WAP LTE connection issues
Hi
I got myself an WAP LTE to replace the USB dongle on my CRS125 because it does not allow me to configure NAT/Portforwarding.
I went with the USB dongle for quite some time and there were no major connection issues so I suppose the signal is OK at the given location.
I inserted the SIM into the WAP LTE and everything worked like a charm - at first. Turns that after a couple minutes to a couple of hours there it just stops working. No data is transmitted over LTE but there the interface is up and has an ip. I configured watchdog to reset the unit which at least mitigates the problem but that is not a proper solution to me.
I attached the logs of the last days but to me they seem pretty OK until the point where the unit reboots without prior warnings/errors
RouterOS is already up to date (6.40.5)
Any ideas?
Edit: upload does not work - embedding them here:
Nov/27/2017 21:10:54 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:13:05 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 21:13:05 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 21:15:44 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 21:15:44 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:16:55 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 21:16:55 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 21:18:04 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 21:18:04 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:19:25 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 21:19:25 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 21:20:44 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 21:20:44 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:22:07 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 21:22:07 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 21:28:04 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 21:28:04 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:38:25 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 21:38:25 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 21:40:24 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 21:40:24 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:42:05 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 21:42:05 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 21:43:24 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 21:43:24 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:47:25 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 21:47:25 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 21:48:16 watchdog,error,critical watchdog cannot ping address 8.8.8.8, rebooting
Nov/27/2017 21:48:17 ovpn,info cdp-test: terminating... - system is going to shutdown
Nov/27/2017 21:48:18 ovpn,info cdp-test: disconnected
Nov/27/2017 21:48:21 system,error,critical System rebooted because of ping watchdog timeout
Nov/27/2017 21:48:21 system,info router rebooted
Nov/27/2017 21:48:23 ovpn,info cdp-test: initializing...
Nov/27/2017 21:48:23 ovpn,info cdp-test: connecting...
Nov/27/2017 21:48:23 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:48:23 ovpn,info cdp-test: disconnected
Nov/27/2017 21:48:24 ovpn,info cdp-test: initializing...
Nov/27/2017 21:48:24 ovpn,info cdp-test: connecting...
Nov/27/2017 21:48:24 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:48:24 ovpn,info cdp-test: disconnected
Nov/27/2017 21:48:26 ovpn,info cdp-test: initializing...
Nov/27/2017 21:48:26 ovpn,info cdp-test: connecting...
Nov/27/2017 21:48:26 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:48:26 ovpn,info cdp-test: disconnected
Nov/27/2017 21:48:29 ovpn,info cdp-test: initializing...
Nov/27/2017 21:48:29 ovpn,info cdp-test: connecting...
Nov/27/2017 21:48:29 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:48:29 ovpn,info cdp-test: disconnected
Nov/27/2017 21:48:30 interface,info ether1 link up (speed 100M, full duplex)
Nov/27/2017 21:48:35 ovpn,info cdp-test: initializing...
Nov/27/2017 21:48:35 ovpn,info cdp-test: connecting...
Nov/27/2017 21:48:35 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:48:35 ovpn,info cdp-test: disconnected
Nov/27/2017 21:48:36 lte,async lte1: sent AT E0 V1
Nov/27/2017 21:48:36 lte,async lte1: rcvd OK
Nov/27/2017 21:48:36 lte,async lte1: sent AT+CGMI
Nov/27/2017 21:48:36 lte,async lte1: rcvd +CGMI: "MikroTik"
Nov/27/2017 21:48:36 lte,async lte1: sent AT+CGMM
Nov/27/2017 21:48:36 lte,async lte1: rcvd +CGMM: "R11e-LTE"
Nov/27/2017 21:48:36 lte,async lte1: sent AT+CGMR
Nov/27/2017 21:48:36 lte,async lte1: rcvd +CGMR: "MikroTik_CP_2.160.000_v001"
Nov/27/2017 21:48:36 lte,async lte1: sent AT+CGSN
Nov/27/2017 21:48:36 lte,async lte1: rcvd +CGSN: 356159060372558
Nov/27/2017 21:48:36 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 21:48:37 lte,async,event ^SRVST: 2
Nov/27/2017 21:48:37 lte,async,event +CREG: 1
Nov/27/2017 21:48:37 lte,async,event +CGREG: 0
Nov/27/2017 21:48:37 lte,async,event +CGEV: ME DETACH
Nov/27/2017 21:48:38 lte,async,event ^SRVST: 0
Nov/27/2017 21:48:38 lte,async,event +CREG: 0
Nov/27/2017 21:48:44 lte,async lte1: rcvd OK
Nov/27/2017 21:48:44 lte,async lte1: sent AT+CMEE=1
Nov/27/2017 21:48:44 lte,async lte1: sent AT+CREG=2
Nov/27/2017 21:48:44 lte,async lte1: sent AT+CGREG=2
Nov/27/2017 21:48:44 lte,async lte1: sent AT+CEREG=2
Nov/27/2017 21:48:44 lte,async lte1: sent AT+CGEREP=2,0
Nov/27/2017 21:48:44 lte,async lte1: sent AT+CMGF=0
Nov/27/2017 21:48:44 lte,async lte1: sent AT+CNMI=1,1,0,1,0
Nov/27/2017 21:48:44 lte,async lte1: sent AT+EEMOPT=1
Nov/27/2017 21:48:44 lte,async lte1: sent AT*MRD_SN?
Nov/27/2017 21:48:45 lte,async lte1: rcvd *MRD_SN:723C031F1162
Nov/27/2017 21:48:45 lte,debug lte serial: *MRD_SN:723C031F1162
Nov/27/2017 21:48:45 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 21:48:45 lte,async lte1: rcvd OK
Nov/27/2017 21:48:45 lte,async lte1: sent AT*CGDFLT=0,"IP","drei.at",,,,,,,,,,,,,,,,,,1
Nov/27/2017 21:48:45 lte,async lte1: sent AT+CPIN?
Nov/27/2017 21:48:45 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 21:48:45 ovpn,info cdp-test: initializing...
Nov/27/2017 21:48:45 ovpn,info cdp-test: connecting...
Nov/27/2017 21:48:45 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:48:45 ovpn,info cdp-test: disconnected
Nov/27/2017 21:48:48 lte,async lte1: sent AT+CPMS="SM","SM","SM"
Nov/27/2017 21:48:48 lte,async lte1: rcvd +CPMS: 0,20,0,20,0,0
Nov/27/2017 21:48:48 lte,async lte1: sent AT+CFUN?
Nov/27/2017 21:48:48 lte,async lte1: rcvd +CFUN: 4
Nov/27/2017 21:48:48 lte,async lte1: sent AT+CNUM
Nov/27/2017 21:48:48 lte,async lte1: sent AT+CIMI
Nov/27/2017 21:48:49 lte,async lte1: rcvd 232106928869593
Nov/27/2017 21:48:49 lte,async lte1: sent AT+CPIN?
