We have 4 of these devices in a mast and originally worked pretty fine.
But lately we have many cuts.
We worked through several ROS versions but now at least cannot go back before 6.42.7 since we need the 4 frequencies.
On bright sunny days the connected devices (2 wAP60G + 1 LHG60G) see hardly cuts.
During heavy rain only the weakest link cuts at times.
But during mild to soft rain we have both wAP60G dropping links a lot. Sometimes every minute. And the signals are all over the place. 30 to 70. MCS also between 1 and 7
The only unit that is doing best under all circumstances the LHG60G but that has a consistent 80 signal with MCS8
But it seems when one of the wAP60G’s goes offline or both it drags the LHG60G also off line.
We tried rc version to no avail
We run 6.43.2 now to no avail. This one worked always fine. Not anymore. But we have drizzle. But even in dry periods they disconnect…
We have a LHG60G link running to same mast (that doesn’t ‘see’) the other 4 wAP60G’s as AP) with 6.43.4 rock solid for days…
Yes could be. But we’ve separated them at least 1,5 meter and they are also pointing in 4 different direction and use 4 different frequencies.
The mast is hit by two more 60Ghz links. One LHG60G link and one Metrolinq link. But these are at least 2 meters away, and frequencies are carefully chosen not to be the same as the sectors pointing in the same direction. And they are highly directional.
A scan only ‘sees’ a neighbouring antena but in a complete different frequency.
We’ve seen setups on photos where they were really back to back or side by side and work…
We also never had these issues with the first ROS versions. But since we needed the extra frequencies and the higher reach we are in some units thrown back in time…
