WAP for LAN - MikroTik RouterBOARD mAP 2nD - Very slow
I’ve got a MikroTik RouterBOARD mAP 2nD.
Essentially, I just want a WAP for a LAN on 192.168.1.0/24. I’ve shown the rough topology below.
My configuration is given below.
# jan/02/1970 00:39:09 by RouterOS 6.48.6
# software id = KAL8-QJ85
# model = RBmAP2nD
# serial number =
add admin-mac=18:FD:74:52:62:52 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="united kingdom" disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid="Mapex Router" wireless-protocol=\
    802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=pwr-line1
add bridge=bridge interface=ether1
add address=192.168.1.100/24 comment=defconf interface=bridge network=\
    192.168.1.0
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.100 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
    established,related,untracked disabled=yes
    invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
    disabled=yes in-interface-list=!LAN
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
/system identity
set name=RouterOS
/tool mac-server
/tool mac-server mac-winbox
This configuration works in the sense that I can ping other devices. However it’s extremely slow. Pings take 3000-4000ms.
Have I done something wrong or do I need a higher spec of router?
Thanks in advance
First remark:
If your ether1 is the real WAN access (as in connected to your ISP modem/router) it can not be AND DHCP client AND be part of the bridge.
There is a reason those other ports are added with comment “defconf”. Since ether1 does not have this, I will assume you added it.
Remove it from the bridge.
On the question of you need a higher spec router, nobody can tell without more info why you placed it in your network and what it is being used for.
Personally I have a couple of those devices, 2 of them installed with a client each time connecting local shop network bidirectionally to Azure Cloud services over ISP modem.
No problems whatsover performance wise (max bandwith of ISP is 50Mb, map can handle a lot more then that).
They are pretty capable if you stay within their specifications.
Sorry if I’ve been unclear.
There is no need for an internet connection through the router - the wireless access is exclusively for connecting a laptop to the wired network.
The situation is that I have a machine with multiple devices on a wired network (192.168.1.0/24), and I would like to plug the router in to give me a wireless AP for the network.
Hopefully that makes sense!
Still the same.
ether1 is in your config a part of the bridge. You can not have a dhcp client on a slave port.
Remove ether1 from the bridge :smiley:
