I have to configure a wAP and I have some problems with APNs.
If I use the APN of the SIM vendor everything works fine, but when I put ISP reseller’s APN, username and password LTE interface doesn’t connect.
I have also noticed that I can assign an IP to LTE with DHCP-Client, I can’t select the interface, and the SIM has got a static IP.
What can I do?
No one?
You are not the only one.
I too have problems with APN and no solution.
Tried with the latest RC 6.41rc38 but its even worse. There is no user/pass for LTE interface.
For the v6.41RC versions the username/password is moved to the ‘/interface lte apn’ menu (currenly no Winbox support - only Console support).
Please enable the lte debug logging and email to support the output file after you see it fails:
/system logging add topics=lte,!raw
Before the output file I want to say what have I done.
v. 6.40.4.
Default APN of mobile carrier in LTE and everything works.
Custom APN brought from mobile carrier, username e password taken from APN server, pap authentication and it doesn’t work.
A thing that I’m not able to do is a DHCP client on LTE interface with user, password and static IP for LTE.
I’ve also tried passthrough-interface on bridge interface, but nothing changes.
I can still try to do a DHCP-Client on bridge with passthrough-interface.
We will try to fix the username/password functionality in one of the next RC versions.
IP address is assigned automatically from the LTE interface from the Cellular Provider.
Yes but it works with the default APN of the SIM, but with the APN of the ISP, brought from SIM card vendor, the LTE doesn’t register and the APN doesn’t receive login requests.
uldis:
Redmor:
v. 6.40.4.
I can still try to do a DHCP-Client on bridge with passthrough-interface.We will try to fix the username/password functionality in one of the next RC versions.
IP address is assigned automatically from the LTE interface from the Cellular Provider.Yes but it works with the default APN of the SIM, but with the APN of the ISP, brought from SIM card vendor, the LTE doesn’t register and the APN doesn’t receive login requests.
Could you tell us what is the difference between both SIM cards? Only the APN is different?
Redmor:
uldis:
Redmor:
v. 6.40.4.
With the working APN LTE needs only APN, with the not working one I also need to specify username, password and pap authentication.
I’m using two SIM card, but each one has got two APNs, one of the mobile carrier of the SIM (Omnitel SIM, omnitel.it APN for example), and the other one is an APN that my ISP brought from mobile carrier (Omnitel SIM, ISP.omnitel.it APN for example, and this one requires user and password).
The difference between wAP and other Mikrotik RB LATE is that I need to set a DHCP-Client on LTE interface to make everything work, but with wAP I can’t.
I saw the passthrough-interface option, but it’s not exactly my case because I need an IP on LTE and DHCP on wlan. I don’t know why it works, the APN doesn’t get login requests. It works with other Mikrotik products and also other non-Mikrotik LTE routers.
With wAP for now I can only use the default APN of the SIM, not the others.
Tell me what you need and I’ll post you logs or even support file.
I’ve also tried rc44, in changelog there’s “Added DHCP-Client for mobile clients that need it” and I thought it was the DHCP-Client thing I need to connect, but that’s not it.
I’m writing following the LTE guide posted on Mikrotik Wiki, and there’s the command for a DHCP-Client on LTE, but that interface isn’t eligible for DHCP-Client, bridges and so on.
Hi everyone - SAME ISSUE
I NEED the different APN, I bought this wAP LTE Kit and waited for 1.5 Months and paid for internet access in that time - and now this APN thing doesn’t work - I’m getting angry here and will think about ever recommending MikroTik to anyone!
Also the username and password PAP authentication needs to work…
Can you please fix this?! It worked fine on SXT LTE, but that one has no Passthrough option …
Please contact support@mikrotik.com we will provide you a test firmware which can be used with the new RC version which will support correctly the authentication.
Has this issue been resolved? Did the Test Firmware help?
Partially yes, with the new LTE firmware and RC one of my two SIMs connected with my APN.
Hello All and support team
I have the same issue whit wap lte kit
work fine whit all mobile operator whitout authentication but non work with authentication PAP or CHAP .
+CME ERROR 100 (unknow error)
I have tested the rb wap lte kit at november 2017 whit same issue.
I wait patient the new os and firmware that patch this bug, but after 5 months whit last 6.42.1 not work again.
is possible fix the bug ?
how can i help you ?
if you need a test sim I can send it
I want use this mikrotik device , but need lte whit authentication , please resolve this bug
[admin@MikroTik] > /interface lte info lte1
pin-status: no password required
functionality: full
manufacturer: “MikroTik”
model: “R11e-LTE”
revision: “MikroTik_CP_2.160.000_v001”
current-operator: +CME ERROR: 100
lac: 61510
current-cellid: 98963224
access-technology: 3G HSDPS & HSUPA
imei: 356159060378399
earfcn: 10638 (DL freq 2127.6Mhz)
rssi: -113dBm
functionality: full
model: “R11e-LTE”
current-operator: 22201
lac: 61510
imsi: 222070190855496
rssi: -109dBm
[admin@MikroTik] >
00:05:21 echo: lte,critical lte1 SMS storage set
[admin@MikroTik] >
lte debug log output
apr/27 00:21:52 lte,async lte1: sent AT+CIMI
apr/27 00:21:54 lte,async lte1: rcvd 222070190855496
apr/27 00:21:54 lte,async lte1: sent AT+CFUN?
apr/27 00:21:54 lte,async lte1: rcvd +CFUN: 4
apr/27 00:21:54 lte,async lte1: sent AT+CNUM
apr/27 00:21:54 lte,async lte1: sent AT+CIMI
apr/27 00:21:54 lte,async lte1: sent AT+CPIN?
apr/27 00:21:54 lte,async lte1: rcvd +CPIN: READY
apr/27 00:21:54 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:21:54 lte,async lte1: rcvd OK
apr/27 00:21:55 lte,async lte1: sent AT+CFUN=1
apr/27 00:21:55 lte,async,event +CREG: 2
apr/27 00:21:55 lte,async,event +CGREG: 2
apr/27 00:21:55 lte,async lte1: rcvd OK
apr/27 00:21:55 lte,debug lte1: config ok
apr/27 00:22:00 lte,async,event +CREG: 11, f046, 5e646e2, 2
apr/27 00:22:00 lte,async,event +CGREG: 11,“f046”,“05e646e2”,6,0
apr/27 00:22:02 lte,async,event +CREG: 5, f046, 5e646e2, 2
apr/27 00:22:02 lte,info lte1: registered, roaming
apr/27 00:22:02 lte,async,event +CGREG: 0
apr/27 00:22:02 lte,async,event +CGREG: 5,“f046”,“05e646e2”,6,0
apr/27 00:22:02 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:22:03 lte,async,event +CREG: 5, f046, 5e646e2, 6
apr/27 00:22:04 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:22:04 lte,async lte1: rcvd OK
apr/27 00:22:04 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:22:05 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:22:05 lte,async lte1: sent AT+CFUN=0
apr/27 00:22:06 lte,async,event +CREG: 5
apr/27 00:22:06 lte,info lte1: registered, roaming
apr/27 00:22:06 lte,async,event +CGREG: 0
apr/27 00:22:06 lte,async,event +CGEV: ME DETACH
apr/27 00:22:06 lte,async,event ^SIMST: 0
apr/27 00:22:06 lte,async,event +MMSG: 1, 0
apr/27 00:22:06 lte,async,event +CPIN: SIM REMOVED
apr/27 00:22:06 lte,async,event ^CARDMODE: 255
apr/27 00:22:06 lte,async,event ^SIMST: 255,0
apr/27 00:22:07 lte,async,event +CREG: 0
apr/27 00:22:07 lte,info lte1: not registred, state: 0
apr/27 00:22:13 lte,async lte1: rcvd OK
apr/27 00:22:13 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:22:13 lte,async lte1: sent ATMRD_SN?
apr/27 00:22:13 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:22:13 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:22:13 lte,async lte1: sent AT+CFUN=4
apr/27 00:22:18 lte,async,event ^SIMST: 0
apr/27 00:22:18 lte,async lte1: rcvd OK
apr/27 00:22:18 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:22:18 lte,async lte1: sent AT+CPIN?
apr/27 00:22:18 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:22:19 lte,async,event +CPIN: READY
apr/27 00:22:19 lte,async,event ^SIMST: 1
apr/27 00:22:20 lte,async lte1: sent AT+CPIN?
apr/27 00:22:20 lte,async lte1: rcvd +CPIN: READY
apr/27 00:22:21 lte,async,event +MMSG: 2, 0
apr/27 00:22:21 lte,async,event +MMSG: 3, 0
apr/27 00:22:21 lte,async,event +MMSG: 0, 0
apr/27 00:22:21 lte,async,event +MPBK: 1
apr/27 00:22:24 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:22:24 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:22:24 lte,async lte1: sent AT+CFUN?
apr/27 00:22:24 lte,async lte1: rcvd +CFUN: 4
apr/27 00:22:24 lte,async lte1: sent AT+CNUM
apr/27 00:22:24 lte,async lte1: sent AT+CIMI
apr/27 00:22:26 lte,async lte1: rcvd 222070190855496
apr/27 00:22:26 lte,async lte1: sent AT+CPIN?
apr/27 00:22:26 lte,async lte1: rcvd +CPIN: READY
apr/27 00:22:26 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:22:26 lte,async lte1: rcvd OK
apr/27 00:22:27 lte,async lte1: sent AT+CFUN=1
apr/27 00:22:27 lte,async,event +CREG: 2
apr/27 00:22:27 lte,async,event +CGREG: 2
apr/27 00:22:27 lte,async lte1: rcvd OK
apr/27 00:22:27 lte,debug lte1: config ok
apr/27 00:22:31 lte,async,event +CREG: 11, f046, 5e646e2, 2
apr/27 00:22:31 lte,async,event +CGREG: 11,“f046”,“05e646e2”,6,0
apr/27 00:22:33 lte,async,event +CGREG: 5,“f046”,“05e646e2”,6,0
apr/27 00:22:33 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:22:33 lte,info lte1: registered, roaming
apr/27 00:22:33 lte,async,event +CREG: 5, f046, 5e646e2, 2
apr/27 00:22:34 lte,async,event +CREG: 5, f046, 5e646e2, 6
apr/27 00:22:35 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:22:35 lte,async lte1: rcvd OK
apr/27 00:22:35 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:22:36 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:22:36 lte,async lte1: sent AT+CFUN=0
apr/27 00:22:36 lte,async,event +CREG: 5
apr/27 00:22:36 lte,info lte1: registered, roaming
apr/27 00:22:36 lte,async,event +CGREG: 0
apr/27 00:22:36 lte,async,event +CGEV: ME DETACH
apr/27 00:22:36 lte,async,event ^SIMST: 0
apr/27 00:22:36 lte,async,event +MMSG: 1, 0
apr/27 00:22:36 lte,async,event +CPIN: SIM REMOVED
apr/27 00:22:36 lte,async,event ^CARDMODE: 255
apr/27 00:22:36 lte,async,event ^SIMST: 255,0
apr/27 00:22:37 lte,async,event +CREG: 0
apr/27 00:22:37 lte,info lte1: not registred, state: 0
apr/27 00:22:43 lte,async lte1: rcvd OK
apr/27 00:22:43 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:22:43 lte,async lte1: sent ATMRD_SN?
apr/27 00:22:44 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:22:44 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:22:44 lte,async lte1: sent AT+CFUN=4
apr/27 00:22:48 lte,async lte1: rcvd OK
apr/27 00:22:48 lte,async,event ^SIMST: 0
apr/27 00:22:48 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:22:48 lte,async lte1: sent AT+CPIN?
apr/27 00:22:48 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:22:50 lte,async,event +CPIN: READY
apr/27 00:22:50 lte,async,event ^SIMST: 1
apr/27 00:22:50 lte,async lte1: sent AT+CPIN?
apr/27 00:22:51 lte,async lte1: rcvd +CPIN: READY
apr/27 00:22:51 lte,async,event +MMSG: 2, 0
apr/27 00:22:52 lte,async,event +MMSG: 3, 0
apr/27 00:22:52 lte,async,event +MMSG: 0, 0
apr/27 00:22:52 lte,async,event +MPBK: 1
apr/27 00:22:55 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:22:55 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:22:55 lte,async lte1: sent AT+CFUN?
apr/27 00:22:55 lte,async lte1: rcvd +CFUN: 4
apr/27 00:22:55 lte,async lte1: sent AT+CNUM
apr/27 00:22:55 lte,async lte1: sent AT+CIMI
apr/27 00:22:56 lte,async lte1: rcvd 222070190855496
apr/27 00:22:56 lte,async lte1: sent AT+CPIN?
apr/27 00:22:56 lte,async lte1: rcvd +CPIN: READY
apr/27 00:22:56 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:22:56 lte,async lte1: rcvd OK
apr/27 00:22:57 lte,async lte1: sent AT+CFUN=1
apr/27 00:22:57 lte,async,event +CREG: 2
apr/27 00:22:57 lte,async,event +CGREG: 2
apr/27 00:22:57 lte,async lte1: rcvd OK
apr/27 00:22:57 lte,debug lte1: config ok
apr/27 00:23:02 lte,async,event +CREG: 11, f046, 5e60f18, 2
apr/27 00:23:02 lte,async,event +CGREG: 11,“f046”,“05e60f18”,6,0
apr/27 00:23:04 lte,async,event +CGREG: 5,“f046”,“05e60f18”,6,0
apr/27 00:23:04 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:23:04 lte,info lte1: registered, roaming
apr/27 00:23:04 lte,async,event +CREG: 5, f046, 5e60f18, 2
apr/27 00:23:05 lte,async,event +CREG: 5, f046, 5e60f18, 6
apr/27 00:23:06 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:23:06 lte,async lte1: rcvd OK
apr/27 00:23:06 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:23:07 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:23:07 lte,async lte1: sent AT+CFUN=0
apr/27 00:23:07 lte,async lte1: rcvd OK
apr/27 00:23:08 lte,async,event +CREG: 5
apr/27 00:23:08 lte,info lte1: registered, roaming
apr/27 00:23:08 lte,async,event +CGREG: 0
apr/27 00:23:08 lte,async,event +CGEV: ME DETACH
apr/27 00:23:08 lte,async,event ^SIMST: 0
apr/27 00:23:08 lte,async,event +MMSG: 1, 0
apr/27 00:23:08 lte,async,event +CPIN: SIM REMOVED
apr/27 00:23:08 lte,async,event ^CARDMODE: 255
apr/27 00:23:08 lte,async,event ^SIMST: 255,0
apr/27 00:23:09 lte,async,event +CREG: 0
apr/27 00:23:09 lte,info lte1: not registred, state: 0
apr/27 00:23:15 lte,async lte1: rcvd OK
apr/27 00:23:15 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:23:15 lte,async lte1: sent ATMRD_SN?
apr/27 00:23:15 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:23:15 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:23:15 lte,async lte1: sent AT+CFUN=4
apr/27 00:23:19 lte,async lte1: rcvd OK
apr/27 00:23:19 lte,async,event ^SIMST: 0
apr/27 00:23:19 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:23:19 lte,async lte1: sent AT+CPIN?
apr/27 00:23:19 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:23:20 lte,async,event +CPIN: READY
apr/27 00:23:20 lte,async,event ^SIMST: 1
apr/27 00:23:21 lte,async lte1: sent AT+CPIN?
apr/27 00:23:21 lte,async lte1: rcvd +CPIN: READY
apr/27 00:23:21 lte,async,event +MMSG: 2, 0
apr/27 00:23:22 lte,async,event +MMSG: 3, 0
apr/27 00:23:22 lte,async,event +MMSG: 0, 0
apr/27 00:23:22 lte,async,event +MPBK: 1
apr/27 00:23:25 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:23:25 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:23:25 lte,async lte1: sent AT+CFUN?
apr/27 00:23:25 lte,async lte1: rcvd +CFUN: 4
apr/27 00:23:25 lte,async lte1: sent AT+CNUM
apr/27 00:23:25 lte,async lte1: sent AT+CIMI
apr/27 00:23:26 lte,async lte1: rcvd 222070190855496
apr/27 00:23:26 lte,async lte1: sent AT+CFUN?
apr/27 00:23:26 lte,async lte1: rcvd +CFUN: 4
apr/27 00:23:26 lte,async lte1: sent AT+CNUM
apr/27 00:23:26 lte,async lte1: sent AT+CIMI
apr/27 00:23:26 lte,async lte1: sent AT+CPIN?
apr/27 00:23:26 lte,async lte1: rcvd +CPIN: READY
apr/27 00:23:26 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:23:26 lte,async lte1: rcvd OK
apr/27 00:23:27 lte,async lte1: sent AT+CFUN=1
apr/27 00:23:27 lte,async,event +CREG: 2
apr/27 00:23:27 lte,async,event +CGREG: 2
apr/27 00:23:27 lte,async lte1: rcvd OK
apr/27 00:23:27 lte,debug lte1: config ok
apr/27 00:23:32 lte,async,event +CREG: 11, f046, 5e60f18, 2
apr/27 00:23:32 lte,async,event +CGREG: 11,“f046”,“05e60f18”,6,0
apr/27 00:23:34 lte,async,event +CGREG: 5,“f046”,“05e60f18”,6,0
apr/27 00:23:34 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:23:34 lte,info lte1: registered, roaming
apr/27 00:23:34 lte,async,event +CREG: 5, f046, 5e60f18, 2
apr/27 00:23:35 lte,async,event +CREG: 5, f046, 5e60f18, 6
apr/27 00:23:36 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:23:36 lte,async lte1: rcvd OK
apr/27 00:23:36 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:23:37 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:23:37 lte,async lte1: sent AT+CFUN=0
apr/27 00:23:38 lte,async,event +CREG: 5
apr/27 00:23:38 lte,info lte1: registered, roaming
apr/27 00:23:38 lte,async,event +CGREG: 0
apr/27 00:23:38 lte,async,event +CGEV: ME DETACH
apr/27 00:23:38 lte,async,event ^SIMST: 0
apr/27 00:23:38 lte,async,event +MMSG: 1, 0
apr/27 00:23:38 lte,async,event +CPIN: SIM REMOVED
apr/27 00:23:38 lte,async,event ^CARDMODE: 255
apr/27 00:23:38 lte,async,event ^SIMST: 255,0
apr/27 00:23:39 lte,async,event +CREG: 0
apr/27 00:23:39 lte,info lte1: not registred, state: 0
apr/27 00:23:45 lte,async lte1: rcvd OK
apr/27 00:23:45 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:23:45 lte,async lte1: sent ATMRD_SN?
apr/27 00:23:45 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:23:45 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:23:45 lte,async lte1: sent AT+CFUN=4
apr/27 00:23:50 lte,async lte1: rcvd OK
apr/27 00:23:50 lte,async,event ^SIMST: 0
apr/27 00:23:50 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:23:50 lte,async lte1: sent AT+CPIN?
apr/27 00:23:50 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:23:51 lte,async,event +CPIN: READY
apr/27 00:23:51 lte,async,event ^SIMST: 1
apr/27 00:23:52 lte,async lte1: sent AT+CPIN?
apr/27 00:23:53 lte,async lte1: rcvd +CPIN: READY
apr/27 00:23:53 lte,async,event +MMSG: 2, 0
apr/27 00:23:53 lte,async,event +MMSG: 3, 0
apr/27 00:23:53 lte,async,event +MMSG: 0, 0
apr/27 00:23:53 lte,async,event +MPBK: 1
apr/27 00:23:57 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:23:57 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:23:57 lte,async lte1: sent AT+CFUN?
apr/27 00:23:57 lte,async lte1: rcvd +CFUN: 4
apr/27 00:23:57 lte,async lte1: sent AT+CNUM
apr/27 00:23:57 lte,async lte1: sent AT+CIMI
apr/27 00:23:57 lte,async lte1: sent AT+CPIN?
apr/27 00:23:58 lte,async lte1: rcvd +CPIN: READY
apr/27 00:23:58 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:23:58 lte,async lte1: rcvd OK
apr/27 00:23:59 lte,async lte1: sent AT+CFUN=1
apr/27 00:23:59 lte,async,event +CREG: 2
apr/27 00:23:59 lte,async,event +CGREG: 2
apr/27 00:23:59 lte,async lte1: rcvd OK
apr/27 00:23:59 lte,debug lte1: config ok
apr/27 00:24:03 lte,async,event +CREG: 11, f046, 5e60f18, 2
apr/27 00:24:03 lte,async,event +CGREG: 11,“f046”,“05e60f18”,6,0
apr/27 00:24:05 lte,async,event +CGREG: 5,“f046”,“05e60f18”,6,0
apr/27 00:24:05 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:24:05 lte,info lte1: registered, roaming
apr/27 00:24:05 lte,async,event +CREG: 5, f046, 5e60f18, 2
apr/27 00:24:06 lte,async,event +CREG: 5, f046, 5e60f18, 6
apr/27 00:24:07 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:24:07 lte,async lte1: rcvd OK
apr/27 00:24:07 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:24:08 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:24:08 lte,async lte1: sent AT+CFUN=0
apr/27 00:24:08 lte,async,event +CREG: 5
apr/27 00:24:08 lte,info lte1: registered, roaming
apr/27 00:24:08 lte,async,event +CGREG: 0
apr/27 00:24:08 lte,async,event +CGEV: ME DETACH
apr/27 00:24:08 lte,async,event ^SIMST: 0
apr/27 00:24:08 lte,async,event +MMSG: 1, 0
apr/27 00:24:08 lte,async,event +CPIN: SIM REMOVED
apr/27 00:24:08 lte,async,event ^CARDMODE: 255
apr/27 00:24:08 lte,async,event ^SIMST: 255,0
apr/27 00:24:09 lte,async,event +CREG: 0
apr/27 00:24:09 lte,info lte1: not registred, state: 0
apr/27 00:24:15 lte,async lte1: rcvd OK
apr/27 00:24:15 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:24:15 lte,async lte1: sent ATMRD_SN?
apr/27 00:24:15 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:24:15 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:24:15 lte,async lte1: sent AT+CFUN=4
apr/27 00:24:20 lte,async lte1: rcvd OK
apr/27 00:24:20 lte,async,event ^SIMST: 0
apr/27 00:24:20 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:24:20 lte,async lte1: sent AT+CPIN?
apr/27 00:24:20 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:24:20 lte,async,event +CPIN: READY
apr/27 00:24:20 lte,async,event ^SIMST: 1
apr/27 00:24:22 lte,async lte1: sent AT+CPIN?
apr/27 00:24:22 lte,async lte1: rcvd +CPIN: READY
apr/27 00:24:22 lte,async,event +MMSG: 2, 0
apr/27 00:24:22 lte,async,event +MMSG: 3, 0
apr/27 00:24:22 lte,async,event +MMSG: 0, 0
apr/27 00:24:22 lte,async,event +MPBK: 1
apr/27 00:24:26 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:24:26 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:24:26 lte,async lte1: sent AT+CFUN?
apr/27 00:24:26 lte,async lte1: rcvd +CFUN: 4
apr/27 00:24:26 lte,async lte1: sent AT+CNUM
apr/27 00:24:26 lte,async lte1: sent AT+CIMI
apr/27 00:24:27 lte,async lte1: rcvd 222070190855496
apr/27 00:24:27 lte,async lte1: sent AT+CFUN?
apr/27 00:24:27 lte,async lte1: rcvd +CFUN: 4
apr/27 00:24:27 lte,async lte1: sent AT+CNUM
apr/27 00:24:27 lte,async lte1: sent AT+CIMI
apr/27 00:24:27 lte,async lte1: sent AT+CPIN?
apr/27 00:24:27 lte,async lte1: rcvd +CPIN: READY
apr/27 00:24:27 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:24:27 lte,async lte1: rcvd OK
apr/27 00:24:28 lte,async lte1: sent AT+CFUN=1
apr/27 00:24:28 lte,async,event +CREG: 2
apr/27 00:24:28 lte,async,event +CGREG: 2
apr/27 00:24:28 lte,async lte1: rcvd OK
apr/27 00:24:28 lte,debug lte1: config ok
apr/27 00:24:34 lte,async,event +CREG: 11, f046, 5e60f18, 2
apr/27 00:24:34 lte,async,event +CGREG: 11,“f046”,“05e60f18”,6,0
apr/27 00:24:38 lte,async,event +CGREG: 5,“f046”,“05e60f18”,6,0
apr/27 00:24:38 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:24:38 lte,info lte1: registered, roaming
apr/27 00:24:38 lte,async,event +CREG: 5, f046, 5e60f18, 2
apr/27 00:24:39 lte,async,event +CREG: 5, f046, 5e60f18, 6
apr/27 00:24:40 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:24:40 lte,async lte1: rcvd OK
apr/27 00:24:40 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:24:41 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:24:41 lte,async lte1: sent AT+CFUN=0
apr/27 00:24:41 lte,async lte1: rcvd OK
apr/27 00:24:41 lte,async,event +CREG: 5
apr/27 00:24:41 lte,info lte1: registered, roaming
apr/27 00:24:41 lte,async,event +CGREG: 0
apr/27 00:24:41 lte,async,event +CGEV: ME DETACH
apr/27 00:24:41 lte,async,event ^SIMST: 0
apr/27 00:24:41 lte,async,event +MMSG: 1, 0
apr/27 00:24:41 lte,async,event +CPIN: SIM REMOVED
apr/27 00:24:41 lte,async,event ^CARDMODE: 255
apr/27 00:24:41 lte,async,event ^SIMST: 255,0
apr/27 00:24:42 lte,async,event +CREG: 0
apr/27 00:24:42 lte,info lte1: not registred, state: 0
apr/27 00:24:48 lte,async lte1: rcvd OK
apr/27 00:24:48 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:24:48 lte,async lte1: sent ATMRD_SN?
