wap ac vs omnitik ac?
Need a long range outdoor unit, which of these two has more range?
I plan to get a Netmetal ac in a few months, but for now I have narrowed it down to either a wap ac or omnitik ac.
The omnitik has more range due to its 7.5 dBi antenna gain, somewhat doubling the range (Antenna gain is reciproque/ is also valid for receive signal strength).
Transmit power will be reduced to stay in the legal limits, but that’s good to balance AP-client TXpower.
The radiation form of the Omnitik antenna is donut/thorus shaped (antenna theory based).
Omnitik 5 ac is limited to 5 GHz only, wAP ac has also 2.4GHz.
For more range, see https://mikrotik.com/products/ptp
Thank you, ended up ordering a Netmetal Ac2 off eurodk. Nearly the same price as the Omnitik but should yield the best performance based on Tik’s site.
