wAP LTE6 Internal Antenna replacements
I have a wAP LTE6 that I was using with external antenna. I removed the internal ones when I fitted the pig tails and I can’t find them. I would like to re-install some. Is it possible to purchase them from anywhere? I can’t find anything on the MK website or generally searching.
TIA
I used this on mine
https://www.amazon.com/SING-LTD-Female-Pigtail-Antenna/dp/B07Y6926KN/
Just draw 2 holes on the sides to install the sma pigtails
And used 2 of these
https://www.amazon.com/600-3980Mhz-Directional-Connector-Wireless-Extender/dp/B0BG6PLX2L/
Just a word of caution … I choose SMA pigtails (the external part of the pigtail)
So you just match SMA antennas, there is RP-SMA also, so if you choose RP-SMA just make sure that the antenna and pigtails match.
Otherwise you will not be able to attach the antennas.