apr/27 00:24:49 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:24:49 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:24:49 lte,async lte1: sent AT+CFUN=4
apr/27 00:24:53 lte,async lte1: rcvd OK
apr/27 00:24:53 lte,async,event ^SIMST: 0
apr/27 00:24:53 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:24:53 lte,async lte1: sent AT+CPIN?
apr/27 00:24:53 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:24:53 lte,async,event +CPIN: READY
apr/27 00:24:53 lte,async,event ^SIMST: 1
apr/27 00:24:55 lte,async lte1: sent AT+CPIN?
apr/27 00:24:55 lte,async lte1: rcvd +CPIN: READY
apr/27 00:24:55 lte,async,event +MMSG: 2, 0
apr/27 00:24:56 lte,async,event +MMSG: 3, 0
apr/27 00:24:56 lte,async,event +MMSG: 0, 0
apr/27 00:24:56 lte,async,event +MPBK: 1
apr/27 00:24:59 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:24:59 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:24:59 lte,async lte1: sent AT+CFUN?
apr/27 00:24:59 lte,async lte1: rcvd +CFUN: 4
apr/27 00:24:59 lte,async lte1: sent AT+CNUM
apr/27 00:24:59 lte,async lte1: sent AT+CIMI
apr/27 00:25:00 lte,async lte1: rcvd 222070190855496
apr/27 00:25:00 lte,async lte1: sent AT+CFUN?
apr/27 00:25:00 lte,async lte1: rcvd +CFUN: 4
apr/27 00:25:00 lte,async lte1: sent AT+CNUM
apr/27 00:25:00 lte,async lte1: sent AT+CIMI
apr/27 00:25:00 lte,async lte1: sent AT+CPIN?
apr/27 00:25:00 lte,async lte1: rcvd +CPIN: READY
apr/27 00:25:00 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:25:00 lte,async lte1: rcvd OK
apr/27 00:25:01 lte,async lte1: sent AT+CFUN=1
apr/27 00:25:01 lte,async,event +CREG: 2
apr/27 00:25:01 lte,async,event +CGREG: 2
apr/27 00:25:01 lte,async lte1: rcvd OK
apr/27 00:25:01 lte,debug lte1: config ok
apr/27 00:25:06 lte,async,event +CREG: 11, f046, 5e60f18, 2
apr/27 00:25:06 lte,async,event +CGREG: 11,“f046”,“05e60f18”,6,0
apr/27 00:25:07 lte,async,event +CGREG: 5,“f046”,“05e60f18”,6,0
apr/27 00:25:07 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:25:07 lte,info lte1: registered, roaming
apr/27 00:25:08 lte,async,event +CREG: 5, f046, 5e60f18, 2
apr/27 00:25:09 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:25:09 lte,async lte1: rcvd OK
apr/27 00:25:09 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:25:10 lte,async,event +CREG: 5, f046, 5e60f18, 6
apr/27 00:25:11 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:25:11 lte,async lte1: sent AT+CFUN=0
apr/27 00:25:11 lte,async lte1: rcvd OK
apr/27 00:25:12 lte,async,event +CREG: 5
apr/27 00:25:12 lte,info lte1: registered, roaming
apr/27 00:25:12 lte,async,event +CGREG: 0
apr/27 00:25:12 lte,async,event +CGEV: ME DETACH
apr/27 00:25:12 lte,async,event ^SIMST: 0
apr/27 00:25:12 lte,async,event +MMSG: 1, 0
apr/27 00:25:12 lte,async,event +CPIN: SIM REMOVED
apr/27 00:25:12 lte,async,event ^CARDMODE: 255
apr/27 00:25:12 lte,async,event ^SIMST: 255,0
apr/27 00:25:13 lte,async,event +CREG: 0
apr/27 00:25:13 lte,info lte1: not registred, state: 0
apr/27 00:25:19 lte,async lte1: rcvd OK
apr/27 00:25:19 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:25:19 lte,async lte1: sent ATMRD_SN?
apr/27 00:25:19 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:25:19 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:25:19 lte,async lte1: sent AT+CFUN=4
apr/27 00:25:23 lte,async,event ^SIMST: 0
apr/27 00:25:23 lte,async lte1: rcvd OK
apr/27 00:25:23 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:25:23 lte,async lte1: sent AT+CPIN?
apr/27 00:25:23 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:25:24 lte,async,event +CPIN: READY
apr/27 00:25:24 lte,async,event ^SIMST: 1
apr/27 00:25:25 lte,async lte1: sent AT+CPIN?
apr/27 00:25:25 lte,async lte1: rcvd +CPIN: READY
apr/27 00:25:25 lte,async,event +MMSG: 2, 0
apr/27 00:25:26 lte,async,event +MMSG: 3, 0
apr/27 00:25:26 lte,async,event +MMSG: 0, 0
apr/27 00:25:26 lte,async,event +MPBK: 1
apr/27 00:25:29 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:25:29 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:25:29 lte,async lte1: sent AT+CFUN?
apr/27 00:25:29 lte,async lte1: rcvd +CFUN: 4
apr/27 00:25:29 lte,async lte1: sent AT+CNUM
apr/27 00:25:29 lte,async lte1: sent AT+CIMI
apr/27 00:25:31 lte,async lte1: rcvd 222070190855496
apr/27 00:25:31 lte,async lte1: sent AT+CFUN?
apr/27 00:25:31 lte,async lte1: rcvd +CFUN: 4
apr/27 00:25:31 lte,async lte1: sent AT+CNUM
apr/27 00:25:31 lte,async lte1: sent AT+CIMI
apr/27 00:25:31 lte,async lte1: sent AT+CPIN?
apr/27 00:25:31 lte,async lte1: rcvd +CPIN: READY
apr/27 00:25:31 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:25:31 lte,async lte1: rcvd OK
apr/27 00:25:32 lte,async lte1: sent AT+CFUN=1
apr/27 00:25:32 lte,async,event +CREG: 2
apr/27 00:25:32 lte,async,event +CGREG: 2
apr/27 00:25:32 lte,async lte1: rcvd OK
apr/27 00:25:32 lte,debug lte1: config ok
apr/27 00:25:36 lte,async,event +CREG: 11, f046, 5e6072e, 2
apr/27 00:25:36 lte,async,event +CGREG: 11,“f046”,“05e6072e”,6,0
apr/27 00:25:37 lte,async,event +CGREG: 5,“f046”,“05e6072e”,6,0
apr/27 00:25:37 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:25:37 lte,info lte1: registered, roaming
apr/27 00:25:38 lte,async,event +CREG: 5, f046, 5e6072e, 2
apr/27 00:25:39 lte,async,event +CREG: 5, f046, 5e6072e, 6
apr/27 00:25:39 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:25:39 lte,async lte1: rcvd OK
apr/27 00:25:39 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:25:41 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:25:41 lte,async lte1: sent AT+CFUN=0
apr/27 00:25:41 lte,async lte1: rcvd OK
apr/27 00:25:41 lte,async,event +CREG: 5
apr/27 00:25:41 lte,info lte1: registered, roaming
apr/27 00:25:41 lte,async,event +CGREG: 0
apr/27 00:25:41 lte,async,event +CGEV: ME DETACH
apr/27 00:25:41 lte,async,event ^SIMST: 0
apr/27 00:25:41 lte,async,event +MMSG: 1, 0
apr/27 00:25:41 lte,async,event +CPIN: SIM REMOVED
apr/27 00:25:41 lte,async,event ^CARDMODE: 255
apr/27 00:25:41 lte,async,event ^SIMST: 255,0
apr/27 00:25:42 lte,async,event +CREG: 0
apr/27 00:25:42 lte,info lte1: not registred, state: 0
apr/27 00:25:48 lte,async lte1: rcvd +CSQ: 99,99
apr/27 00:25:48 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:25:48 lte,async lte1: rcvd OK
apr/27 00:25:48 lte,async lte1: sent ATMRD_SN?
