Does the antenna in wAP give better signal in some directions?
I’m wondering if it makes a difference if it’s roof mounted (near the wall) or wall mounted (near the roof) when the goal is to get the best signal in a half circle out from the wall?
No, it is roughly circular. Direction does not make a big difference.
Thank you Normis
