Sorry, I was so mad that I forgot to make photos for you…
The last I remember was the loop: ‘kernel load failed’ (or something similar) >> reboot…
PS. NetInstall and restore from .backup also failed…
It stucked at another loop: kernel load >> starting services >> login screen (0,5 - 1 second) >> reboot…
At the end I had to restore from ‘export compact’ rsc backup file…
Thank you for the report.
As currently this is the only report, it would be great to get any information from somebody who had similar issues, console output will be great.