apr/27 00:25:49 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:25:49 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:25:49 lte,async lte1: sent AT+CFUN=4
apr/27 00:25:53 lte,async lte1: rcvd OK
apr/27 00:25:53 lte,async,event ^SIMST: 0
apr/27 00:25:53 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:25:53 lte,async lte1: sent AT+CPIN?
apr/27 00:25:53 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:25:55 lte,async,event +CPIN: READY
apr/27 00:25:55 lte,async,event ^SIMST: 1
apr/27 00:25:55 lte,async lte1: sent AT+CPIN?
apr/27 00:25:56 lte,async lte1: rcvd +CPIN: READY
apr/27 00:25:56 lte,async,event +MMSG: 2, 0
apr/27 00:25:57 lte,async,event +MMSG: 3, 0
apr/27 00:25:57 lte,async,event +MMSG: 0, 0
apr/27 00:25:57 lte,async,event +MPBK: 1
apr/27 00:26:00 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:26:00 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:26:00 lte,async lte1: sent AT+CFUN?
apr/27 00:26:00 lte,async lte1: rcvd +CFUN: 4
apr/27 00:26:00 lte,async lte1: sent AT+CNUM
apr/27 00:26:00 lte,async lte1: sent AT+CIMI
apr/27 00:26:01 lte,async lte1: rcvd 222070190855496
apr/27 00:26:01 lte,async lte1: sent AT+CPIN?
apr/27 00:26:01 lte,async lte1: rcvd +CPIN: READY
apr/27 00:26:01 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:26:01 lte,async lte1: rcvd OK
apr/27 00:26:02 lte,async lte1: sent AT+CFUN=1
apr/27 00:26:02 lte,async,event +CREG: 2
apr/27 00:26:02 lte,async,event +CGREG: 2
apr/27 00:26:02 lte,async lte1: rcvd OK
apr/27 00:26:02 lte,debug lte1: config ok
apr/27 00:26:08 lte,async,event +CREG: 11, f046, 5e60f18, 2
apr/27 00:26:08 lte,async,event +CGREG: 11,“f046”,“05e60f18”,6,0
apr/27 00:26:09 lte,async,event +CGREG: 5,“f046”,“05e60f18”,6,0
apr/27 00:26:09 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:26:09 lte,info lte1: registered, roaming
apr/27 00:26:10 lte,async,event +CREG: 5, f046, 5e60f18, 2
apr/27 00:26:11 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:26:11 lte,async lte1: rcvd OK
apr/27 00:26:11 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:26:21 lte,async,event +CREG: 5, f046, 5e6072e, 2
apr/27 00:26:21 lte,async,event +CGREG: 5,“f046”,“05e6072e”,6,0
apr/27 00:26:21 lte,async,event +CREG: 5, f046, 5e6072e, 6
apr/27 00:26:22 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:26:22 lte,async lte1: sent AT+CFUN=0
apr/27 00:26:22 lte,async lte1: rcvd OK
apr/27 00:26:22 lte,async,event +CREG: 5
apr/27 00:26:22 lte,info lte1: registered, roaming
apr/27 00:26:22 lte,async,event +CGREG: 0
apr/27 00:26:22 lte,async,event +CGEV: ME DETACH
apr/27 00:26:22 lte,async,event ^SIMST: 0
apr/27 00:26:22 lte,async,event +MMSG: 1, 0
apr/27 00:26:22 lte,async,event +CPIN: SIM REMOVED
apr/27 00:26:22 lte,async,event ^CARDMODE: 255
apr/27 00:26:22 lte,async,event ^SIMST: 255,0
apr/27 00:26:23 lte,async,event +CREG: 0
apr/27 00:26:23 lte,info lte1: not registred, state: 0
apr/27 00:26:29 lte,async lte1: rcvd +CSQ: 99,99
apr/27 00:26:29 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:26:29 lte,async lte1: rcvd OK
apr/27 00:26:29 lte,async lte1: sent ATMRD_SN?
apr/27 00:26:30 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:26:30 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:26:30 lte,async lte1: sent AT+CFUN=4
apr/27 00:26:34 lte,async,event ^SIMST: 0
apr/27 00:26:34 lte,async lte1: rcvd OK
apr/27 00:26:34 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:26:34 lte,async lte1: sent AT+CPIN?
apr/27 00:26:34 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:26:36 lte,async,event +CPIN: READY
apr/27 00:26:36 lte,async,event ^SIMST: 1
apr/27 00:26:36 lte,async lte1: sent AT+CPIN?
apr/27 00:26:37 lte,async lte1: rcvd +CPIN: READY
apr/27 00:26:37 lte,async,event +MMSG: 2, 0
apr/27 00:26:38 lte,async,event +MMSG: 3, 0
apr/27 00:26:38 lte,async,event +MMSG: 0, 0
apr/27 00:26:38 lte,async,event +MPBK: 1
apr/27 00:26:41 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:26:41 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:26:41 lte,async lte1: sent AT+CFUN?
apr/27 00:26:41 lte,async lte1: rcvd +CFUN: 4
apr/27 00:26:41 lte,async lte1: sent AT+CNUM
apr/27 00:26:41 lte,async lte1: sent AT+CIMI
apr/27 00:26:42 lte,async lte1: rcvd 222070190855496
apr/27 00:26:42 lte,async lte1: sent AT+CPIN?
apr/27 00:26:42 lte,async lte1: rcvd +CPIN: READY
apr/27 00:26:42 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:26:42 lte,async lte1: rcvd OK
apr/27 00:26:43 lte,async lte1: sent AT+CFUN=1
apr/27 00:26:43 lte,async,event +CREG: 2
apr/27 00:26:43 lte,async,event +CGREG: 2
apr/27 00:26:43 lte,async lte1: rcvd OK
apr/27 00:26:43 lte,debug lte1: config ok
apr/27 00:26:49 lte,async,event +CREG: 11, f046, 5e60f18, 2
apr/27 00:26:49 lte,async,event +CGREG: 11,“f046”,“05e60f18”,6,0
apr/27 00:26:50 lte,async,event +CGREG: 5,“f046”,“05e60f18”,6,0
apr/27 00:26:50 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:26:50 lte,info lte1: registered, roaming
apr/27 00:26:50 lte,async,event +CREG: 5, f046, 5e60f18, 2
apr/27 00:26:52 lte,async,event +CREG: 5, f046, 5e60f18, 6
apr/27 00:26:52 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:26:52 lte,async lte1: rcvd OK
apr/27 00:26:52 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:26:53 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:26:53 lte,async lte1: sent AT+CFUN=0
apr/27 00:26:54 lte,async,event +CREG: 5
apr/27 00:26:54 lte,info lte1: registered, roaming
apr/27 00:26:54 lte,async,event +CGREG: 0
apr/27 00:26:54 lte,async,event +CGEV: ME DETACH
apr/27 00:26:54 lte,async,event ^SIMST: 0
apr/27 00:26:54 lte,async,event +MMSG: 1, 0
apr/27 00:26:54 lte,async,event +CPIN: SIM REMOVED
apr/27 00:26:54 lte,async,event ^CARDMODE: 255
apr/27 00:26:54 lte,async,event ^SIMST: 255,0
apr/27 00:26:55 lte,async,event +CREG: 0
apr/27 00:26:55 lte,info lte1: not registred, state: 0
apr/27 00:27:01 lte,async lte1: rcvd OK
apr/27 00:27:01 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:27:01 lte,async lte1: sent ATMRD_SN?
apr/27 00:27:01 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:27:01 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:27:01 lte,async lte1: sent AT+CFUN=4
apr/27 00:27:06 lte,async lte1: rcvd OK
apr/27 00:27:06 lte,async,event ^SIMST: 0
apr/27 00:27:06 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:27:06 lte,async lte1: sent AT+CPIN?
