In the manual is written.
“wAP only: Power jack (5.5mm outside and 2mm inside diameter, female, pin positive plug) supports 12-57 V
powering, the device comes with a 24 V 0.8 A power adapter.”
Received wAP’s RBwAP2nD came with 24 V 0.38a power adapters.
Will be used with PoE injector and approximately 30m ethernet cable.
Will the wAP’s work well???
