19:31:05 lte,async lte1: sent AT+CNUM
Feb/09/2024 19:31:05 lte,async lte1: sent AT+CIMI
Feb/09/2024 19:31:05 lte,async lte1: rcvd 244915452884840
Feb/09/2024 19:31:05 lte,async lte1: sent AT+CPIN?
Feb/09/2024 19:31:05 lte,async lte1: rcvd +CPIN: READY
Feb/09/2024 19:31:05 lte,async lte1: sent AT*BAND?
Feb/09/2024 19:31:05 lte,async lte1: rcvd *BAND: 15, 78, 147, 480, 50923735, 0, 2, 2, 0
Feb/09/2024 19:31:05 lte,async lte1: sent AT*BAND=15,78,147,480,50923735,1,2,0
Feb/09/2024 19:31:05 lte,async lte1: rcvd OK
Feb/09/2024 19:31:05 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
Feb/09/2024 19:31:06 lte,async lte1: sent AT+ZGDCONT=5,"IP","opengate",0
Feb/09/2024 19:31:06 lte,async lte1: rcvd OK
Feb/09/2024 19:31:06 lte,async lte1: sent AT+ZGPCOAUTH=5,"","",0
Feb/09/2024 19:31:06 lte,async lte1: sent AT+COPS=0
Feb/09/2024 19:31:06 lte,async lte1: sent AT+COPS=3,0
Feb/09/2024 19:31:06 lte,async lte1: sent AT+CFUN=1
Feb/09/2024 19:31:06 lte,async,event lte1: +CPAS: 2
Feb/09/2024 19:31:06 lte,debug lte1: config ok
Feb/09/2024 19:31:06 lte,async,event lte1: *RADIOPOWER: 1
Feb/09/2024 19:31:07 lte,info lte1: registered roaming
Feb/09/2024 19:31:07 lte,async,event lte1: +CPAS: 0
Feb/09/2024 19:31:07 lte,async,event lte1: +CEN1: 1, 248, 01
Feb/09/2024 19:31:07 lte,async,event lte1: +CGEV: EPS PDN ACT 5
Feb/09/2024 19:31:07 lte,async,event lte1: *COPN:0,Telia EE
Feb/09/2024 19:31:07 lte,async,event lte1: *COPN:1,Telia EE
Feb/09/2024 19:31:07 lte,async,event lte1: +ZNITZ: 2024,02,09,19,31,44,32,0
Feb/09/2024 19:31:07 lte,async,event lte1: +NITZ: 0,+8,24/02/09,17:31:44
Feb/09/2024 19:31:12 lte,async lte1: sent AT+ZGACT=1,5
Feb/09/2024 19:31:12 lte,async lte1: rcvd OK
Feb/09/2024 19:31:15 lte,async,event lte1: +ZCONSTAT: 1,5
Feb/09/2024 19:31:15 lte,async,event lte1: +ZGIPDNS: 5,"IP","193.210.231.137","193.210.231.137","192.89.123.230","192.89.123.231","","","",""
Feb/09/2024 19:31:15 interface,info lte1 link up
Feb/09/2024 19:32:23 system,info sntp change time Feb/09/2024 19:31:46 => Feb/09/2024 19:32:23
Feb/09/2024 19:33:00 script,info NETWATCH/LTE/OK
Feb/09/2024 19:34:00 script,info NETWATCH/LTE/UP/sendLteIpAddress
Feb/09/2024 19:34:01 e-mail,info sent <MikroTik wAP LTE side aktiivne> to:
Feb/09/2024 21:41:15 lte,async,raw lte1: +CREG: 0
Feb/09/2024 21:41:15 lte,async,raw lte1: $CREG: 0
Feb/09/2024 21:41:15 lte,async,event lte1: ^MODE:3
Feb/09/2024 21:41:15 lte,async,event lte1: +MSRI: 1
Feb/09/2024 21:41:15 lte,async,event lte1: +MPBK: 0
Feb/09/2024 21:41:15 lte,async,event lte1: +MMSG: 0, 0
Feb/09/2024 21:41:15 lte,async,raw lte1: +CGREG: 0
Feb/09/2024 21:41:15 lte,async,raw lte1: +CEREG: 0
Feb/09/2024 21:41:15 lte,info lte1: not registred, state: 0
Feb/09/2024 21:41:15 lte,async,event lte1: +CPAS: 5
Feb/09/2024 21:41:15 lte,async,event lte1: *SIMDETEC:2,NOS
Feb/09/2024 21:41:16 lte,async,raw lte1: sent AT+CFUN?