apr/27 00:27:06 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:27:07 lte,async,event +CPIN: READY
apr/27 00:27:07 lte,async,event ^SIMST: 1
apr/27 00:27:08 lte,async lte1: sent AT+CPIN?
apr/27 00:27:09 lte,async lte1: rcvd +CPIN: READY
apr/27 00:27:09 lte,async,event +MMSG: 2, 0
apr/27 00:27:09 lte,async,event +MMSG: 3, 0
apr/27 00:27:09 lte,async,event +MMSG: 0, 0
apr/27 00:27:10 lte,async,event +MPBK: 1
apr/27 00:27:13 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:27:13 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:27:13 lte,async lte1: sent AT+CFUN?
apr/27 00:27:13 lte,async lte1: rcvd +CFUN: 4
apr/27 00:27:13 lte,async lte1: sent AT+CNUM
apr/27 00:27:13 lte,async lte1: sent AT+CIMI
apr/27 00:27:14 lte,async lte1: rcvd 222070190855496
apr/27 00:27:14 lte,async lte1: sent AT+CPIN?
apr/27 00:27:14 lte,async lte1: rcvd +CPIN: READY
apr/27 00:27:14 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:27:14 lte,async lte1: rcvd OK
apr/27 00:27:15 lte,async lte1: sent AT+CFUN=1
apr/27 00:27:15 lte,async,event +CREG: 2
apr/27 00:27:15 lte,async,event +CGREG: 2
apr/27 00:27:15 lte,async lte1: rcvd OK
apr/27 00:27:15 lte,debug lte1: config ok
apr/27 00:27:20 lte,async,event +CREG: 11, f046, 5e60f18, 2
apr/27 00:27:20 lte,async,event +CGREG: 11,“f046”,“05e60f18”,6,0
apr/27 00:27:22 lte,async,event +CGREG: 5,“f046”,“05e60f18”,6,0
apr/27 00:27:22 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:27:22 lte,info lte1: registered, roaming
apr/27 00:27:22 lte,async,event +CREG: 5, f046, 5e60f18, 2
apr/27 00:27:24 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:27:24 lte,async lte1: rcvd OK
apr/27 00:27:24 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:27:32 lte,async,event +CREG: 5, f046, 5e646e2, 2
apr/27 00:27:32 lte,async,event +CGREG: 5,“f046”,“05e646e2”,6,0
apr/27 00:27:32 lte,async,event +CREG: 5, f046, 5e646e2, 6
apr/27 00:27:33 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:27:33 lte,async lte1: sent AT+CFUN=0
apr/27 00:27:33 lte,async,event +CREG: 5
apr/27 00:27:33 lte,info lte1: registered, roaming
apr/27 00:27:33 lte,async,event +CGREG: 0
apr/27 00:27:33 lte,async,event +CGEV: ME DETACH
apr/27 00:27:33 lte,async,event ^SIMST: 0
apr/27 00:27:33 lte,async,event +MMSG: 1, 0
apr/27 00:27:33 lte,async,event +CPIN: SIM REMOVED
apr/27 00:27:33 lte,async,event ^CARDMODE: 255
apr/27 00:27:33 lte,async,event ^SIMST: 255,0
apr/27 00:27:34 lte,async,event +CREG: 0
apr/27 00:27:34 lte,info lte1: not registred, state: 0
apr/27 00:27:39 lte,async lte1: rcvd OK
apr/27 00:27:39 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:27:39 lte,async lte1: sent ATMRD_SN?
apr/27 00:27:40 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:27:40 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:27:40 lte,async lte1: sent AT+CFUN=4
apr/27 00:27:44 lte,async lte1: rcvd OK
apr/27 00:27:44 lte,async,event ^SIMST: 0
apr/27 00:27:44 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:27:44 lte,async lte1: sent AT+CPIN?
apr/27 00:27:44 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:27:46 lte,async,event +CPIN: READY
apr/27 00:27:46 lte,async,event ^SIMST: 1
apr/27 00:27:46 lte,async lte1: sent AT+CPIN?
apr/27 00:27:47 lte,async lte1: rcvd +CPIN: READY
apr/27 00:27:48 lte,async,event +MMSG: 2, 0
apr/27 00:27:48 lte,async,event +MMSG: 3, 0
apr/27 00:27:48 lte,async,event +MMSG: 0, 0
apr/27 00:27:48 lte,async,event +MPBK: 1
apr/27 00:27:51 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:27:51 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:27:51 lte,async lte1: sent AT+CFUN?
apr/27 00:27:51 lte,async lte1: rcvd +CFUN: 4
apr/27 00:27:51 lte,async lte1: sent AT+CNUM
apr/27 00:27:51 lte,async lte1: sent AT+CIMI
apr/27 00:27:53 lte,async lte1: rcvd 222070190855496
apr/27 00:27:53 lte,async lte1: sent AT+CPIN?
apr/27 00:27:53 lte,async lte1: rcvd +CPIN: READY
apr/27 00:27:53 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:27:53 lte,async lte1: rcvd OK
apr/27 00:27:54 lte,async lte1: sent AT+CFUN=1
apr/27 00:27:54 lte,async,event +CREG: 2
apr/27 00:27:54 lte,async,event +CGREG: 2
apr/27 00:27:54 lte,async lte1: rcvd OK
apr/27 00:27:54 lte,debug lte1: config ok
apr/27 00:28:01 lte,async,event +CREG: 11, f046, 5e60f18, 2
apr/27 00:28:01 lte,async,event +CGREG: 11,“f046”,“05e60f18”,6,0
apr/27 00:28:02 lte,async,event +CGREG: 5,“f046”,“05e60f18”,6,0
apr/27 00:28:02 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:28:02 lte,info lte1: registered, roaming
apr/27 00:28:02 lte,async,event +CREG: 5, f046, 5e60f18, 2
apr/27 00:28:04 lte,async,event +CREG: 5, f046, 5e60f18, 6
apr/27 00:28:04 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:28:04 lte,async lte1: rcvd OK
apr/27 00:28:04 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:28:05 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:28:05 lte,async lte1: sent AT+CFUN=0
apr/27 00:28:06 lte,async,event +CREG: 5
apr/27 00:28:06 lte,info lte1: registered, roaming
apr/27 00:28:06 lte,async,event +CGREG: 0
apr/27 00:28:06 lte,async,event +CGEV: ME DETACH
apr/27 00:28:06 lte,async,event ^SIMST: 0
apr/27 00:28:06 lte,async,event +MMSG: 1, 0
apr/27 00:28:06 lte,async,event +CPIN: SIM REMOVED
apr/27 00:28:06 lte,async,event ^CARDMODE: 255
apr/27 00:28:06 lte,async,event ^SIMST: 255,0
apr/27 00:28:07 lte,async,event +CREG: 0
apr/27 00:28:07 lte,info lte1: not registred, state: 0
apr/27 00:28:13 lte,async lte1: rcvd OK
apr/27 00:28:13 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:28:13 lte,async lte1: sent ATMRD_SN?
apr/27 00:28:13 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:28:13 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:28:13 lte,async lte1: sent AT+CFUN=4
apr/27 00:28:18 lte,async lte1: rcvd OK
apr/27 00:28:18 lte,async,event ^SIMST: 0
apr/27 00:28:18 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:28:18 lte,async lte1: sent AT+CPIN?
apr/27 00:28:18 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:28:19 lte,async,event +CPIN: READY
apr/27 00:28:19 lte,async,event ^SIMST: 1
apr/27 00:28:20 lte,async lte1: sent AT+CPIN?
apr/27 00:28:21 lte,async lte1: rcvd +CPIN: READY
apr/27 00:28:21 lte,async,event +MMSG: 2, 0
apr/27 00:28:21 lte,async,event +MMSG: 3, 0
apr/27 00:28:21 lte,async,event +MMSG: 0, 0
apr/27 00:28:22 lte,async,event +MPBK: 1
apr/27 00:28:25 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:28:25 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:28:25 lte,async lte1: sent AT+CFUN?
apr/27 00:28:25 lte,async lte1: rcvd +CFUN: 4
apr/27 00:28:25 lte,async lte1: sent AT+CNUM
apr/27 00:28:25 lte,async lte1: sent AT+CIMI
apr/27 00:28:26 lte,async lte1: rcvd 222070190855496
apr/27 00:28:26 lte,async lte1: sent AT+CPIN?
