wAP R + Huawei me909s-120
Hello to all
I buy wAP R and Huawei me909s-120 miniPCI LTE card for 4G connection.
MT see it like LTE, I have connection to internet, lte is running, lte1 is set as dhcp client, masqurade is done on lte1, dinamic ip is given from my ISP. Some traffic exist on lte1 interface.
LAN and WLAN are connected to bridge, no firewall rule.
ROS is 6.41.2 firmware 6.41.2 (latest). LTE packet are installed on ROS.
But, if I connect laptop to Lan port of MT i don’t have internet.
Also I can’t ping anything: ex 8.8.8.8 www.yaho.com. I try with google DNS and my ISP DNS, same problem. LTE is default route.
Does any moden init commands must bi input ? What can bee the problem ?
I just input Huawei Card, turn on router, update ros and that is it, input APN setting from my ISP and everything start to work on lte.
Also MT don’t see any port of LTE card.
Help please
SOLVED
SIM was defected… :frowning: Work only on 3G. On LTE Huawei give 50Mb/download 20Mb/s upload. More then I need.
Can someone tell me if I change this LTE Huawei Card for MikroTik R11e-LTE, can I have info about LTE interface (signal, Tehnology…) over SNMP ?
With Huawei card I can’t see this over SNMP only over Winbox or terminal. Is ther way to se it over SNMP, and if yes which LTE card to use ?
Thank you
Mine is working perfect’y with both lte cards
How su extract LTE info over SNMP ?
