# dec/19/2019 14:25:52 by RouterOS 6.45.7
# software id = 0YVW-DUP3
# model = RouterBOARD wAP R-2nD
# serial number = 86C409549322
add comment="Externe Gast User" name=bridge-extern
add admin-mac=B8:69:F4:11:79:2C auto-mac=no comment="Interne Verteilung" name=\
bridge-intern
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=drei.at authentication=pap default-route-distance=1 name=Planet3
add apn=webaut default-route-distance=1 name="HoT Internet"
/interface lte
set [ find ] apn-profiles=Planet3 mac-address=AC:FF:FF:00:00:00 name=lte1
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed \
mode=dynamic-keys name=porfile-intern supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
comment=2,4GHz disabled=no disconnect-timeout=5s frequency=auto mode=\
ap-bridge multicast-buffering=disabled multicast-helper=disabled name=\
wlan-Intern radio-name="LTE Router" security-profile=porfile-intern ssid=\
LKintern tx-power=19 tx-power-mode=all-rates-fixed wmm-support=required \
wps-mode=disabled
/interface wireless nstreme
set wlan-Intern comment=2,4GHz
/interface wireless manual-tx-power-table
/interface wireless
add default-ap-tx-limit=56000 default-client-tx-limit=56000 disabled=no \
keepalive-frames=disabled mac-address=BA:69:F4:11:79:2D master-interface=\
wlan-Intern multicast-buffering=disabled multicast-helper=disabled name=\
wlan-Gast ssid="Loskrochn Gast" wds-cost-range=0 wds-default-cost=0 \
wps-mode=disabled
/ip hotspot profile
add name=pool-intern ranges=192.168.0.1-192.168.3.254
add name=pool-extern ranges=192.169.0.1-192.169.2.250
add name=pool_PPTP ranges=192.168.3.241-192.168.3.250
add name=dhcp_pool4 ranges=192.168.0.2-192.168.3.254
add address-pool=pool-extern disabled=no interface=bridge-extern name=\
dhcp-extern
add address-pool=pool-intern disabled=no interface=bridge-intern name=\
dhcp-intern
/ppp profile
add change-tcp-mss=yes dns-server=192.168.0.1 local-address=192.168.0.1 name=\
PPTP remote-address=pool_PPTP use-encryption=yes
set *FFFFFFFE dns-server=192.168.0.1 local-address=192.168.0.1 remote-address=\
192.168.0.100
add bridge=bridge-intern comment=defconf interface=ether1
add bridge=bridge-intern comment=defconf interface=wlan-Intern
add bridge=bridge-extern interface=wlan-Gast
add bridge=bridge-intern disabled=yes interface=wlan-Intern
add bridge=bridge-intern disabled=yes interface=WAN
/interface detect-internet
set detect-interface-list=all
add interface=lte1 list=WAN
add interface=ether1 list=LAN
add interface=bridge-extern list=LAN
add interface=bridge-intern list=LAN
add interface=wlan-Gast list=LAN
add interface=wlan-Intern list=LAN
/interface pptp-server server
set default-profile=PPTP enabled=yes
add address=192.168.88.1/24 comment=defconf disabled=yes interface=\
bridge-intern network=192.168.88.0
add address=192.168.0.1/16 interface=bridge-intern network=192.168.0.0
add address=192.169.0.1/16 interface=bridge-extern network=192.169.0.0
add address=192.168.0.1/16 disabled=yes interface=ether1 network=192.168.0.0
add address=192.168.10.1/16 disabled=yes interface=wlan-Gast network=\
192.168.0.0
add address=192.168.0.1/16 disabled=yes interface=wlan-Intern network=\
192.168.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-server lease
add address=192.168.0.95 comment=Kasse mac-address=50:9A:4C:3C:0C:65
add address=192.168.0.90 comment="EC " mac-address=54:7F:54:C8:28:92
add address=192.168.0.200 client-id=1:b8:27:eb:fd:2f:86 comment=\
Haftungsausschluss mac-address=B8:27:EB:FD:2F:86