apr/27 00:28:26 lte,async lte1: rcvd +CPIN: READY
apr/27 00:28:26 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:28:26 lte,async lte1: rcvd OK
apr/27 00:28:27 lte,async lte1: sent AT+CFUN=1
apr/27 00:28:27 lte,async,event +CREG: 2
apr/27 00:28:27 lte,async,event +CGREG: 2
apr/27 00:28:27 lte,async lte1: rcvd OK
apr/27 00:28:27 lte,debug lte1: config ok
apr/27 00:28:33 lte,async,event +CREG: 11, f046, 5e646e2, 2
apr/27 00:28:33 lte,async,event +CGREG: 11,“f046”,“05e646e2”,6,0
apr/27 00:28:34 lte,async,event +CGREG: 5,“f046”,“05e646e2”,6,0
apr/27 00:28:34 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:28:34 lte,info lte1: registered, roaming
apr/27 00:28:34 lte,async,event +CREG: 5, f046, 5e646e2, 2
apr/27 00:28:35 lte,async,event +CREG: 5, f046, 5e646e2, 6
apr/27 00:28:36 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:28:36 lte,async lte1: rcvd OK
apr/27 00:28:36 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:28:37 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:28:37 lte,async lte1: sent AT+CFUN=0
apr/27 00:28:38 lte,async,event +CREG: 5
apr/27 00:28:38 lte,info lte1: registered, roaming
apr/27 00:28:38 lte,async,event +CGREG: 0
apr/27 00:28:38 lte,async,event +CGEV: ME DETACH
apr/27 00:28:38 lte,async,event ^SIMST: 0
apr/27 00:28:38 lte,async,event +MMSG: 1, 0
apr/27 00:28:38 lte,async,event +CPIN: SIM REMOVED
apr/27 00:28:38 lte,async,event ^CARDMODE: 255
apr/27 00:28:38 lte,async,event ^SIMST: 255,0
apr/27 00:28:39 lte,async,event +CREG: 0
apr/27 00:28:39 lte,info lte1: not registred, state: 0
apr/27 00:28:45 lte,async lte1: rcvd OK
apr/27 00:28:45 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:28:45 lte,async lte1: sent ATMRD_SN?
apr/27 00:28:45 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:28:45 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:28:45 lte,async lte1: sent AT+CFUN=4
apr/27 00:28:49 lte,async lte1: rcvd OK
apr/27 00:28:49 lte,async,event ^SIMST: 0
apr/27 00:28:49 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:28:49 lte,async lte1: sent AT+CPIN?
apr/27 00:28:49 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:28:50 lte,async,event +CPIN: READY
apr/27 00:28:50 lte,async,event ^SIMST: 1
apr/27 00:28:51 lte,async lte1: sent AT+CPIN?
apr/27 00:28:51 lte,async lte1: rcvd +CPIN: READY
apr/27 00:28:51 lte,async,event +MMSG: 2, 0
apr/27 00:28:52 lte,async,event +MMSG: 3, 0
apr/27 00:28:52 lte,async,event +MMSG: 0, 0
apr/27 00:28:52 lte,async,event +MPBK: 1
apr/27 00:28:55 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:28:55 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:28:55 lte,async lte1: sent AT+CFUN?
apr/27 00:28:55 lte,async lte1: rcvd +CFUN: 4
apr/27 00:28:55 lte,async lte1: sent AT+CNUM
apr/27 00:28:55 lte,async lte1: sent AT+CIMI
apr/27 00:28:55 lte,async lte1: sent AT+CPIN?
apr/27 00:28:57 lte,async lte1: rcvd +CPIN: READY
apr/27 00:28:57 lte,async lte1: sent AT+CFUN?
apr/27 00:28:57 lte,async lte1: rcvd +CFUN: 4
apr/27 00:28:57 lte,async lte1: sent AT+CNUM
apr/27 00:28:57 lte,async lte1: sent AT+CIMI
apr/27 00:28:58 lte,async lte1: rcvd 222070190855496
apr/27 00:28:58 lte,async lte1: sent AT+CPIN?
apr/27 00:28:58 lte,async lte1: rcvd +CPIN: READY
apr/27 00:28:58 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:28:58 lte,async lte1: rcvd OK
apr/27 00:28:59 lte,async lte1: sent AT+CFUN=1
apr/27 00:28:59 lte,async,event +CREG: 2
apr/27 00:28:59 lte,async,event +CGREG: 2
apr/27 00:28:59 lte,async lte1: rcvd OK
apr/27 00:28:59 lte,debug lte1: config ok
apr/27 00:29:03 lte,async,event +CREG: 11, f046, 5e6072e, 2
apr/27 00:29:03 lte,async,event +CGREG: 11,“f046”,“05e6072e”,6,0
apr/27 00:29:05 lte,async,event +CGREG: 5,“f046”,“05e6072e”,6,0
apr/27 00:29:05 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:29:05 lte,info lte1: registered, roaming
apr/27 00:29:05 lte,async,event +CREG: 5, f046, 5e6072e, 2
apr/27 00:29:06 lte,async,event +CREG: 5, f046, 5e6072e, 6
apr/27 00:29:07 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:29:07 lte,async lte1: rcvd OK
apr/27 00:29:07 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:29:08 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:29:08 lte,async lte1: sent AT+CFUN=0
apr/27 00:29:08 lte,async,event +CREG: 5
apr/27 00:29:08 lte,info lte1: registered, roaming
apr/27 00:29:08 lte,async,event +CGREG: 0
apr/27 00:29:08 lte,async,event +CGEV: ME DETACH
apr/27 00:29:08 lte,async,event ^SIMST: 0
apr/27 00:29:08 lte,async,event +MMSG: 1, 0
apr/27 00:29:08 lte,async,event +CPIN: SIM REMOVED
apr/27 00:29:08 lte,async,event ^CARDMODE: 255
apr/27 00:29:08 lte,async,event ^SIMST: 255,0
apr/27 00:29:09 lte,async,event +CREG: 0
apr/27 00:29:09 lte,info lte1: not registred, state: 0
apr/27 00:29:15 lte,async lte1: rcvd OK
apr/27 00:29:15 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:29:15 lte,async lte1: sent ATMRD_SN?
apr/27 00:29:16 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:29:16 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:29:16 lte,async lte1: sent AT+CFUN=4
apr/27 00:29:20 lte,async lte1: rcvd OK
apr/27 00:29:20 lte,async,event ^SIMST: 0
apr/27 00:29:20 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:29:20 lte,async lte1: sent AT+CPIN?
apr/27 00:29:20 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:29:22 lte,async,event +CPIN: READY
apr/27 00:29:22 lte,async,event ^SIMST: 1
apr/27 00:29:22 lte,async lte1: sent AT+CPIN?
apr/27 00:29:23 lte,async lte1: rcvd +CPIN: READY
apr/27 00:29:24 lte,async,event +MMSG: 2, 0
apr/27 00:29:24 lte,async,event +MMSG: 3, 0
apr/27 00:29:24 lte,async,event +MMSG: 0, 0
apr/27 00:29:24 lte,async,event +MPBK: 1
apr/27 00:29:27 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:29:27 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:29:27 lte,async lte1: sent AT+CFUN?
apr/27 00:29:27 lte,async lte1: rcvd +CFUN: 4
apr/27 00:29:27 lte,async lte1: sent AT+CNUM
apr/27 00:29:27 lte,async lte1: sent AT+CIMI
apr/27 00:29:27 lte,async lte1: sent AT+CPIN?
