WAP guest vlan
I am trying to create a guest VLAN on a WAP, and have the DHCP server and routing to the internet happen on a main router. I am getting very confused by the examples and tutorials I am reading.
Internet<—> ether1–R1–ether5 <----> ether1–WAP-R2–wlan1_guest
Wireless client connects to wireless interface SSID_vlan10
Wireless client received DHCP lease from R1 DHCP server server-vlan10
R2 can ping R1 192.168.10.1 on interface bridge_VLAN10
Problem:
R2 cannot ping 4.2.2.2 on interface bridge_VLAN10
Router 1 (R1):
/interface vlan
add interface=ether5 name=vlan10 vlan-id=10
add name=pool-vlan10 ranges=192.168.10.101-192.168.10.199
add address-pool=pool-vlan10 disabled=no interface=vlan10 name=server-vlan10
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
add address=192.168.10.0/24 dns-server=8.8.8.8 gateway=192.168.10.1
Router 2 (WAP-R2):
add name=bridge1
add name=bridge_VLAN10
/interface vlan
add interface=ether1 name=vlan10 vlan-id=10
/interface wireless
add disabled name=wlan1_vlan10 security-profile=profile_vlan10 ssid=SSID_vlan10 wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add name=vlan10-pool ranges=192.168.10.101-192.168.10.199
add address-pool=vlan10-pool interface=vlan10 name=vlan10-server
add bridge=bridge1 interface=Corporate-wlan1
add bridge=bridge_VLAN10 interface=wlan1_vlan10 pvid=10
add bridge=bridge_VLAN10 interface=vlan10 pvid=10
add address=192.168.10.2/24 interface=vlan10 network=192.168.10.0
I prefer to filter VLAN on the bridge, instead of creating multiple bridges.
Please have a look at this great topic, that should answer all your questions!
Assuming you want the AP to be nothing more than an AP/switch for your vlans.
Read this one… https://forum.mikrotik.com/viewtopic.php?t=182276 (but ensure you understand the vlans link erlinden gave you first)
As simple as it gets.
You only need to identify on the AP, the vlan on the trusted subnet, the subnet which the AP gets its IP address from (usually statically set via lease on the main router).
