Hello!
WAP AC is now with “NEW” mark. (https://mikrotik.com/products?filter&s=n#!)
Is there something changed or this is error on site?
Hello!
and have you opened a new thread to make you say “READ before opening useless topics”?
what is written if you click on the link?
The new revision features 2x Gigabit Ethernet ports, enhanced wireless antenna performance, more RAM, and a powerful quad-core CPU!
MT did not change the “wAP ac” name. So be careful when you order the device: check the product code: RBwAPG-5HacD2HnD (ARM processor version) to be certain it is the new one..
The old product code is RBwAPG-5HacT2HnD, T not D, because of the triple 5 GHz chain in the old mipsbe.revision.
Thanks, I do not notice that,
I search only the /r3 at the end of serial number
