Hello guys, it’s just me or the new wap lte have serious issues regarding 4g speed? In the same spot my 4g huawey usb stick connected to an rb951 has way more internet speed than the wap lte.
This is not normal, the wap antennas are huge compared with the ones on the usb stick and even so the speed drop is more than 60% on the download.
Is anyone having this problem also?
I’m gonna do some more tests but this is not promissing… I was expecting way more of this routerboard…
what speed you are getting from the wap lte and from the usb modem? What LTE category your USB modem supports?
Try to compare which band each unit uses as maybe the wap lte connected to different bands or cell tower.
Got similar question here, with ZTE MF286 modem that provider gives on same spot i get 42mbit, with wap LTE i get 22mbit.
Also tried putting sim in old 3 years old Samsung Galaxy S5 it achieves 38mbit speed on same spot.(LTE).
The usb Modem is a Huawei E3276s-150 with the following specs:
4G LTE Band 1/3/7/8/20 FDD (DD800/900/1800/2100/2600MHz)
3G UMTS 900/AWS/1900/2100MHz
GSM 850/900/1800/1900MHz
The diference in speed at this moment, in the same spot, is Mtik+USB 13,5Mbps of download and Mtik wAP LTE 6.5Mbps (I had to turn the device around to obtain the maximum download speed).
On the wAP I selected only the same band that the usb modem support and even so, the download speed is too slow.
This is not compreensible, the wAP antennas are twice the size of the usb modem, and the antennas on the usb are half of the modem size…
I even tested with the latest RouterOs RC Firmware to see if there was some improve, but nothing…
Regarding the Tower, there is only one LTE tower from NOS (Orange) in this zone, so they are both connecting to it.
Anyone found any solution for this? If there is any solution…
So far I think this is a problem with the pci Modem itself,. not the routerboard…
ZTE MF286 is a CAT6 LTE modem with CA, WAP LTE kit is only CAT4 without CA - that is why the speed is lower as the ZTE most likely were using CA with multiple bands/frequencies. Note sure which Samsung S5 you have but it also looks like has CAT6 with CA.
Than this router is not an option for me, i mean i dont expect more than 100mbit, but if cheaper router achieves double speeds, i have nothing more to add here.
Here are the results, attention that this SIM card down/up is locked to 30Mbps/3Mbps by the carrier (NOS aka Orange Portugal)
RB+Huawei LTE E3276s-150 USB:
wAP LTE Kit:
This is NOT what I was expecting… So dissapointed right now…
I cannot send this to a client knowing it’s worst than the RB+USB solution…
I hope you guys find out that this is only a bug in the firmware, otherwise this is a major flop
Here is the speedtest from a local cellular provider also running on Band3.
Signal readings:
earfcn: 1300 (band 3, bandwidth 20Mhz, cqi 13)
rsrp: -76dBm
rsrq: -10dB
sinr: 20dB
It could be related to the signal as your RSRP is very low. You could try to adjust the board location to get a better signal and better SINR readings. Try to check if both modems were using the same cell tower id. Maybe you could try to lock the modem to a different band which is working better there?
I’ve compared SXT-LTE and wAP LTE, and seems to me, the SXT-LTE is much faster (if supported band is available).
At home, SXT-LTE could do ~80/35mbps almost any time, but wAP LTE only the half (~35/18mbps) on band3, 20MHz.
Also, it would be really helpful, if scan would display not only one provider with one technology, and offer possibility of blacklisting a congested cell.
(i don’t know, if data-roaming is supported between cells on request of load balancer)
Yes, i would do.
But it needs to connect again. Sadly if i do changes on LTE interface (like disable bands) the modem don’t connect to provider even with waiting long time (like 5-10 minutes).
Need to reboot device…
Of course, all measurement done with cable. Now disabled the wifi. Do you think, it has not enough power to drive both wireless modules?
Try with the Release-Candidate firmware, it improves a little bit the lte interface on the wAP.
Another thing that I tried was rotating the antenas, puting the inside face facing outside and vice-versa, and i don’t know why, in one carrier the signal got better, but in the other got worst! Still trying possibilities!!
Not related to power, but interference between wireless and LTE modem, I did often get noticeable better speeds on other manufacturer LTE routers when disabling on board wifi.
I’m from Portugal, all the LTE bands used in here are supposedly compatible, one thing that I noticed is that most of the times my upload is bigger than my download, it also happens to you?
