wApR and LTE (AT&T sim specifically) DENIED
We have been using AT&T sims for a while (over a year) though lately “SOME” of the wapRs does not REGISTER to AT&T when modem attempts to connect.
Tried “BEC” brand device with sims(yes 3 different ones with 3 different IPv4’s) that would not REGISTER to AT&T and they all register on BEC device but not on Tik WAPR (Rile-LTE-US)
Model: RBwAPR-2ND&R11e-LTE-US
Tried some older firmwares/ROS’s nothing seems to be consistent. The sim either Registers on AT&T or it doesn’t when in the WAPR.
Registers EVERYTIME on BEC device so SIMs are all good.
Thought IMEI tied to IP might be a problem when AT&T issues IP that’s what led to several SIMS being tried. Still once a sim is DENIED on AT&T when inserted into the WAPR it does not seem to want to REGISTER ever. Though this other brand “BEC” it boots right up and REGISTERS within 2-3 minutes of boot up. (everytime)
The strange thing is that the WAPR’s are not ALL having trouble, only some. I thought I had it solved with 6.40.9 ROS but not yet Again the APN number is set correctly for AT&T for the modem to use.
WapR’s are being setup as PASS-THROUGH to provide wireless backup so the IP needs to be received through the device on the edge(CPE device) In most cases an IAD(Adrtran).
I have taken the IAD out of the mix and hooked up a 2011 to the LTE direct and allowed it to dhcp-client via LTE. You can see the modem hit the AT&T nettwork attempt to connect (SEARCHING)
Then after a few minutes you get “DENIED”
Here is a sample output of one that “WORKED” fine
MT-WAP-R-ATT] /interface lte> info 0
pin-status: ok
registration-status: registered
functionality: full
manufacturer: MikroTik
model: R11e-LTE-US
revision: MPSS: R11eL_v16.02.183961 APSS: R11eL_v05.03.183961
CUSTAPP:
current-operator: AT&T
lac: 26
current-cellid: 51468553
enb-id: 201049
sector-id: 9
phy-cellid: 202
access-technology: Evolved 3G (LTE)
imei: xxxxxxxxxxxxx875
imsi: xxxxxxxxxxxxxxx831
uicc: xxxxxxxxxxxxxxx8312
earfcn: 900
rssi: -51dBm
rsrp: -90dBm
rsrq: -15dB
Trying to find out what is different about wAPR LTE now that is only “SOMETIMES” causing this issue. Like I say the example above worked out of the box. I loaded the latest stable ROS 6.48.1 and updated firmware and it just REGISTERED.
So after two weeks of factory-reset / no default config / trying other ROS versions and updating firmware to those and even downgrading firmware many many times I am asking if anyone else has any other ideas.
If the SIMs were the trouble then why do they like the other brand LTE everytime and not the Tik wAPR? And then why only SOME of them have this issue.
Better question: Might there be some other diags other than info 0 that might log connection to AT&T via modem and provide some useful input ? ( other than REGISTERED / DENIED)
Thank you for any help you can provide
We face similar problem, AT&T start be more restrictive ? like he not be before…
We use Quectel who should work out-of-box, but recentry we see that units must change imei to recovery internet, symtops are like yours, you see connection without internet.
Out detect-internet-and-fix it scripting do stuff like re-enable interfaces etc, try disable Cell Lock, try all Bands, try all APNs 2x, try reboot, try all APNs 2x , try IMEI, repeat from start.
We have sometime notification that internet is back after change APN, common should be broadband but some units detect internet at phone sic!..
Praise MikroTik for scripting feature :slight_smile:
PS. USA Quectel sell units cheaper then AliE and that way we have original products who have certification and should work.
About R11e-LTE-US, we not use it but at start point we know it’s work.
Went back and revisited this again.
Looks like this setting got it registered
/interface lte
set [ find ] name=lte1 network-mode=3g
@DENIED-WapR-LTE] /interface lte> inf 0
pin-status: ok
functionality: full
model: R11e-LTE-US
revision: MPSS: R11eL_v16.02.183961 APSS: R11eL_v05.03.183961 CUSTAPP:
lac: 20939
current-cellid: 212281596
access-technology: 3G
imei: xx-xx3462
imsi: xxx-xx6829
uicc: xxx-xx-xxx8296
rssi: -69dBm
There’s a way to change the IMEI if AT&T restricts it (and they do for a couple special plans) but since it’s a bit of a secret, I’m not sure how I can share it because there are no PMs in this forum. I sometimes have my wAP denied if it can’t find a good enough tower to connect to, so that could have been a factor as well.
I may be interested in that IMEI change.
I can use
/interface lte
and it registers to AT&T but does NOT obtain the public IP associated with the IMEI/simm.
If I use
/interface lte
set [ find ] name=lte1 network-mode=lte
It will go through it’s motions and then do “DENIED” instead of registered
If I do
/interface lte
set [ find ] name=lte1 network-mode=gsm
I get error stating that gsm is not supported (not that using GSM would be an option for voice anyway but just to try all three options)
Jalapeno and Cablenut9,
I also would be interested in instructions for modifying the IMEI. Please PM me.
You can’t send PMs on this forum.
Well I am in need of this as well. Maybe reddit ltehacks to pm?
This is official MikroTik forum.
I see some post about IMEI what was removed and I think no one write the way here.
What are you saying here?
Anyway, the way to change the LTE6’s IMEI is here: https://www.reddit.com/r/mikrotik/comments/nr22yt/changing_the_imei_on_the_mikrotik_lte6_modem_no/ The website is down but the instructions are also in the comments.
