wAP ac R internal LTE antennas' dimensions?
As it says in the title - can anyone provide the wAP ac R’s LTE antenna dimensions?
I’m looking into using Mikrotik’s wAP ac R with a Quectel EM12-G LTE module, which requires Ipex4/MHF4 connectors. The wAP’s LTE antennas have larger Ipex1 (uFL) connectors. I can use an adapter, obviously, but I was wondering if replacing the original antenna with something about the same size (or at least the same width in order to slide into the Mikrotik’s plastic mount) with MHF4 connectors could be a better solution. There are many different antenna options on that Chinese shopping site we all know and love, maybe one of them will fit the Mikrotik. I’m aware of that little locking pin, I reckon a shorter antenna that still matches the width would be OK?
Thanks!
First,
RB MAIN u.FL = mhf1 at RB PCB:
Second end is mhf4 at m.2 units.
Both Female.
One seller at AliE start sell them after my request, search a " u.fl mhf1 female to mhf4 female " or write me PM.
