bricker
1
I tried to reset the config of a wAP ac to default values by pressing the reset button and then connecting it to POE.
I did not have the feeling that it worked because there was still no SSID without key, so I repeated the procedure.
Now the wAP does not light the LEDs when I connect it to the C2960-L-SM.
Is there any chance to revive the wAP ac? The switch still supplies power to other devices, so I think the switch is not broken.
Thanks for your help
Thomas
bricker
2
wAPs are now back online.
I waited a long time with disconnected APs.
Power cycled the switch 2 times.
With IOS 15.2.5 one AP was detected to be 100 MBit Full Duplex 15.2 Watts and the other one with 1000MBit Full Duplex 0Watts.
Yesterday I upgraded to 15.2.7ED. Now both devices are connected with Gigabit/Full Duplex and 15.2W power consumption.
I think it is ok to blame Cisco for not implementing correctly PoE+ in 15.2.5 and probably it is not yet really robust implemented.
