My problem is to get from DHCP address in virtual wireless interface.
I have Mikrotik wAP AC access point in mode: WISP AP
Main DHCP server is router Mikrotik RB3011
From main wireless interfaces i-wifi1 and i-wifi2 I’m getting addresses and DHCP is working fine.
From v-wifi (virtual interface) I can’t get address and probably something wrong is with DHCP.
Please help me to find how to fix this problem.
name="i-wifi1" mtu=1500 l2mtu=1600 mac-address=64:XX:XX:XX:XX:85
arp=enabled interface-type=Atheros AR9300 mode=station ssid="wifi1"
frequency=2462 band=2ghz-b/g/n channel-width=20mhz secondary-channel=""
scan-list=default wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=secure compression=no
1 R name="i-wifi2" mtu=1500 l2mtu=1600 mac-address=64:XX:XX:XX:XX:84
arp=enabled interface-type=Atheros AR9888 mode=ap-bridge ssid="wifi2"
frequency=auto band=5ghz-a/n/ac channel-width=20/40/80mhz-eeeC
secondary-channel="" scan-list=default wireless-protocol=802.11
vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default compression=no
2 name="v-wifi1" mtu=1500 l2mtu=1600 mac-address=66:XX:XX:XX:XX:85
arp=enabled interface-type=virtual master-interface=i-wifi1
mode=ap-bridge ssid="virt1" vlan-mode=no-tag vlan-id=1 wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
