I recently purchased a MikroTik wAP LTE kit and tried to use a Verizon SIM chip in it. The chip works in my phone but when I transfer it to the device, I can’t seem to get it to work. I’m not sure how to troubleshoot the LTE connection. Does anyone have a guide on how to set this up and/or troubleshoot it?
I’ve watched some videos on the topic and I noticed that the LTE interface had check boxes in the “Bands” section but mine doesn’t provide me any options there - when I click the drop down list, nothing actually appears. Do I need to put anything in the settings to get Verizon to recognize the device?
Did you put an apn in?
Also do you know what band you need for verizon?
If you have the us version of wap lte you cant manually select bands.
Sent from my LG-Q710AL using Tapatalk
Where does one get the APN?
If you do a quick google search youll find out.
Thank you. I did a little bit of digging and it looks like Verizon has some different versions of it and I’m not 100% sure of formatting but I’ll tinker with it later this week and try to figure it out. The little SIM card adapter decided to run off on me so I had to order another one.
Got it - I used vzwinternet. Thanks!