add address=192.168.3.200 client-id=1:0:f:0:53:34:56 comment=Terminal1 \
mac-address=00:0F:00:53:34:56
add address=192.168.2.201 client-id=1:0:f:0:4f:ce:e9 comment="Terminal 2" \
mac-address=00:0F:00:4F:CE:E9
add address=192.168.2.202 client-id=1:a0:88:b4:9f:c9:c8 comment="Terminal Lapi" \
mac-address=A0:88:B4:9F:C9:C8
add address=192.168.0.3 client-id=1:24:18:1d:d9:d:a2 mac-address=\
24:18:1D:D9:0D:A2
add address=192.168.0.10 client-id=1:40:9f:38:45:42:85 comment=Lasertag \
mac-address=40:9F:38:45:42:85
add address=192.168.0.150 comment=CAM mac-address=00:11:14:15:55:D9
add address=192.168.0.2 client-id=1:74:4d:28:fa:47:3d comment=Switch \
mac-address=74:4D:28:FA:47:3D
add address=192.168.0.0/16 dns-server=192.168.0.1,8.8.8.8,8.8.4.4 gateway=\
192.168.0.1 netmask=16
add address=192.169.0.0/16 dns-server=192.169.0.1,8.8.8.8,8.8.4.4 gateway=\
192.169.0.1 netmask=16
set allow-remote-requests=yes cache-max-ttl=2d servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 comment=defconf disabled=yes name=router.lan
/ip firewall address-list
add address=192.168.0.151-192.168.3.250 list="Block Internet"
add address=192.168.10.1-192.168.15.250 list="Block Local"
add action=accept chain=forward disabled=yes dst-address=192.168.0.150 \
dst-port=8080 protocol=tcp
dst-port=8080 protocol=udp
established,related,untracked disabled=yes log-prefix=rolle3
invalid disabled=yes log=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes log=\
yes log-prefix=icmp protocol=icmp
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=\
127.0.0.1 log=yes
disabled=yes in-interface-list=!LAN
add action=reject chain=forward comment="Block Local" disabled=yes \
in-interface=bridge-intern log=yes log-prefix=block out-interface=\
bridge-intern reject-with=icmp-network-unreachable src-address-list=\
"Block Local"
add action=drop chain=forward comment="Block Internet" disabled=yes log=yes \
log-prefix="Block Internet" src-address-list="Block Internet"
disabled=yes ipsec-policy=in,ipsec
disabled=yes ipsec-policy=out,ipsec
connection-state=established,related disabled=yes log-prefix=rolle12
established,related,untracked disabled=yes log-prefix=rolle13
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new disabled=yes \
in-interface-list=WAN
/ip firewall mangle
add action=change-ttl chain=postrouting comment=\
"Maske f\EF\BF\BDr Subnetze zu Drei" disabled=yes new-ttl=set:65 \
out-interface=lte1 passthrough=yes
add action=dst-nat chain=dstnat disabled=yes dst-port=8080 in-interface=\
bridge-intern protocol=tcp to-addresses=192.168.0.150 to-ports=8080
bridge-intern protocol=udp to-addresses=192.168.0.150 to-ports=8080
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
/ppp secret
add disabled=yes name=michi profile=PPTP service=pptp
add name=gaigg.alexander profile=PPTP service=pptp
/system clock
set time-zone-name=Europe/Vienna
/system logging
add action=disk disabled=yes prefix=LTE topics=lte
/system ntp client
set enabled=yes server-dns-names=at.pool.ntp.org
/system scheduler
add disabled=yes interval=1d name=Restart on-event="/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=nov/16/2019 start-time=02:00:00
/tool mac-server
/tool mac-server mac-winbox
/tool sms
set allowed-number="" port=lte1 receive-enabled=yes
Hello again,
i have done all changes but the dhcp-intern wont work, in winbox it is red :-/
now i create a second virtual WLAN like wlan-intern and put them in the bridge intern it works
but why?
