Hello Guys,
I’m a fresh MikroTik user, so maybe my question is dumb
I’ve installed RBwAPR-2nD&R11e-LTE with 6.47.7 SW release and SIM card for LTE.
I haven’t configured routerboard with advanced settings. I’ve just used a quick set (AP LTE) profile. SIM card is registered in 2G/3G/4G network (LTE Band 7 15MHz).
Every time I “ask” for www address (contacting with GSM operator DNS and resolving a name) I’ve got a few seconds communication break. I checked with simple tool - ping to GSM operator DNS. And every time I asked for www address, I’ve got a same story - few second break and then reconnect and success.
Same time I pinged a router in local network. There weren’t connection breaks.
I haven’t found anything strange in logs.
Did anyone of you found same problem? What to do with it? Maybe some boxes have to be checked in advanced configuration.
Hi Guys,
after many tries I think I resolved a problem.
Internal antennas are piece of sh… Without external panel / yagi antennas (or one with MIMO) WAP LTE doesn’t work. WAP LTE is installed on a wall with line of sight to BTS. Distance between WAP LTE and BTS is about 400 meters. Internal antennas aren’t omni . They look like two 120-180 degrees sectors combined together by modem. It is possible when I installed WAP LTE in front of BTS, there was a problem with propagation, because BTS was in a “dead zone”.
my WAP LTE has a problem with B7 15MHz. I don’t know why. Maybe a problem is in sector.