Feb/09/2024 21:41:16 lte,async,raw lte1: rcvd +CFUN: 4
Feb/09/2024 21:41:16 lte,async,raw lte1: sent AT+CSQ
Feb/09/2024 21:41:16 lte,async,raw lte1: rcvd +CSQ: 2097152,0
Feb/09/2024 21:41:16 lte,async,event lte1: *SIMDETEC:1,SIM
Feb/09/2024 21:41:16 lte,async,event lte1: *ICCID: 8935801230087243468
Feb/09/2024 21:41:16 lte,async,event lte1: *EUICC: 1
Feb/09/2024 21:41:16 lte,async,raw lte1: +CREG: 0
Feb/09/2024 21:41:16 lte,async,raw lte1: $CREG: 0
Feb/09/2024 21:41:17 lte,async,raw lte1: +CGREG: 0
Feb/09/2024 21:41:17 lte,async,raw lte1: +CEREG: 0
Feb/09/2024 21:41:17 lte,async,event lte1: *RADIOPOWER: 0
Feb/09/2024 21:41:17 lte,async,event lte1: *ADMINDATA: 1, 2, 1
Feb/09/2024 21:41:17 lte,async,event lte1: +CPIN: READY
Feb/09/2024 21:41:17 lte,async,event lte1: *EUICC: 1
Feb/09/2024 21:41:17 lte,async,event lte1: *ECCLIST: 5, 31, 000, 31, 08, 31, 112, 31, 110, 31, 911
Feb/09/2024 21:41:17 lte,async,event lte1: +MMSG: 0, 0
Feb/09/2024 21:41:24 lte,account lte1 session: 7773s 53311013/1439091796 bytes 755732/2159781 packets
Feb/09/2024 21:41:24 lte,async lte1: modem hung up
Feb/09/2024 21:41:24 interface,info lte1 link down
Feb/09/2024 21:42:00 script,info NETWATCH/LTE/DOWN
Feb/09/2024 21:42:00 system,info device changed
Feb/09/2024 21:42:04 lte,async lte1: sent ATE0
Feb/09/2024 21:42:04 lte,async lte1: rcvd OK
Feb/09/2024 21:42:04 lte,async lte1: sent AT+CGMI
Feb/09/2024 21:42:04 lte,async lte1: rcvd +CGMI: "MikroTik"
Feb/09/2024 21:42:04 lte,async lte1: sent AT+CGMM
Feb/09/2024 21:42:04 lte,async lte1: rcvd +CGMM: "R11e-LTE6"
Feb/09/2024 21:42:04 lte,async lte1: sent AT+CGMR
Feb/09/2024 21:42:04 lte,async lte1: rcvd R11e-LTE6_V036
Feb/09/2024 21:42:04 lte,async lte1: sent AT+CGSN
Feb/09/2024 21:42:04 lte,async lte1: rcvd 356662102211544
Feb/09/2024 21:42:04 lte,async lte1: sent AT+CFUN=0
Feb/09/2024 21:42:04 lte,async,event lte1: *EUICC: 4
Feb/09/2024 21:42:04 lte,async,event lte1: +MMSG: 0, 0
Feb/09/2024 21:42:04 lte,async,event lte1: *RADIOPOWER: 0
Feb/09/2024 21:42:05 system,info device changed
Feb/09/2024 21:42:05 script,info NETWATCH/LTE/RESTARTED
Feb/09/2024 21:42:06 lte,async lte1: sent ATE0
Feb/09/2024 21:42:06 lte,async lte1: rcvd OK
Feb/09/2024 21:42:06 lte,async lte1: sent AT+CFUN?
Feb/09/2024 21:42:06 lte,async lte1: rcvd +CFUN: 0
Feb/09/2024 21:42:06 lte,async lte1: sent AT+CFUN=4
Feb/09/2024 21:42:08 lte,async,event lte1: *SIMDETEC:1,SIM
Feb/09/2024 21:42:08 lte,async lte1: rcvd OK
Feb/09/2024 21:42:08 lte,async,event lte1: *RADIOPOWER: 0
Feb/09/2024 21:42:08 lte,async,event lte1: *ICCID: 8935801230087243468
Feb/09/2024 21:42:08 lte,async,event lte1: *EUICC: 1
Feb/09/2024 21:42:09 lte,async,event lte1: *ADMINDATA: 1, 2, 1
Feb/09/2024 21:42:09 lte,async,event lte1: +CPIN: READY
Feb/09/2024 21:42:09 lte,async,event lte1: *EUICC: 1
Feb/09/2024 21:42:09 lte,async,event lte1: *ECCLIST: 5, 31, 000, 31, 08, 31, 112, 31, 110, 31, 911
Feb/09/2024 21:42:09 lte,async lte1: sent AT+CFUN?