Nov/27/2017 21:48:49 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 21:48:49 lte,async lte1: sent AT*BAND=15,79,147,480,589829,0,2,0
Nov/27/2017 21:48:49 lte,async lte1: rcvd OK
Nov/27/2017 21:48:50 lte,async lte1: sent AT+CFUN=1
Nov/27/2017 21:48:50 lte,async,event +CREG: 2
Nov/27/2017 21:48:50 lte,async,event +CEREG: 2
Nov/27/2017 21:48:50 lte,async lte1: rcvd OK
Nov/27/2017 21:48:50 lte,debug lte1: config ok
Nov/27/2017 21:48:51 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 21:48:51 lte,info lte1: registered, home
Nov/27/2017 21:48:51 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:48:51 lte,debug lte1: network access technology: Evolved 3G (LTE)
Nov/27/2017 21:48:51 lte,async,event +CGEV: EPS PDN ACT 5
Nov/27/2017 21:48:51 lte,async,event +NITZ: PLMN Long Name: 3 AT,
Nov/27/2017 21:48:51 lte,async,event +NITZ: PLMN Short Name: 3 AT,
Nov/27/2017 21:48:51 lte,async,event +NITZ: 17/11/27,20:49:14+4,0
Nov/27/2017 21:48:52 lte,async lte1: sent AT+CGDCONT?
Nov/27/2017 21:48:52 lte,async lte1: rcvd +CGDCONT: 5,"IP","drei.at.mnc010.mcc232.gprs","77.117.136.118",,,802110030100108106d55e4e108306d55e4e11000d04d55e4e10000d04d55e4e11,
Nov/27/2017 21:48:52 lte,async lte1: sent AT+CGCONTRDP=5
Nov/27/2017 21:48:52 lte,async lte1: rcvd +CGCONTRDP: 5,5,"drei.at.mnc010.mcc232.gprs","77.117.136.118","","","213.94.78.16","213.94.78.17","","","0","0"
Nov/27/2017 21:48:52 interface,info lte1 link up
Nov/27/2017 21:48:52 system,info item added
Nov/27/2017 21:48:55 ovpn,info cdp-test: initializing...
Nov/27/2017 21:48:55 ovpn,info cdp-test: connecting...
Nov/27/2017 21:49:00 ovpn,info cdp-test: using encoding - AES-256-CBC/SHA1
Nov/27/2017 21:49:00 ovpn,info cdp-test: connected
Nov/27/2017 21:50:06 system,info cloud change time Nov/27/2017-21:49:43 => Nov/27/2017-21:50:06
Nov/27/2017 21:52:15 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 21:52:15 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 21:54:44 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 21:54:44 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:56:24 watchdog,error,critical watchdog cannot ping address 8.8.8.8, rebooting
Nov/27/2017 21:56:24 ovpn,info cdp-test: terminating... - system is going to shutdown
Nov/27/2017 21:56:25 ovpn,info cdp-test: disconnected
Nov/27/2017 21:56:30 system,error,critical System rebooted because of ping watchdog timeout
Nov/27/2017 21:56:30 system,info router rebooted
Nov/27/2017 21:56:32 ovpn,info cdp-test: initializing...
Nov/27/2017 21:56:32 ovpn,info cdp-test: connecting...
Nov/27/2017 21:56:32 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:56:32 ovpn,info cdp-test: disconnected
Nov/27/2017 21:56:33 ovpn,info cdp-test: initializing...
Nov/27/2017 21:56:33 ovpn,info cdp-test: connecting...
Nov/27/2017 21:56:33 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:56:33 ovpn,info cdp-test: disconnected
Nov/27/2017 21:56:34 ovpn,info cdp-test: initializing...
Nov/27/2017 21:56:34 ovpn,info cdp-test: connecting...
Nov/27/2017 21:56:34 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:56:34 ovpn,info cdp-test: disconnected
Nov/27/2017 21:56:38 ovpn,info cdp-test: initializing...
Nov/27/2017 21:56:38 ovpn,info cdp-test: connecting...
Nov/27/2017 21:56:38 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:56:38 ovpn,info cdp-test: disconnected
Nov/27/2017 21:56:40 interface,info ether1 link up (speed 100M, full duplex)
Nov/27/2017 21:56:44 ovpn,info cdp-test: initializing...
Nov/27/2017 21:56:44 ovpn,info cdp-test: connecting...
Nov/27/2017 21:56:44 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:56:44 ovpn,info cdp-test: disconnected
Nov/27/2017 21:56:50 lte,async lte1: sent AT E0 V1
Nov/27/2017 21:56:50 lte,async lte1: rcvd OK
Nov/27/2017 21:56:50 lte,async lte1: sent AT+CGMI
Nov/27/2017 21:56:50 lte,async lte1: rcvd +CGMI: "MikroTik"
Nov/27/2017 21:56:50 lte,async lte1: sent AT+CGMM
Nov/27/2017 21:56:50 lte,async lte1: rcvd +CGMM: "R11e-LTE"
Nov/27/2017 21:56:50 lte,async lte1: sent AT+CGMR
Nov/27/2017 21:56:50 lte,async lte1: rcvd +CGMR: "MikroTik_CP_2.160.000_v001"
Nov/27/2017 21:56:50 lte,async lte1: sent AT+CGSN
Nov/27/2017 21:56:50 lte,async lte1: rcvd +CGSN: 356159060372558
Nov/27/2017 21:56:50 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 21:56:50 lte,async,event ^SRVST: 2
Nov/27/2017 21:56:50 lte,async,event +CREG: 1
Nov/27/2017 21:56:50 lte,async,event +CGREG: 0
Nov/27/2017 21:56:50 lte,async,event +CGEV: ME DETACH
Nov/27/2017 21:56:51 lte,async,event ^SRVST: 0
Nov/27/2017 21:56:51 lte,async,event +CREG: 0
Nov/27/2017 21:56:54 ovpn,info cdp-test: initializing...
Nov/27/2017 21:56:54 ovpn,info cdp-test: connecting...
Nov/27/2017 21:56:54 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:56:54 ovpn,info cdp-test: disconnected
Nov/27/2017 21:56:58 lte,async lte1: rcvd OK
Nov/27/2017 21:56:58 lte,async lte1: sent AT+CMEE=1
Nov/27/2017 21:56:58 lte,async lte1: sent AT+CREG=2
Nov/27/2017 21:56:58 lte,async lte1: sent AT+CGREG=2
Nov/27/2017 21:56:58 lte,async lte1: sent AT+CEREG=2
Nov/27/2017 21:56:58 lte,async lte1: sent AT+CGEREP=2,0
Nov/27/2017 21:56:58 lte,async lte1: sent AT+CMGF=0
Nov/27/2017 21:56:58 lte,async lte1: sent AT+CNMI=1,1,0,1,0
Nov/27/2017 21:56:58 lte,async lte1: sent AT+EEMOPT=1
Nov/27/2017 21:56:58 lte,async lte1: sent AT*MRD_SN?
