I wanted to know if the Mikrotik WAP lte Kit with included modem and LTE / 4G data SIM supports SMS. If I go to “tools> sms”, I find “Unknown” in the port and also finds nothing from the terminal with “port print”.
Yes, it does support sending and receiving (/tool sms receive-enabled=yes). The port is what you named the interface in /interface. Make shure it’s enabled.
You can use this feature to remotely trigger your device to book a daily datarate via SMS and go online by sending a SMS to the device. That’s cool.
Thanks to everyone for the support, I followed the guide and I updated the model to the V008 version but I still do not see any port under “tools> sms”. The “/ print port” command returns:
[admin@Router_Vittoria] > /port print
Flags: I - inactive
# DEVICE NAME CHANNELS USED-BY BAUD-RATE
For the rest, the modem and the connection work well
Hello!
Is there any progress on that topic, as I am having the exactly same issue - lte modem is not listed under /port print and I cannot send SMS?
I updated the RouterOS (6.42.4), board firmware and modem firmware (MikroTik_CP_2.160.000_v008).
This is a huge issue for me, as I’m using a prepaid service that can be refilled only by sending a SMS.
I finally received feedback from the support!
I updated to v6.43rc56 and this seems to fix the functionality to send and receive through the console! The Winbox v3,16 tool still doesn’t work (maybe the new version), but that’s not so important.