Feb/09/2024 21:42:09 lte,async lte1: rcvd +CFUN: 4
Feb/09/2024 21:42:09 lte,async lte1: sent AT+CMEE=2
Feb/09/2024 21:42:09 lte,async,event lte1: +MMSG: 0, 0
Feb/09/2024 21:42:09 lte,async lte1: rcvd OK
Feb/09/2024 21:42:09 lte,async lte1: sent AT+CREG=2
Feb/09/2024 21:42:09 lte,async lte1: sent AT+CGREG=2
Feb/09/2024 21:42:09 lte,async lte1: sent AT+CEREG=2
Feb/09/2024 21:42:09 lte,async lte1: sent AT+CGEREP=2,0
Feb/09/2024 21:42:09 lte,async lte1: sent AT+CMGF=0
Feb/09/2024 21:42:09 lte,async lte1: sent AT+CNMI=1,1,0,1,0
Feb/09/2024 21:42:09 lte,async lte1: sent AT+EEMOPT=1
Feb/09/2024 21:42:09 lte,async lte1: sent AT*MRD_SN?
Feb/09/2024 21:42:09 lte,async,event lte1: +MMSG: 0, 1
Feb/09/2024 21:42:09 lte,async,event lte1: +MPBK: 1
Feb/09/2024 21:42:09 lte,async lte1: rcvd *MRD_SN:HDB01K88A5A
Feb/09/2024 21:42:09 lte,async lte1: sent AT+CPIN?
Feb/09/2024 21:42:09 lte,async lte1: rcvd +CPIN: READY
Feb/09/2024 21:42:09 lte,async,event lte1: +MMSG: 1, 1
Feb/09/2024 21:42:13 lte,async lte1: sent AT+CPMS="SM","SM","SM"
Feb/09/2024 21:42:13 lte,async,event lte1: +MMSG: 1, 1
Feb/09/2024 21:42:13 lte,async lte1: rcvd +CPMS: 20,20,20,20,20,20
Feb/09/2024 21:42:13 lte,async lte1: sent AT+CFUN?
Feb/09/2024 21:42:13 lte,async lte1: rcvd +CFUN: 4
Feb/09/2024 21:42:13 lte,async lte1: sent AT*ICCID?
Feb/09/2024 21:42:13 lte,async lte1: rcvd *ICCID: 8935801230087243468
Feb/09/2024 21:42:13 lte,async lte1: sent AT+CNUM
Feb/09/2024 21:42:13 lte,async lte1: sent AT+CIMI
Feb/09/2024 21:42:13 lte,async lte1: rcvd 244915452884840
Feb/09/2024 21:42:13 lte,async lte1: sent AT+CPIN?
Feb/09/2024 21:42:13 lte,async lte1: rcvd +CPIN: READY
Feb/09/2024 21:42:13 lte,async lte1: sent AT*BAND?
Feb/09/2024 21:42:13 lte,async lte1: rcvd *BAND: 15, 78, 147, 480, 50923735, 0, 2, 2, 0
Feb/09/2024 21:42:13 lte,async lte1: sent AT*BAND=15,78,147,480,50923735,1,2,0
Feb/09/2024 21:42:14 lte,async lte1: rcvd OK
Feb/09/2024 21:42:14 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
Feb/09/2024 21:42:15 lte,async lte1: sent AT+ZGDCONT=5,"IP","opengate",0
Feb/09/2024 21:42:15 lte,async lte1: rcvd OK
Feb/09/2024 21:42:15 lte,async lte1: sent AT+ZGPCOAUTH=5,"","",0
Feb/09/2024 21:42:15 lte,async lte1: sent AT+COPS=0
Feb/09/2024 21:42:15 lte,async lte1: sent AT+COPS=3,0
Feb/09/2024 21:42:15 lte,async lte1: sent AT+CFUN=1
Feb/09/2024 21:42:15 lte,async,event lte1: +CPAS: 2
Feb/09/2024 21:42:15 lte,debug lte1: config ok
Feb/09/2024 21:42:15 lte,async,raw lte1: sent AT+CFUN?