Nov/27/2017 21:56:58 lte,async lte1: rcvd *MRD_SN:723C031F1162
Nov/27/2017 21:56:58 lte,debug lte serial: *MRD_SN:723C031F1162
Nov/27/2017 21:56:58 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 21:56:58 lte,async lte1: sent AT*CGDFLT=0,"IP","drei.at",,,,,,,,,,,,,,,,,,1
Nov/27/2017 21:56:58 lte,async lte1: sent AT+CPIN?
Nov/27/2017 21:56:58 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 21:57:01 lte,async lte1: sent AT+CPMS="SM","SM","SM"
Nov/27/2017 21:57:01 lte,async lte1: rcvd +CPMS: 0,20,0,20,0,0
Nov/27/2017 21:57:01 lte,async lte1: sent AT+CFUN?
Nov/27/2017 21:57:01 lte,async lte1: rcvd +CFUN: 4
Nov/27/2017 21:57:01 lte,async lte1: sent AT+CNUM
Nov/27/2017 21:57:01 lte,async lte1: sent AT+CIMI
Nov/27/2017 21:57:01 lte,async lte1: sent AT+CPIN?
Nov/27/2017 21:57:03 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 21:57:03 lte,async lte1: sent AT*BAND=15,79,147,480,589829,0,2,0
Nov/27/2017 21:57:03 lte,async lte1: rcvd OK
Nov/27/2017 21:57:04 lte,async lte1: sent AT+CFUN=1
Nov/27/2017 21:57:04 lte,async,event +CREG: 2
Nov/27/2017 21:57:04 lte,async,event +CEREG: 2
Nov/27/2017 21:57:04 lte,async lte1: rcvd OK
Nov/27/2017 21:57:04 lte,debug lte1: config ok
Nov/27/2017 21:57:04 ovpn,info cdp-test: initializing...
Nov/27/2017 21:57:04 ovpn,info cdp-test: connecting...
Nov/27/2017 21:57:04 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 21:57:04 ovpn,info cdp-test: disconnected
Nov/27/2017 21:57:04 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 21:57:04 lte,info lte1: registered, home
Nov/27/2017 21:57:04 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 21:57:04 lte,debug lte1: network access technology: Evolved 3G (LTE)
Nov/27/2017 21:57:04 lte,async,event +CGEV: EPS PDN ACT 5
Nov/27/2017 21:57:04 lte,async,event +NITZ: PLMN Long Name: 3 AT,
Nov/27/2017 21:57:04 lte,async,event +NITZ: PLMN Short Name: 3 AT,
Nov/27/2017 21:57:04 lte,async,event +NITZ: 17/11/27,20:57:25+4,0
Nov/27/2017 21:57:05 lte,async lte1: sent AT+CGDCONT?
Nov/27/2017 21:57:05 lte,async lte1: rcvd +CGDCONT: 5,"IP","drei.at.mnc010.mcc232.gprs","77.117.135.251",,,802110030100108106d55e4e108306d55e4e11000d04d55e4e10000d04d55e4e11,
Nov/27/2017 21:57:05 lte,async lte1: sent AT+CGCONTRDP=5
Nov/27/2017 21:57:05 lte,async lte1: rcvd +CGCONTRDP: 5,5,"drei.at.mnc010.mcc232.gprs","77.117.135.251","","","213.94.78.16","213.94.78.17","","","0","0"
Nov/27/2017 21:57:05 interface,info lte1 link up
Nov/27/2017 21:57:06 system,info item added
Nov/27/2017 21:57:14 ovpn,info cdp-test: initializing...
Nov/27/2017 21:57:14 ovpn,info cdp-test: connecting...
Nov/27/2017 21:57:19 ovpn,info cdp-test: using encoding - AES-256-CBC/SHA1
Nov/27/2017 21:57:19 ovpn,info cdp-test: connected
Nov/27/2017 21:57:56 system,info cloud change time Nov/27/2017-21:57:35 => Nov/27/2017-21:57:56
Nov/27/2017 21:58:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 21:58:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:00:24 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:00:24 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:01:35 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:01:35 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:02:55 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:02:55 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:04:26 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:04:26 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:05:55 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:05:55 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:07:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:07:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:10:25 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:10:25 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:11:36 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:11:36 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:13:04 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:13:04 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:14:46 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:14:46 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:16:55 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:16:55 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:18:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:18:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:20:55 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:20:55 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:22:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:22:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:25:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:25:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:28:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:28:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:29:01 watchdog,error,critical watchdog cannot ping address 8.8.8.8, rebooting
Nov/27/2017 22:29:01 ovpn,info cdp-test: terminating... - system is going to shutdown
Nov/27/2017 22:29:02 ovpn,info cdp-test: disconnected
Nov/27/2017 22:29:06 system,error,critical router was rebooted without proper shutdown by watchdog timer
Nov/27/2017 22:29:09 ovpn,info cdp-test: initializing...
Nov/27/2017 22:29:09 ovpn,info cdp-test: connecting...
Nov/27/2017 22:29:09 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:29:09 ovpn,info cdp-test: disconnected
Nov/27/2017 22:29:10 ovpn,info cdp-test: initializing...
Nov/27/2017 22:29:10 ovpn,info cdp-test: connecting...
Nov/27/2017 22:29:10 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:29:10 ovpn,info cdp-test: disconnected
Nov/27/2017 22:29:11 ovpn,info cdp-test: initializing...
Nov/27/2017 22:29:11 ovpn,info cdp-test: connecting...
Nov/27/2017 22:29:11 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:29:11 ovpn,info cdp-test: disconnected
Nov/27/2017 22:29:14 ovpn,info cdp-test: initializing...
Nov/27/2017 22:29:14 ovpn,info cdp-test: connecting...
Nov/27/2017 22:29:14 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:29:14 ovpn,info cdp-test: disconnected
Nov/27/2017 22:29:17 lte,async lte1: sent AT E0 V1
Nov/27/2017 22:29:17 lte,async lte1: rcvd OK
Nov/27/2017 22:29:17 lte,async lte1: sent AT+CGMI
Nov/27/2017 22:29:17 lte,async lte1: rcvd +CGMI: "MikroTik"
Nov/27/2017 22:29:17 lte,async lte1: sent AT+CGMM
Nov/27/2017 22:29:17 lte,async lte1: rcvd +CGMM: "R11e-LTE"
Nov/27/2017 22:29:17 lte,async lte1: sent AT+CGMR
Nov/27/2017 22:29:17 lte,async lte1: rcvd +CGMR: "MikroTik_CP_2.160.000_v001"
Nov/27/2017 22:29:17 lte,async lte1: sent AT+CGSN
Nov/27/2017 22:29:17 lte,async lte1: rcvd +CGSN: 356159060372558
Nov/27/2017 22:29:17 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 22:29:17 lte,async,event ^SRVST: 2
Nov/27/2017 22:29:17 lte,async,event +CREG: 1
Nov/27/2017 22:29:17 lte,async,event +CGREG: 0
Nov/27/2017 22:29:17 lte,async,event +CGEV: ME DETACH
Nov/27/2017 22:29:17 interface,info ether1 link up (speed 100M, full duplex)
Nov/27/2017 22:29:18 lte,async,event ^SRVST: 0
Nov/27/2017 22:29:18 lte,async,event +CREG: 0
Nov/27/2017 22:29:21 ovpn,info cdp-test: initializing...
