WAP60G-AP can only see 1 of 3 WAP60G Stations. Please help!
Hi All,
So we have a topology as shown in the following diagram:
The firmware we are running is 6.43.7. We have configured the AP in AP mode, and the connecting devices in station-bridge mode. We are running a flat /24 10.10.10.0 network for addressing of all the devices. For some unknown reason we are only seeing one station talking to the AP, which we have full IP connectivity to. The others simply refuse to connect. We DO sometimes see one of the other two stations pop up in a WinBox scan as 0.0.0.0, but have not been able to get this station to connect properly. When checking this device by connecting locally to it, the IP is set, etc so not sure why we are seeing 0.0.0.0. The third device is simply not seen at all. We are well within tolerances for physical alignment, there is no obstructions, and clear LOS. They are at most 80m from the AP. When checking the interfaces panel, we see the following:
As seen, WLAN60-Station-2 is the link that’s working, passing traffic as we would expect. WLAN60-Station-3 is the 0.0.0.0 address we are seeing in WinBox, and WLAN60-Station-4 is well…dead.
Would appreciate any guidance here as we have been banging our heads against a wall trying to get these to work.
Cheers!
L3 not L4 license, and no WAP60G-AP
