wAP AC Microtik - unable to config correct
Hello, I’m new to RouterOS and I’m trying to config a Dual AP but seem to hit some issues.
My config is Provider Router Modem with DHCP , with wifi enabled —> UTP in ETH1 Microtik wAP
What I need is dual Home AP, with IP Addresses getting leased from Provider modem ( and dns servers also ? )
192.168.0.1/24 is the ip of the provider modem
I tried selecting Home Ap Dual on the Microtik user interface, set the Local Network address to 192.168.0.2 ( correct subnet /24) and dhcp disabled, NAT disabled ( as I don’t want double natting )
The internet address aquisition is set to automatic ? I also tried static ( but then I’m not sure what to enter ) → I tried setting it the same ip as the local network config eg 192.168.0.2/24 and the gateway pointed to the providers modem 192.168.0.1
DNS Servers : 8.8.8.8 ( google dns )
Firewall router = disabled
I hit apply → then wifi disconnect, reconnects → get no ip ( so dhcp is not used via my provider modem ) . I then assigned a static ip in the /24 network range ( router = 192.168.0.2 )manually to reconnect to the interface.
No internet connection is the message I get. Offcourse no dns is given to me since I’m now on static ip.. How can I get a dynamic ip from my providers modem and also how can I get the dns addresses from the provider eg.
I’m really confused. I have a knowledge of networking but the routerOS is new to me
Any help appreciated