Nov/27/2017 22:29:21 ovpn,info cdp-test: connecting...
Nov/27/2017 22:29:21 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:29:21 ovpn,info cdp-test: disconnected
Nov/27/2017 22:29:25 lte,async lte1: rcvd OK
Nov/27/2017 22:29:25 lte,async lte1: sent AT+CMEE=1
Nov/27/2017 22:29:25 lte,async lte1: sent AT+CREG=2
Nov/27/2017 22:29:25 lte,async lte1: sent AT+CGREG=2
Nov/27/2017 22:29:25 lte,async lte1: sent AT+CEREG=2
Nov/27/2017 22:29:25 lte,async lte1: sent AT+CGEREP=2,0
Nov/27/2017 22:29:25 lte,async lte1: sent AT+CMGF=0
Nov/27/2017 22:29:25 lte,async lte1: sent AT+CNMI=1,1,0,1,0
Nov/27/2017 22:29:25 lte,async lte1: sent AT+EEMOPT=1
Nov/27/2017 22:29:25 lte,async lte1: sent AT*MRD_SN?
Nov/27/2017 22:29:25 lte,async lte1: rcvd *MRD_SN:723C031F1162
Nov/27/2017 22:29:25 lte,debug lte serial: *MRD_SN:723C031F1162
Nov/27/2017 22:29:25 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 22:29:25 lte,async lte1: sent AT*CGDFLT=0,"IP","drei.at",,,,,,,,,,,,,,,,,,1
Nov/27/2017 22:29:25 lte,async lte1: sent AT+CPIN?
Nov/27/2017 22:29:25 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 22:29:28 lte,async lte1: sent AT+CPMS="SM","SM","SM"
Nov/27/2017 22:29:28 lte,async lte1: rcvd +CPMS: 0,20,0,20,0,0
Nov/27/2017 22:29:28 lte,async lte1: sent AT+CFUN?
Nov/27/2017 22:29:28 lte,async lte1: rcvd +CFUN: 4
Nov/27/2017 22:29:28 lte,async lte1: sent AT+CNUM
Nov/27/2017 22:29:28 lte,async lte1: sent AT+CIMI
Nov/27/2017 22:29:30 lte,async lte1: rcvd 232106928869593
Nov/27/2017 22:29:30 lte,async lte1: sent AT+CPIN?
Nov/27/2017 22:29:30 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 22:29:30 lte,async lte1: sent AT*BAND=15,79,147,480,589829,0,2,0
Nov/27/2017 22:29:30 lte,async lte1: rcvd OK
Nov/27/2017 22:29:31 lte,async lte1: sent AT+CFUN=1
Nov/27/2017 22:29:31 lte,async,event +CREG: 2
Nov/27/2017 22:29:31 lte,async,event +CEREG: 2
Nov/27/2017 22:29:31 lte,async lte1: rcvd OK
Nov/27/2017 22:29:31 lte,debug lte1: config ok
Nov/27/2017 22:29:31 ovpn,info cdp-test: initializing...
Nov/27/2017 22:29:31 ovpn,info cdp-test: connecting...
Nov/27/2017 22:29:31 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:29:31 ovpn,info cdp-test: disconnected
Nov/27/2017 22:29:32 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:29:32 lte,info lte1: registered, home
Nov/27/2017 22:29:32 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:29:32 lte,debug lte1: network access technology: Evolved 3G (LTE)
Nov/27/2017 22:29:32 lte,async,event +CGEV: EPS PDN ACT 5
Nov/27/2017 22:29:32 lte,async,event +NITZ: PLMN Long Name: 3 AT,
Nov/27/2017 22:29:32 lte,async,event +NITZ: PLMN Short Name: 3 AT,
Nov/27/2017 22:29:32 lte,async,event +NITZ: 17/11/27,21:30:38+4,0
Nov/27/2017 22:29:33 lte,async lte1: sent AT+CGDCONT?
Nov/27/2017 22:29:33 lte,async lte1: rcvd +CGDCONT: 5,"IP","drei.at.mnc010.mcc232.gprs","178.114.180.219",,,802110030100108106d55e4e118306d55e4e10000d04d55e4e11000d04d55e4e10,
Nov/27/2017 22:29:33 lte,async lte1: sent AT+CGCONTRDP=5
Nov/27/2017 22:29:33 lte,async lte1: rcvd +CGCONTRDP: 5,5,"drei.at.mnc010.mcc232.gprs","178.114.180.219","","","213.94.78.17","213.94.78.16","","","0","0"
Nov/27/2017 22:29:33 interface,info lte1 link up
Nov/27/2017 22:29:33 system,info item added
Nov/27/2017 22:29:41 ovpn,info cdp-test: initializing...
Nov/27/2017 22:29:41 ovpn,info cdp-test: connecting...
Nov/27/2017 22:29:46 ovpn,info cdp-test: using encoding - AES-256-CBC/SHA1
Nov/27/2017 22:29:47 ovpn,info cdp-test: connected
Nov/27/2017 22:29:59 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:29:59 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:33:34 system,info cloud change time Nov/27/2017-22:32:28 => Nov/27/2017-22:33:34
Nov/27/2017 22:34:14 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:34:14 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:46:46 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:46:46 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:48:05 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:48:05 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:49:15 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:49:15 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:50:13 watchdog,error,critical watchdog cannot ping address 8.8.8.8, rebooting
Nov/27/2017 22:50:13 ovpn,info cdp-test: terminating... - system is going to shutdown
Nov/27/2017 22:50:14 ovpn,info cdp-test: disconnected
Nov/27/2017 22:50:19 system,error,critical System rebooted because of ping watchdog timeout
Nov/27/2017 22:50:19 system,info router rebooted
Nov/27/2017 22:50:21 ovpn,info cdp-test: initializing...
Nov/27/2017 22:50:21 ovpn,info cdp-test: connecting...
Nov/27/2017 22:50:21 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:50:21 ovpn,info cdp-test: disconnected
Nov/27/2017 22:50:22 ovpn,info cdp-test: initializing...
Nov/27/2017 22:50:22 ovpn,info cdp-test: connecting...
Nov/27/2017 22:50:22 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:50:22 ovpn,info cdp-test: disconnected
Nov/27/2017 22:50:24 ovpn,info cdp-test: initializing...
Nov/27/2017 22:50:24 ovpn,info cdp-test: connecting...
Nov/27/2017 22:50:24 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:50:24 ovpn,info cdp-test: disconnected
Nov/27/2017 22:50:27 ovpn,info cdp-test: initializing...
Nov/27/2017 22:50:27 ovpn,info cdp-test: connecting...
