I’m trying to put an WAP AC to work with the following configuration:
Broadcasting 2 ssid’s that each are connected to a vlan on ether1. This should be all transparent so DHCP should come from the router that is connected on ether1.
I’ve looked at this: http://forum.mikrotik.com/t/advice-configuration-rbwap2nd/103449/7
I can imagine I have to configure 2 bridges but how can I set a default route for each bridge?
Preferably I’d use capman because I have to do several.
I won’t help you with Capsman, because I don’t know it very well, but just some info:
Bridge is transparent, you don’t need to set any routes. The only (default) route you need is for the router itself, if you want it to be able to access internet.
For wireless with VLANs, I’d like to direct your attention to vlan-mode parameter of wireless interfaces. For example, this is the essential part of my home AP for guests, where guest VLAN 82 comes as tagged on ether1:
VLAN doesn’t even have to be configured anywhere (not counting vlan-xxx parameters for wireless) if the router doesn’t need to be part of it. Also any IP configuration is only for management purposes, i.e. optional.
