wAP to capsman without cables
how can i setup wAP to connect to CAPSMAN trough wifi?
I have tried to set up wAP in station, station pseudobridge, station bridge. Nothing has worked.
could you tell what setup you want to make?
You want to make wAP as CAP to the CAPsMAN and connect it to the CAPsMAN via wifi?
If, yes then it is not possible as the wifi interface can’t be used as regular wireless interface and also participate in the CAPsMAN - you need to choose only one of the option.
Yes, that is exactly what i need to achieve.