Nov/27/2017 22:50:27 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:50:27 ovpn,info cdp-test: disconnected
Nov/27/2017 22:50:29 interface,info ether1 link up (speed 100M, full duplex)
Nov/27/2017 22:50:30 lte,async lte1: sent AT E0 V1
Nov/27/2017 22:50:30 lte,async lte1: rcvd OK
Nov/27/2017 22:50:30 lte,async lte1: sent AT+CGMI
Nov/27/2017 22:50:30 lte,async lte1: rcvd +CGMI: "MikroTik"
Nov/27/2017 22:50:30 lte,async lte1: sent AT+CGMM
Nov/27/2017 22:50:30 lte,async lte1: rcvd +CGMM: "R11e-LTE"
Nov/27/2017 22:50:30 lte,async lte1: sent AT+CGMR
Nov/27/2017 22:50:30 lte,async lte1: rcvd +CGMR: "MikroTik_CP_2.160.000_v001"
Nov/27/2017 22:50:30 lte,async lte1: sent AT+CGSN
Nov/27/2017 22:50:30 lte,async lte1: rcvd +CGSN: 356159060372558
Nov/27/2017 22:50:30 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 22:50:30 lte,async,event ^SRVST: 2
Nov/27/2017 22:50:30 lte,async,event +CREG: 1
Nov/27/2017 22:50:30 lte,async,event +CGREG: 0
Nov/27/2017 22:50:30 lte,async,event +CGEV: ME DETACH
Nov/27/2017 22:50:31 lte,async,event ^SRVST: 0
Nov/27/2017 22:50:31 lte,async,event +CREG: 0
Nov/27/2017 22:50:34 ovpn,info cdp-test: initializing...
Nov/27/2017 22:50:34 ovpn,info cdp-test: connecting...
Nov/27/2017 22:50:34 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:50:34 ovpn,info cdp-test: disconnected
Nov/27/2017 22:50:38 lte,async lte1: rcvd OK
Nov/27/2017 22:50:38 lte,async lte1: sent AT+CMEE=1
Nov/27/2017 22:50:38 lte,async lte1: sent AT+CREG=2
Nov/27/2017 22:50:38 lte,async lte1: sent AT+CGREG=2
Nov/27/2017 22:50:38 lte,async lte1: sent AT+CEREG=2
Nov/27/2017 22:50:38 lte,async lte1: sent AT+CGEREP=2,0
Nov/27/2017 22:50:38 lte,async lte1: sent AT+CMGF=0
Nov/27/2017 22:50:38 lte,async lte1: sent AT+CNMI=1,1,0,1,0
Nov/27/2017 22:50:38 lte,async lte1: sent AT+EEMOPT=1
Nov/27/2017 22:50:38 lte,async lte1: sent AT*MRD_SN?
Nov/27/2017 22:50:38 lte,async lte1: rcvd *MRD_SN:723C031F1162
Nov/27/2017 22:50:38 lte,debug lte serial: *MRD_SN:723C031F1162
Nov/27/2017 22:50:38 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 22:50:38 lte,async lte1: sent AT*CGDFLT=0,"IP","drei.at",,,,,,,,,,,,,,,,,,1
Nov/27/2017 22:50:38 lte,async lte1: sent AT+CPIN?
Nov/27/2017 22:50:38 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 22:50:41 lte,async lte1: sent AT+CPMS="SM","SM","SM"
Nov/27/2017 22:50:41 lte,async lte1: rcvd +CPMS: 0,20,0,20,0,0
Nov/27/2017 22:50:41 lte,async lte1: sent AT+CFUN?
Nov/27/2017 22:50:41 lte,async lte1: rcvd +CFUN: 4
Nov/27/2017 22:50:41 lte,async lte1: sent AT+CNUM
Nov/27/2017 22:50:41 lte,async lte1: sent AT+CIMI
Nov/27/2017 22:50:43 lte,async lte1: rcvd 232106928869593
Nov/27/2017 22:50:43 lte,async lte1: sent AT+CPIN?
Nov/27/2017 22:50:43 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 22:50:43 lte,async lte1: sent AT*BAND=15,79,147,480,589829,0,2,0
Nov/27/2017 22:50:43 lte,async lte1: rcvd OK
Nov/27/2017 22:50:44 ovpn,info cdp-test: initializing...
Nov/27/2017 22:50:44 ovpn,info cdp-test: connecting...
Nov/27/2017 22:50:44 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 22:50:44 ovpn,info cdp-test: disconnected
Nov/27/2017 22:50:44 lte,async lte1: sent AT+CFUN=1
Nov/27/2017 22:50:44 lte,async,event +CREG: 2
Nov/27/2017 22:50:44 lte,async,event +CEREG: 2
Nov/27/2017 22:50:44 lte,async lte1: rcvd OK
Nov/27/2017 22:50:44 lte,debug lte1: config ok
Nov/27/2017 22:50:45 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:50:45 lte,info lte1: registered, home
Nov/27/2017 22:50:45 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:50:45 lte,debug lte1: network access technology: Evolved 3G (LTE)
Nov/27/2017 22:50:45 lte,async,event +CGEV: EPS PDN ACT 5
Nov/27/2017 22:50:45 lte,async,event +NITZ: PLMN Long Name: 3 AT,
Nov/27/2017 22:50:45 lte,async,event +NITZ: PLMN Short Name: 3 AT,
Nov/27/2017 22:50:45 lte,async,event +NITZ: 17/11/27,21:51:06+4,0
Nov/27/2017 22:50:46 lte,async lte1: sent AT+CGDCONT?
Nov/27/2017 22:50:46 lte,async lte1: rcvd +CGDCONT: 5,"IP","drei.at.mnc010.mcc232.gprs","77.117.170.218",,,802110030100108106d55e4e108306d55e4e11000d04d55e4e10000d04d55e4e11,
Nov/27/2017 22:50:46 lte,async lte1: sent AT+CGCONTRDP=5
Nov/27/2017 22:50:46 lte,async lte1: rcvd +CGCONTRDP: 5,5,"drei.at.mnc010.mcc232.gprs","77.117.170.218","","","213.94.78.16","213.94.78.17","","","0","0"
Nov/27/2017 22:50:46 interface,info lte1 link up
Nov/27/2017 22:50:46 system,info item added
Nov/27/2017 22:50:54 ovpn,info cdp-test: initializing...
Nov/27/2017 22:50:54 ovpn,info cdp-test: connecting...
Nov/27/2017 22:50:58 ovpn,info cdp-test: terminating... - peer disconnected
Nov/27/2017 22:50:58 ovpn,info cdp-test: disconnected
Nov/27/2017 22:51:09 ovpn,info cdp-test: initializing...
Nov/27/2017 22:51:09 ovpn,info cdp-test: connecting...
