wAP LoRa8 kit configuration in Home network
tried to find my questions already in the beginners basic forum but without success or I used the wrong search keywords.
I have two wAP LoRa kit brand new on my desk. I started configuration from the Quickstart booklet. My use case is to configure two LoRa-Gateways connected via ethernet-port to my Home router (Fritz!Box) and than connect the LoRa-Gateway to TTN. The two wAP LoRa kits should optain IP via DHCP.
I got the two Gateways configured and connected to TTN but I’m not sure, if the configuration is best. So my questions are:
  • what is the best starting point from the Quick set pre defined configurations (I use winbox64 on Windows)?
  • what es the correct mode: Router-Mode or Bridged-Mode? For the moment I configured Bridge-Mode with automatic address aquisition
  • how can I configure WLAN so that I can use it for configuration of the wAP LoRa8 kit?
  • is there a block diagram, how the different function parts of the wAP LoRa kit are connected together?
Thank you for your support
