WAP LTE KIT
Can anyone help me with information about WAP LTE kit information/setup? If i configure it in routed mode, i get ip /32 ( 10.0.0.1 ) and its OK. But if i configure it as passthrough and set DHCP client on HEX it does get same IP but with /30 subnet mask and default route to .2. I have another sim in same private APN ( in second WAP LTE) which holds 10.0.0.2 ( in routed mode).
When both devices are in routed mode i can ping from side to side but in any other scenario i can not ( any of WAP’s in passthrough mode).
Have you tried the latest release candidate RouterOS? *) lte - use “/32” address for the Passthrough feature when R11e-LTE module is used;
That was solution. I was on stable branch. THX!