Nov/27/2017 22:51:13 ovpn,info cdp-test: using encoding - AES-256-CBC/SHA1
Nov/27/2017 22:51:13 ovpn,info cdp-test: connected
Nov/27/2017 22:51:44 system,info cloud change time Nov/27/2017-22:51:24 => Nov/27/2017-22:51:44
Nov/27/2017 22:51:46 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:51:46 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 22:54:55 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 22:54:55 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 22:57:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 22:57:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 23:00:55 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 23:00:55 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 23:03:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 23:03:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 23:05:21 watchdog,error,critical watchdog cannot ping address 8.8.8.8, rebooting
Nov/27/2017 23:05:21 ovpn,info cdp-test: terminating... - system is going to shutdown
Nov/27/2017 23:05:22 ovpn,info cdp-test: disconnected
Nov/27/2017 23:05:26 system,error,critical System rebooted because of ping watchdog timeout
Nov/27/2017 23:05:27 system,info router rebooted
Nov/27/2017 23:05:28 ovpn,info cdp-test: initializing...
Nov/27/2017 23:05:28 ovpn,info cdp-test: connecting...
Nov/27/2017 23:05:29 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:05:29 ovpn,info cdp-test: disconnected
Nov/27/2017 23:05:29 ovpn,info cdp-test: initializing...
Nov/27/2017 23:05:29 ovpn,info cdp-test: connecting...
Nov/27/2017 23:05:31 ovpn,info cdp-test: initializing...
Nov/27/2017 23:05:31 ovpn,info cdp-test: connecting...
Nov/27/2017 23:05:31 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:05:31 ovpn,info cdp-test: disconnected
Nov/27/2017 23:05:34 ovpn,info cdp-test: initializing...
Nov/27/2017 23:05:34 ovpn,info cdp-test: connecting...
Nov/27/2017 23:05:34 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:05:34 ovpn,info cdp-test: disconnected
Nov/27/2017 23:05:36 lte,async lte1: sent AT E0 V1
Nov/27/2017 23:05:36 lte,async lte1: rcvd OK
Nov/27/2017 23:05:36 lte,async lte1: sent AT+CGMI
Nov/27/2017 23:05:36 lte,async lte1: rcvd +CGMI: "MikroTik"
Nov/27/2017 23:05:36 lte,async lte1: sent AT+CGMM
Nov/27/2017 23:05:36 lte,async lte1: rcvd +CGMM: "R11e-LTE"
Nov/27/2017 23:05:36 lte,async lte1: sent AT+CGMR
Nov/27/2017 23:05:36 lte,async lte1: rcvd +CGMR: "MikroTik_CP_2.160.000_v001"
Nov/27/2017 23:05:36 lte,async lte1: sent AT+CGSN
Nov/27/2017 23:05:36 lte,async lte1: rcvd +CGSN: 356159060372558
Nov/27/2017 23:05:36 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 23:05:37 lte,async,event ^SRVST: 2
Nov/27/2017 23:05:37 lte,async,event +CREG: 1
Nov/27/2017 23:05:37 lte,async,event +CGREG: 0
Nov/27/2017 23:05:37 lte,async,event +CGEV: ME DETACH
Nov/27/2017 23:05:37 interface,info ether1 link up (speed 100M, full duplex)
Nov/27/2017 23:05:38 lte,async,event ^SRVST: 0
Nov/27/2017 23:05:38 lte,async,event +CREG: 0
Nov/27/2017 23:05:41 ovpn,info cdp-test: initializing...
Nov/27/2017 23:05:41 ovpn,info cdp-test: connecting...
Nov/27/2017 23:05:41 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:05:41 ovpn,info cdp-test: disconnected
Nov/27/2017 23:05:44 lte,async lte1: rcvd OK
Nov/27/2017 23:05:44 lte,async lte1: sent AT+CMEE=1
Nov/27/2017 23:05:44 lte,async lte1: sent AT+CREG=2
Nov/27/2017 23:05:44 lte,async lte1: sent AT+CGREG=2
Nov/27/2017 23:05:44 lte,async lte1: sent AT+CEREG=2
Nov/27/2017 23:05:44 lte,async lte1: sent AT+CGEREP=2,0
Nov/27/2017 23:05:44 lte,async lte1: sent AT+CMGF=0
Nov/27/2017 23:05:44 lte,async lte1: sent AT+CNMI=1,1,0,1,0
Nov/27/2017 23:05:44 lte,async lte1: sent AT+EEMOPT=1
Nov/27/2017 23:05:44 lte,async lte1: sent AT*MRD_SN?
Nov/27/2017 23:05:45 lte,async lte1: rcvd *MRD_SN:723C031F1162
Nov/27/2017 23:05:45 lte,debug lte serial: *MRD_SN:723C031F1162
Nov/27/2017 23:05:45 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 23:05:45 lte,async lte1: rcvd OK
Nov/27/2017 23:05:45 lte,async lte1: sent AT*CGDFLT=0,"IP","drei.at",,,,,,,,,,,,,,,,,,1
Nov/27/2017 23:05:45 lte,async lte1: sent AT+CPIN?
Nov/27/2017 23:05:45 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 23:05:48 lte,async lte1: sent AT+CPMS="SM","SM","SM"
Nov/27/2017 23:05:48 lte,async lte1: rcvd +CPMS: 0,20,0,20,0,0
Nov/27/2017 23:05:48 lte,async lte1: sent AT+CFUN?
Nov/27/2017 23:05:48 lte,async lte1: rcvd +CFUN: 4
Nov/27/2017 23:05:48 lte,async lte1: sent AT+CNUM
Nov/27/2017 23:05:48 lte,async lte1: sent AT+CIMI
Nov/27/2017 23:05:49 lte,async lte1: rcvd 232106928869593
Nov/27/2017 23:05:49 lte,async lte1: sent AT+CPIN?
Nov/27/2017 23:05:49 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 23:05:49 lte,async lte1: sent AT*BAND=15,79,147,480,589829,0,2,0
Nov/27/2017 23:05:49 lte,async lte1: rcvd OK
Nov/27/2017 23:05:50 lte,async lte1: sent AT+CFUN=1
Nov/27/2017 23:05:50 lte,async,event +CREG: 2
Nov/27/2017 23:05:50 lte,async,event +CEREG: 2
Nov/27/2017 23:05:50 lte,async lte1: rcvd OK
Nov/27/2017 23:05:50 lte,debug lte1: config ok
Nov/27/2017 23:05:51 ovpn,info cdp-test: initializing...
Nov/27/2017 23:05:51 ovpn,info cdp-test: connecting...
Nov/27/2017 23:05:51 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:05:51 ovpn,info cdp-test: disconnected
Nov/27/2017 23:05:51 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 23:05:51 lte,info lte1: registered, home
Nov/27/2017 23:05:51 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 23:05:51 lte,debug lte1: network access technology: Evolved 3G (LTE)
Nov/27/2017 23:05:51 lte,async,event +CGEV: EPS PDN ACT 5
Nov/27/2017 23:05:51 lte,async,event +NITZ: PLMN Long Name: 3 AT,
Nov/27/2017 23:05:51 lte,async,event +NITZ: PLMN Short Name: 3 AT,
Nov/27/2017 23:05:51 lte,async,event +NITZ: 17/11/27,22:06:13+4,0
Nov/27/2017 23:05:52 lte,async lte1: sent AT+CGDCONT?
