wAP LTE kit temperature
Hello!
What is the normal temperature for a wAP LTE kit ?
Installed in a room, constant temperature not lower than 46С (ambient temperature is 24C).
It is correct?
I not know what is the normal temperature of wAP, but 46°C is not dangerous.
Regards.
Thanks for replay!
Yes 46 is not dangerous, but i want use our monitoring system for check mikrotik state.
What dangerous temp for mikrotik?
With 60 or more it have some problem. Change thermal paste and check heatsink if it happen.
Regards.
