Will the wap lte kit support sms because the sxt lre doesn’t!!!
When will it be available for purchase in Brazil? Maybe until Christmas 2018?
I need him for a project for 15,000 buses.
Ask your distributor, because they are already available. Or try another distributor.
Normis will it support sms?
Because I just bought an SXT LTE to use to send SMSes but it is not working.
Also are you planning to support SMS in the SXT LTE?
are you sure that your 4g provider support sms via 4g? most of operators doesn’t (4g is for traffic and video calls). sxt lte, wap lte (version with modem) have only 4g modem (not 3g + 4g)
according to mikrotik website:
The wAP LTE is a small weatherproof wireless access point with a built in cellular modem that supports 2G, 3G and 4G (LTE) connectivity
there are 2 models ( actually 3, the third is for US)
wAP LTE kit - with lte modem and wAP lte R - with out modem. try to find more information about modem in wap lte kit - if it doesn’t support 3g or 2g (also not every modem support sms) you can buy wap R and mini-PCI lte modem with sms support and with suport of 2-3G
So finally does anyone know if the wap LTE kit with the onboard modem supports SMS?
Pre-order only. Prevision: 2018.
wAP LTE kit supports sms, send and receive:
Could someone help me with setup WAP LTE kit to recevie or send SMS?
Look at the screenshot above, have you tried these steps?
Describe what is not working for you and what you expected instead.
Review documentation here: https://wiki.mikrotik.com/wiki/Manual:Tools/Sms
On Winbox port is not visible. On cli how can I read sms on inbox?