Feb/09/2024 21:42:15 lte,async,event lte1: *RADIOPOWER: 1
Feb/09/2024 21:42:15 lte,async,raw lte1: rcvd +CFUN: 1
Feb/09/2024 21:42:15 lte,async,raw lte1: sent AT+CSQ
Feb/09/2024 21:42:15 lte,async,raw lte1: rcvd +CSQ: 2097152,0
Feb/09/2024 21:42:16 lte,async,raw lte1: +CGREG: 0
Feb/09/2024 21:42:16 lte,async,raw lte1: +CEREG: 5,"2715","0335371f",9
Feb/09/2024 21:42:16 lte,info lte1: registered roaming
Feb/09/2024 21:42:16 lte,async,event lte1: +CPAS: 0
Feb/09/2024 21:42:16 lte,async,raw lte1: +CREG: 5,"2715","0335371f",9
Feb/09/2024 21:42:16 lte,async,raw lte1: $CREG: 5,"2715","0335371f",9,"14c"
Feb/09/2024 21:42:16 lte,async,event lte1: +CEN1: 1, 248, 01
Feb/09/2024 21:42:16 lte,async,event lte1: +CGEV: EPS PDN ACT 5
Feb/09/2024 21:42:16 lte,async,event lte1: *COPN:0,Telia EE
Feb/09/2024 21:42:16 lte,async,event lte1: *COPN:1,Telia EE
Feb/09/2024 21:42:16 lte,async,event lte1: +ZNITZ: 2024,02,09,21,42,16,32,0
Feb/09/2024 21:42:16 lte,async,event lte1: +NITZ: 0,+8,24/02/09,19:42:16
Feb/09/2024 21:42:18 lte,async,raw lte1: sent AT+CFUN?
Feb/09/2024 21:42:18 lte,async,raw lte1: rcvd +CFUN: 1
Feb/09/2024 21:42:18 lte,async,raw lte1: sent AT+COPS?
Feb/09/2024 21:42:18 lte,async,raw lte1: rcvd +COPS: 0,0,"Telia",9
Feb/09/2024 21:42:18 lte,async,raw lte1: sent AT+CESQ
Feb/09/2024 21:42:18 lte,async,raw lte1: rcvd +CESQ: 63,99,255,255,20,61
Feb/09/2024 21:42:21 lte,async lte1: sent AT+ZGACT=1,5
Feb/09/2024 21:42:21 lte,async lte1: rcvd OK
Feb/09/2024 21:42:22 lte,async,raw lte1: +CREG: 5,"2715","0335371f",7
Feb/09/2024 21:42:22 lte,async,raw lte1: $CREG: 5,"2715","0335371f",7,"14c"
Feb/09/2024 21:42:22 lte,async,raw lte1: +CEREG: 5,"2715","0335371f",7
Feb/09/2024 21:42:24 lte,async,event lte1: +ZCONSTAT: 1,5
Feb/09/2024 21:42:24 lte,async,event lte1: +ZGIPDNS: 5,"IP","193.210.230.90","193.210.230.90","192.89.123.230","192.89.123.231","","","",""
Feb/09/2024 21:42:24 interface,info lte1 link up
Feb/09/2024 21:42:24 lte,async,raw lte1: sent AT+CFUN?
Feb/09/2024 21:42:24 lte,async,raw lte1: rcvd +CFUN: 1
Feb/09/2024 21:42:24 lte,async,raw lte1: sent AT+COPS?
Feb/09/2024 21:42:24 lte,async,raw lte1: rcvd +COPS: 0,0,"Telia",7
Feb/09/2024 21:42:24 lte,async,raw lte1: sent AT+CESQ
Feb/09/2024 21:42:24 lte,async,raw lte1: rcvd +CESQ: 59,99,255,255,22,59
Feb/09/2024 21:42:27 lte,async,raw lte1: +CREG: 5,"2715","0335371f",9
Feb/09/2024 21:42:27 lte,async,raw lte1: $CREG: 5,"2715","0335371f",9,"14c"
Feb/09/2024 21:42:27 lte,async,raw lte1: +CEREG: 5,"2715","0335371f",9
Feb/09/2024 21:42:27 lte,async,raw lte1: sent AT+CFUN?
Feb/09/2024 21:42:27 lte,async,raw lte1: rcvd +CFUN: 1
Feb/09/2024 21:42:27 lte,async,raw lte1: sent AT+COPS?
Feb/09/2024 21:42:27 lte,async,raw lte1: rcvd +COPS: 0,0,"Telia",9
Feb/09/2024 21:42:27 lte,async,raw lte1: sent AT+CESQ
Feb/09/2024 21:42:27 lte,async,raw lte1: rcvd +CESQ: 53,99,255,255,18,50
Feb/09/2024 21:43:00 script,info NETWATCH/LTE/OK
Feb/09/2024 21:43:05 script,info NETWATCH/LTE/DOWN/sendLteIpAddress
Feb/09/2024 21:43:07 e-mail,info sent <MikroTik wAP LTE side aktiivne> to:
Feb/09/2024 21:44:00 script,info NETWATCH/LTE/UP/sendLteIpAddress
Feb/09/2024 21:44:01 e-mail,info sent <MikroTik wAP LTE side aktiivne> to:
Decided to upgrade from 6.49.11 to 7.14 with netinstall (without keeping old configuration). I did not add netwatch script (for restarting LTE interface).
For now it seems that it solved this issue, uptime 18 days and still going on, no issues so far.