Nov/27/2017 23:05:52 lte,async lte1: rcvd +CGDCONT: 5,"IP","drei.at.mnc010.mcc232.gprs","178.114.177.18",,,802110030100108106d55e4e118306d55e4e10000d04d55e4e11000d04d55e4e10,
Nov/27/2017 23:05:52 lte,async lte1: sent AT+CGCONTRDP=5
Nov/27/2017 23:05:52 lte,async lte1: rcvd +CGCONTRDP: 5,5,"drei.at.mnc010.mcc232.gprs","178.114.177.18","","","213.94.78.17","213.94.78.16","","","0","0"
Nov/27/2017 23:05:52 interface,info lte1 link up
Nov/27/2017 23:05:52 system,info item added
Nov/27/2017 23:06:01 ovpn,info cdp-test: initializing...
Nov/27/2017 23:06:01 ovpn,info cdp-test: connecting...
Nov/27/2017 23:06:05 ovpn,info cdp-test: using encoding - AES-256-CBC/SHA1
Nov/27/2017 23:06:05 ovpn,info cdp-test: connected
Nov/27/2017 23:06:24 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 23:06:24 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 23:07:09 system,info cloud change time Nov/27/2017-23:06:48 => Nov/27/2017-23:07:09
Nov/27/2017 23:08:14 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 23:08:14 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 23:10:05 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 23:10:05 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 23:11:45 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 23:11:45 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 23:14:26 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 23:14:26 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 23:17:55 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 23:17:55 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 23:18:48 watchdog,error,critical watchdog cannot ping address 8.8.8.8, rebooting
Nov/27/2017 23:18:48 ovpn,info cdp-test: terminating... - system is going to shutdown
Nov/27/2017 23:18:49 ovpn,info cdp-test: disconnected
Nov/27/2017 23:18:53 system,error,critical router was rebooted without proper shutdown by watchdog timer
Nov/27/2017 23:18:55 ovpn,info cdp-test: initializing...
Nov/27/2017 23:18:55 ovpn,info cdp-test: connecting...
Nov/27/2017 23:18:55 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:18:55 ovpn,info cdp-test: disconnected
Nov/27/2017 23:18:56 ovpn,info cdp-test: initializing...
Nov/27/2017 23:18:56 ovpn,info cdp-test: connecting...
Nov/27/2017 23:18:56 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:18:56 ovpn,info cdp-test: disconnected
Nov/27/2017 23:18:58 ovpn,info cdp-test: initializing...
Nov/27/2017 23:18:58 ovpn,info cdp-test: connecting...
Nov/27/2017 23:18:58 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:18:58 ovpn,info cdp-test: disconnected
Nov/27/2017 23:19:01 ovpn,info cdp-test: initializing...
Nov/27/2017 23:19:01 ovpn,info cdp-test: connecting...
Nov/27/2017 23:19:01 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:19:01 ovpn,info cdp-test: disconnected
Nov/27/2017 23:19:03 interface,info ether1 link up (speed 100M, full duplex)
Nov/27/2017 23:19:08 ovpn,info cdp-test: initializing...
Nov/27/2017 23:19:08 ovpn,info cdp-test: connecting...
Nov/27/2017 23:19:08 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:19:08 ovpn,info cdp-test: disconnected
Nov/27/2017 23:19:08 lte,async lte1: sent AT E0 V1
Nov/27/2017 23:19:08 lte,async lte1: rcvd OK
Nov/27/2017 23:19:08 lte,async lte1: sent AT+CGMI
Nov/27/2017 23:19:08 lte,async lte1: rcvd +CGMI: "MikroTik"
Nov/27/2017 23:19:08 lte,async lte1: sent AT+CGMM
Nov/27/2017 23:19:08 lte,async lte1: rcvd +CGMM: "R11e-LTE"
Nov/27/2017 23:19:08 lte,async lte1: sent AT+CGMR
Nov/27/2017 23:19:08 lte,async lte1: rcvd +CGMR: "MikroTik_CP_2.160.000_v001"
Nov/27/2017 23:19:08 lte,async lte1: sent AT+CGSN
Nov/27/2017 23:19:08 lte,async lte1: rcvd +CGSN: 356159060372558
Nov/27/2017 23:19:08 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 23:19:09 lte,async,event ^SRVST: 2
Nov/27/2017 23:19:09 lte,async,event +CREG: 1
Nov/27/2017 23:19:09 lte,async,event +CGREG: 0
Nov/27/2017 23:19:09 lte,async,event +CGEV: ME DETACH
Nov/27/2017 23:19:10 lte,async,event ^SRVST: 0
Nov/27/2017 23:19:10 lte,async,event +CREG: 0
Nov/27/2017 23:19:16 lte,async lte1: rcvd OK
Nov/27/2017 23:19:16 lte,async lte1: sent AT+CMEE=1
Nov/27/2017 23:19:16 lte,async lte1: sent AT+CREG=2
Nov/27/2017 23:19:16 lte,async lte1: sent AT+CGREG=2
Nov/27/2017 23:19:16 lte,async lte1: sent AT+CEREG=2
Nov/27/2017 23:19:16 lte,async lte1: sent AT+CGEREP=2,0
Nov/27/2017 23:19:16 lte,async lte1: sent AT+CMGF=0
Nov/27/2017 23:19:16 lte,async lte1: sent AT+CNMI=1,1,0,1,0
Nov/27/2017 23:19:16 lte,async lte1: sent AT+EEMOPT=1
Nov/27/2017 23:19:16 lte,async lte1: sent AT*MRD_SN?
Nov/27/2017 23:19:17 lte,async lte1: rcvd *MRD_SN:723C031F1162
Nov/27/2017 23:19:17 lte,debug lte serial: *MRD_SN:723C031F1162
Nov/27/2017 23:19:17 lte,async lte1: sent AT+CFUN=4
Nov/27/2017 23:19:17 lte,async lte1: rcvd OK
Nov/27/2017 23:19:17 lte,async lte1: sent AT*CGDFLT=0,"IP","drei.at",,,,,,,,,,,,,,,,,,1
Nov/27/2017 23:19:17 lte,async lte1: sent AT+CPIN?
Nov/27/2017 23:19:17 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 23:19:18 ovpn,info cdp-test: initializing...
Nov/27/2017 23:19:18 ovpn,info cdp-test: connecting...
Nov/27/2017 23:19:18 ovpn,info cdp-test: terminating... - could not connect
Nov/27/2017 23:19:18 ovpn,info cdp-test: disconnected
Nov/27/2017 23:19:20 lte,async lte1: sent AT+CPMS="SM","SM","SM"
Nov/27/2017 23:19:20 lte,async lte1: rcvd +CPMS: 0,20,0,20,0,0
Nov/27/2017 23:19:20 lte,async lte1: sent AT+CFUN?
Nov/27/2017 23:19:20 lte,async lte1: rcvd +CFUN: 4
Nov/27/2017 23:19:20 lte,async lte1: sent AT+CNUM
Nov/27/2017 23:19:20 lte,async lte1: sent AT+CIMI
Nov/27/2017 23:19:21 lte,async lte1: rcvd 232106928869593
Nov/27/2017 23:19:21 lte,async lte1: sent AT+CPIN?