apr/27 00:29:29 lte,async lte1: rcvd +CPIN: READY
apr/27 00:29:29 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:29:29 lte,async lte1: rcvd OK
apr/27 00:29:30 lte,async lte1: sent AT+CFUN=1
apr/27 00:29:30 lte,async,event +CREG: 2
apr/27 00:29:30 lte,async,event +CGREG: 2
apr/27 00:29:30 lte,async lte1: rcvd OK
apr/27 00:29:30 lte,debug lte1: config ok
apr/27 00:29:34 lte,async,event +CREG: 11, f046, 5e6072e, 2
apr/27 00:29:34 lte,async,event +CGREG: 11,“f046”,“05e6072e”,6,0
apr/27 00:29:36 lte,async,event +CGREG: 5,“f046”,“05e6072e”,6,0
apr/27 00:29:36 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:29:36 lte,info lte1: registered, roaming
apr/27 00:29:36 lte,async,event +CREG: 5, f046, 5e6072e, 2
apr/27 00:29:37 lte,async,event +CREG: 5, f046, 5e6072e, 6
apr/27 00:29:38 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:29:38 lte,async lte1: rcvd OK
apr/27 00:29:38 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:29:39 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:29:39 lte,async lte1: sent AT+CFUN=0
apr/27 00:29:39 lte,async,event +CREG: 5
apr/27 00:29:39 lte,info lte1: registered, roaming
apr/27 00:29:39 lte,async,event +CGREG: 0
apr/27 00:29:39 lte,async,event +CGEV: ME DETACH
apr/27 00:29:39 lte,async,event ^SIMST: 0
apr/27 00:29:39 lte,async,event +MMSG: 1, 0
apr/27 00:29:39 lte,async,event +CPIN: SIM REMOVED
apr/27 00:29:39 lte,async,event ^CARDMODE: 255
apr/27 00:29:39 lte,async,event ^SIMST: 255,0
apr/27 00:29:40 lte,async,event +CREG: 0
apr/27 00:29:40 lte,info lte1: not registred, state: 0
apr/27 00:29:46 lte,async lte1: rcvd OK
apr/27 00:29:46 lte,async lte1: sent AT+EEMOPT=1
apr/27 00:29:46 lte,async lte1: sent ATMRD_SN?
apr/27 00:29:47 lte,async lte1: rcvd MRD_SN:723C036E81D6
apr/27 00:29:47 lte,debug lte serial: MRD_SN:723C036E81D6
apr/27 00:29:47 lte,async lte1: sent AT+CFUN=4
apr/27 00:29:51 lte,async lte1: rcvd OK
apr/27 00:29:51 lte,async,event ^SIMST: 0
apr/27 00:29:51 lte,async lte1: sent ATCGDFLT=0,“IP”,“m2mlab.it”,1,0,1
apr/27 00:29:51 lte,async lte1: sent AT+CPIN?
apr/27 00:29:51 lte,async lte1: rcvd +CME ERROR: 14
apr/27 00:29:53 lte,async,event +CPIN: READY
apr/27 00:29:53 lte,async,event ^SIMST: 1
apr/27 00:29:53 lte,async lte1: sent AT+CPIN?
apr/27 00:29:54 lte,async lte1: rcvd +CPIN: READY
apr/27 00:29:55 lte,async,event +MMSG: 2, 0
apr/27 00:29:55 lte,async,event +MMSG: 3, 0
apr/27 00:29:55 lte,async,event +MMSG: 0, 0
apr/27 00:29:55 lte,async,event +MPBK: 1
apr/27 00:29:58 lte,async lte1: sent AT+CPMS=“SM”,“SM”,“SM”
apr/27 00:29:58 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,0
apr/27 00:29:58 lte,async lte1: sent AT+CFUN?
apr/27 00:29:58 lte,async lte1: rcvd +CFUN: 4
apr/27 00:29:58 lte,async lte1: sent AT+CNUM
apr/27 00:29:58 lte,async lte1: sent AT+CIMI
apr/27 00:30:00 lte,async lte1: rcvd 222070190855496
apr/27 00:30:00 lte,async lte1: sent AT+CPIN?
apr/27 00:30:00 lte,async lte1: rcvd +CPIN: READY
apr/27 00:30:00 lte,async lte1: sent ATBAND=1,79,147,480,589829,1,2,0
apr/27 00:30:00 lte,async lte1: rcvd OK
apr/27 00:30:01 lte,async lte1: sent AT+CFUN=1
apr/27 00:30:01 lte,async,event +CREG: 2
apr/27 00:30:01 lte,async,event +CGREG: 2
apr/27 00:30:01 lte,async lte1: rcvd OK
apr/27 00:30:01 lte,debug lte1: config ok
apr/27 00:30:07 lte,async,event +CREG: 11, f046, 5e646e2, 2
apr/27 00:30:07 lte,async,event +CGREG: 11,“f046”,“05e646e2”,6,0
apr/27 00:30:08 lte,async,event +CREG: 5, f046, 5e646e2, 2
apr/27 00:30:08 lte,info lte1: registered, roaming
apr/27 00:30:08 lte,async,event +CGREG: 0
apr/27 00:30:08 lte,async,event +CGREG: 5,“f046”,“05e646e2”,6,0
apr/27 00:30:08 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
apr/27 00:30:10 lte,async,event +CREG: 5, f046, 5e646e2, 6
apr/27 00:30:10 lte,async lte1: sent AT+CGDCONT=5,“IP”,“m2mlab.it”
apr/27 00:30:10 lte,async lte1: rcvd OK
apr/27 00:30:10 lte,async lte1: sent AT+CGDATA=“”,5
apr/27 00:30:12 lte,async lte1: rcvd +CME ERROR: 100
apr/27 00:30:12 lte,async lte1: sent AT+CFUN=0
apr/27 00:30:12 lte,async,event +CREG: 5
apr/27 00:30:12 lte,info lte1: registered, roaming
apr/27 00:30:12 lte,async,event +CGREG: 0
apr/27 00:30:12 lte,async,event +CGEV: ME DETACH
apr/27 00:30:12 lte,async,event ^SIMST: 0
apr/27 00:30:12 lte,async,event +MMSG: 1, 0
apr/27 00:30:12 lte,async,event +CPIN: SIM REMOVED
apr/27 00:30:12 lte,async,event ^CARDMODE: 255
apr/27 00:30:12 lte,async,event ^SIMST: 255,0
apr/27 00:30:13 lte,async,event +CREG: 0
apr/27 00:30:13 lte,info lte1: not registred, state: 0
[admin@MikroTik] /log>
thanks
senzatempo
I wait patient the new os and firmware that patch this bug, but after 5 months whit last 6.42.1 not work again.is possible fix the bug ?
if you need a test sim I can send itI want use this mikrotik device , but need lte whit authentication , please resolve this bug
Bug is solved in newer wAPs because they come out with LTE firmware v8, you have v1.
Ask support@mikrotik.com the guide to upgrade wAP’s LTE firmware, and always upgrade wAPs to last stable version.
My lte does not register
0:59:52 echo: lte,async,raw lte1: sent AT+CSQ
00:59:52 echo: lte,async,raw lte1: rcvd +CSQ: 99,99
[admin@MikroTik] >
00:59:55 echo: lte,async,raw lte1: sent AT+EEMGINFO?
00:59:55 echo: lte,async,raw lte1: rcvd OK
00:59:55 echo: lte,async,raw lte1: sent AT+CSQ
00:59:55 echo: lte,async,raw lte1: rcvd +CSQ: 99,99
[admin@MikroTik] >
00:59:58 echo: lte,async,raw lte1: sent AT+EEMGINFO?
00:59:58 echo: lte,async,raw lte1: rcvd OK
00:59:58 echo: lte,async,raw lte1: sent AT+CSQ
00:59:58 echo: lte,async,raw lte1: rcvd +CSQ: 99,99
[admin@MikroTik] >
01:00:01 echo: lte,async,raw lte1: sent AT+EEMGINFO?
01:00:01 echo: lte,async,raw lte1: rcvd OK
01:00:01 echo: lte,async,raw lte1: sent AT+CSQ
01:00:01 echo: lte,async,raw lte1: rcvd +CSQ: 99,99
[admin@MikroTik] >
01:00:04 echo: lte,async,raw lte1: sent AT+EEMGINFO?
01:00:04 echo: lte,async,raw lte1: rcvd OK
01:00:04 echo: lte,async,raw lte1: sent AT+CSQ
[admin@MikroTik] >
01:00:04 echo: lte,async,raw lte1: rcvd +CSQ: 99,99
[admin@MikroTik] >
01:00:06 echo: lte,async,event +CREG: 3, 81e6, 32b1209, 7
01:00:06 echo: lte,async,event +CEREG: 3,“81e6”,“032b1209”,7
[admin@MikroTik] >
01:00:07 echo: lte,async,raw lte1: sent AT+EEMGINFO?
01:00:07 echo: lte,async,raw lte1: rcvd OK
01:00:07 echo: lte,async,raw lte1: sent AT+CSQ
01:00:07 echo: lte,async,raw lte1: rcvd +CSQ: 99,99
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
Have you updated wAP to last stable?
You’re referring to this? https://wiki.mikrotik.com/wiki/Manual:Interface/LTE#Modem_firmware_upgrade_for_R11e-LTE_.28INT.29_modems
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >Have you updated wAP to last stable?
Update needs LTE registered?
