wap60g behaving weird
The setup went smoothly and everything worked fine until the other day. I have the master on the outside of the house and the slave on the outside of the stable about 50m away. It’s not the best conditions with a few trees in the way and a pavillions metal frame but it worked and it worked really good. Now, I get notifications from my cameras in the stable but I can’t reach them. I have other stuff in the stable that can’t access internet. I have rebooted everything from my router in the house to all equipment in the stable. About every 20th try I can access a camera and get image for about 2-3 seconds then i freezes again.
I’m going to test moving the master to a better location but it was working, what happened? How can I investigate this further?
What frequency are the radios using? If you’re using 58320, use something (anything) else.
I have the best luck on 64800 and 62640, but 60480 should also work.
Didn’t even know you could change it? I’ve just plugged them in and everything worked.