Nov/27/2017 23:19:21 lte,async lte1: rcvd +CPIN: READY
Nov/27/2017 23:19:21 lte,async lte1: sent AT*BAND=15,79,147,480,589829,0,2,0
Nov/27/2017 23:19:21 lte,async lte1: rcvd OK
Nov/27/2017 23:19:22 lte,async lte1: sent AT+CFUN=1
Nov/27/2017 23:19:22 lte,async,event +CREG: 2
Nov/27/2017 23:19:22 lte,async,event +CEREG: 2
Nov/27/2017 23:19:22 lte,async lte1: rcvd OK
Nov/27/2017 23:19:22 lte,debug lte1: config ok
Nov/27/2017 23:19:23 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 23:19:23 lte,info lte1: registered, home
Nov/27/2017 23:19:23 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 23:19:23 lte,debug lte1: network access technology: Evolved 3G (LTE)
Nov/27/2017 23:19:23 lte,async,event +CGEV: EPS PDN ACT 5
Nov/27/2017 23:19:23 lte,async,event +NITZ: PLMN Long Name: 3 AT,
Nov/27/2017 23:19:23 lte,async,event +NITZ: PLMN Short Name: 3 AT,
Nov/27/2017 23:19:23 lte,async,event +NITZ: 17/11/27,22:20:32+4,0
Nov/27/2017 23:19:24 lte,async lte1: sent AT+CGDCONT?
Nov/27/2017 23:19:24 lte,async lte1: rcvd +CGDCONT: 5,"IP","drei.at.mnc010.mcc232.gprs","178.114.180.88",,,802110030100108106d55e4e118306d55e4e10000d04d55e4e11000d04d55e4e10,
Nov/27/2017 23:19:24 lte,async lte1: sent AT+CGCONTRDP=5
Nov/27/2017 23:19:24 lte,async lte1: rcvd +CGCONTRDP: 5,5,"drei.at.mnc010.mcc232.gprs","178.114.180.88","","","213.94.78.17","213.94.78.16","","","0","0"
Nov/27/2017 23:19:24 interface,info lte1 link up
Nov/27/2017 23:19:24 system,info item added
Nov/27/2017 23:19:28 ovpn,info cdp-test: initializing...
Nov/27/2017 23:19:28 ovpn,info cdp-test: connecting...
Nov/27/2017 23:19:32 ovpn,info cdp-test: using encoding - AES-256-CBC/SHA1
Nov/27/2017 23:19:32 ovpn,info cdp-test: connected
Nov/27/2017 23:23:23 system,info cloud change time Nov/27/2017-23:22:14 => Nov/27/2017-23:23:23
Nov/27/2017 23:25:26 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 23:25:26 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/27/2017 23:26:35 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/27/2017 23:26:35 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/27/2017 23:54:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/27/2017 23:54:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 00:01:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 00:01:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 00:16:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 00:16:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 01:01:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 01:01:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 02:01:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 02:01:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 03:00:45 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 03:00:45 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 04:01:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 04:01:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 05:01:05 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 05:01:05 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 06:01:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 06:01:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 06:17:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 06:17:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 06:29:46 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 06:29:46 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 06:31:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 06:31:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 07:01:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 07:01:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 07:14:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 07:14:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 07:15:46 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 07:15:46 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 07:22:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 07:22:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 07:37:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 07:37:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 07:40:25 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 07:40:25 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 07:45:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 07:45:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 07:54:55 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 07:54:55 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 08:01:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 08:01:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 08:11:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 08:11:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 08:32:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 08:32:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 08:34:05 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 08:34:05 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 08:55:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 08:55:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 08:57:45 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 08:57:45 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 09:01:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 09:01:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 09:16:25 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 09:16:25 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 09:18:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 09:18:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 09:21:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 09:21:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 09:31:56 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 09:31:56 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 09:33:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 09:33:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 09:34:26 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 09:34:26 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 09:35:35 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 09:35:35 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 09:36:56 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 09:36:56 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 09:55:55 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 09:55:55 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 10:00:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 10:00:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 10:01:45 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 10:01:45 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 10:06:05 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 10:06:05 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 10:08:25 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 10:08:25 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 10:14:26 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 10:14:26 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 10:15:35 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 10:15:35 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 10:23:36 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 10:23:36 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 10:30:05 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 10:30:05 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 10:33:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 10:33:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 10:34:35 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 10:34:35 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 10:36:56 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 10:36:56 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 10:42:45 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 10:42:45 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 10:44:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 10:44:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 10:45:25 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 10:45:25 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 10:51:46 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 10:51:46 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 10:53:45 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 10:53:45 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 10:56:56 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 10:56:56 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 11:01:05 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 11:01:05 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 11:18:06 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 11:18:06 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 11:21:15 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 11:21:15 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 11:25:26 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 11:25:26 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 11:28:05 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 11:28:05 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 11:29:16 lte,async,event +CREG: 1, 27f1, 192be0a, 7
Nov/28/2017 11:29:16 lte,async,event +CEREG: 1,"27f1","0192be0a",7
Nov/28/2017 11:30:35 lte,async,event +CREG: 1, 27f1, 192be64, 7
Nov/28/2017 11:30:35 lte,async,event +CEREG: 1,"27f1","0192be64",7
Nov/28/2017 11:36:29 system,info,account user admin logged in from 10.100.1.101 via winbox
it looks like more problem with the LTE connection as there is no indication that the data connection is closed. It looks like the connection is switching all the time betwen some LTE Towers. You can try to leave the ping running and check when it stops working.
What is the signal of the LTE connection?
I had a simple USB dongle right in the same spot until I got the WAP LTE to replace it. Also I temporarily switched back to the dongle to crosscheck and the problems only arise with the WAP LTE. Therefore I can’t really blame the network.
Today I even swapped the SIM card with no effekt.
Is it possible I just received a faulty unit?
for the signal part:
[admin@MikroTik] > /interface lte info lte1
         pin-status: no password required
      functionality: full
       manufacturer: "MikroTik"
              model: "R11e-LTE"
           revision: "MikroTik_CP_2.160.000_v001"
   current-operator: 23205
     current-cellid: 26394212
  access-technology: Evolved 3G (LTE)
     session-uptime: 34m18s
               imei: xxxxxxxxxxxxxxxxxxx
             earfcn: 397 (band 1, bandwidth 10Mhz, cqi 13)
               rsrp: -79dBm
               rsrq: -9dB
               sinr: 16dB
Do you have any updates on this?
It seems I have quite similar problems. My unit also works fine after reboot for some minutes and then it just looses LTE-connection. Previously I had another LTE-router installed, which had other issues but LTE-Connection was stable.
At the moment I use two other WAP LTE on other locations and they had’nt this issue so far. I also updated today to the newest Firmware without any change.
So I think my next step will be a hardware replacement to check if I just got a broken unit there.
