I received a WAP LTE to replace a broken 4G modem.
The old setup was some old Huawei, connected to our RB2011UiAS-RM. The 2011 was set up as a pretty standard NAT/DHCP-appliance for the devices behind it. So far so good. The RB2011 got its WAN address from the Huawei. Simple as it gets.
BUT, my problem now is that I actually can not figure out how to set the wAP LTE up to bridge the connection so that the 2011 can use the public IP. I thought i could just create a bridge and attach the interfaces, but the LTE interface is not bridgeable it seem. So, right now i have set the wAP LTE up to do NAT but I would lite to move this functionality back to the 2011.
Soooo, could soneone shed some light… or better yet, a config for the wAP LTE?
There is a new functionality in RouterOS 6.41rc that allows to “bridge” your LTE/4G modem with the device being connected to MikroTik with LTE modem. However, it doesn’t work the way I thought in case of 4G USB modem, but maybe it is different in case of wAP LTE. You can try to do a passthriugh and see what happens.
In previous published rc version of 6.41 (I think it was 6.41rc38) this E3372-153 didn’t work at all. You informed via ticket, that you are aware about it, and next release candidate published will solve the problem. Then we got 6.41.rc44, problem solved, but not the way we wanted…
