can someone tell me if an LHG60ad can connect to a wap60 from ~500m distance?
i have aesthetical limitations for mounting anything on the fasade and the wap is the only device i could fit nicely, and the client would be 500m away, i can put lhg there.
would that work OK?
right now there’s a ptp 2ghz link that works well but is not enough bandwidth. 5ghz is too crowded, 2ghz i mounted because i thought i have no LOS, but i have it, it’s tight but i have about 4-5m hole between 2 buildings so i have clear LOS.
thanks.
i suppose this distances are during normal clean weather with no fog or rain?
in that case, this probably won’t work for me, or i must use backup.