new code
# dec/19/2019 19:41:06 by RouterOS 6.45.7
add admin-mac=B8:69:F4:11:79:2C auto-mac=no comment="Interne Verteilung" name=bridge-intern
/interface lte apn
/interface lte
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=porfile-intern supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX comment=2,4GHz disabled=no disconnect-timeout=5s frequency=auto hide-ssid=yes mode=\
ap-bridge multicast-buffering=disabled multicast-helper=disabled name=wlan radio-name="LTE Router" security-profile=porfile-intern ssid=LKintern1 \
tx-power=19 tx-power-mode=all-rates-fixed wmm-support=required wps-mode=disabled
add default-ap-tx-limit=56000 default-client-tx-limit=56000 disabled=no keepalive-frames=disabled mac-address=BA:69:F4:11:79:2D master-interface=wlan \
multicast-buffering=disabled multicast-helper=disabled name=wlan-Gast ssid="Loskrochn Gast" wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=BA:69:F4:11:79:2E master-interface=wlan multicast-buffering=disabled name=wlan-intern security-profile=\
porfile-intern ssid=LKintern wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
set wlan comment=2,4GHz
/ip hotspot profile
add address-pool=pool-extern disabled=no interface=bridge-extern name=dhcp-extern
add address-pool=pool-intern disabled=no interface=bridge-intern name=dhcp-intern
/ppp profile
add change-tcp-mss=yes dns-server=192.168.0.1 local-address=192.168.0.1 name=PPTP remote-address=pool_PPTP use-encryption=yes
set *FFFFFFFE dns-server=192.168.0.1 local-address=192.168.0.1 remote-address=192.168.0.100
add bridge=bridge-intern comment=defconf disabled=yes interface=wlan
add bridge=bridge-intern interface=wlan-intern
add interface=wlan list=LAN
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge-intern network=192.168.88.0
add address=192.168.10.1/16 disabled=yes interface=wlan-Gast network=192.168.0.0
add address=192.168.0.1/16 disabled=yes interface=wlan network=192.168.0.0
/ip cloud
add address=192.168.0.200 client-id=1:b8:27:eb:fd:2f:86 comment=Haftungsausschluss mac-address=B8:27:EB:FD:2F:86
add address=192.168.3.200 client-id=1:0:f:0:53:34:56 comment=Terminal1 mac-address=00:0F:00:53:34:56
add address=192.168.2.201 client-id=1:0:f:0:4f:ce:e9 comment="Terminal 2" mac-address=00:0F:00:4F:CE:E9
add address=192.168.2.202 client-id=1:a0:88:b4:9f:c9:c8 comment="Terminal Lapi" mac-address=A0:88:B4:9F:C9:C8
add address=192.168.0.3 client-id=1:24:18:1d:d9:d:a2 mac-address=24:18:1D:D9:0D:A2
add address=192.168.0.10 client-id=1:40:9f:38:45:42:85 comment=Lasertag mac-address=40:9F:38:45:42:85
add address=192.168.0.2 client-id=1:74:4d:28:fa:47:3d comment=Switch mac-address=74:4D:28:FA:47:3D
add address=192.168.0.0/16 dns-server=192.168.0.1,8.8.8.8,8.8.4.4 gateway=192.168.0.1 netmask=16
add address=192.169.0.0/16 dns-server=192.169.0.1,8.8.8.8,8.8.4.4 gateway=192.169.0.1 netmask=16
/ip dns static
add action=accept chain=input connection-state=established,related
add action=accept chain=input in-interface-list=LAN
add action=log chain=input disabled=yes
add action=drop chain=input
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward disabled=yes dst-address=192.168.0.150 dst-port=8080 protocol=tcp
add action=accept chain=forward disabled=yes dst-address=192.168.0.150 dst-port=8080 protocol=udp
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked disabled=yes log-prefix=\
rolle3
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes log=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes log=yes log-prefix=icmp protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=127.0.0.1 log=yes
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=reject chain=forward comment="Block Local" disabled=yes in-interface=bridge-intern log=yes log-prefix=block out-interface=bridge-intern \
reject-with=icmp-network-unreachable src-address-list="Block Local"
add action=drop chain=forward comment="Block Internet" disabled=yes log=yes log-prefix="Block Internet" src-address-list="Block Internet"
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes log-prefix=rolle12
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked disabled=yes \
log-prefix=rolle13
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes log=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes \
/ip firewall mangle
add action=change-ttl chain=postrouting comment="Maske f\EF\BF\BDr Subnetze zu Drei" disabled=yes new-ttl=set:65 out-interface=lte1 passthrough=yes
add action=dst-nat chain=dstnat disabled=yes dst-port=8080 in-interface=bridge-intern protocol=tcp to-addresses=192.168.0.150 to-ports=8080
add action=dst-nat chain=dstnat disabled=yes dst-port=8080 in-interface=bridge-intern protocol=udp to-addresses=192.168.0.150 to-ports=8080
/ppp secret
/system clock
/system logging
/system ntp client
/system scheduler
add disabled=yes interval=1d name=Restart on-event="/system reboot" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=\
/tool mac-server
/tool sms
[gaigg.alexander@MikroTik] >
