Warning : timeout while waiting for program 20 / 24
Hi Mikrotik,
Our router RB1100AHx4 Dude Edition, with Dude enabled RoS 6.46.6, it’s been twice in last 30days this router can’t be accessed from winbox / telnet / ssh.
The service running okay, NAT routing, but DHCP Server, Dude, VPNs all are down.
In the log showing warning about this, I don’t know what is this
timeout while waiting for program 24
Is this a bug ?
im also having the same problem with the same router
ive had this problem however for the past 6 months and ive given up, we are unable to replace it as the replacements are too expensive and we require the fallover port as well :frowning:
from what ive read up in other posts and abit of googling
it seems all TCP/ICMP stuff goes tits up?
UDP however works fine? because i was able to connect to our cameras behind our router which use UDP no problem,
but anything TCP, no luck?
only way i found of fixing this was to physically restart the router as even the local console via serial lead was locked up
i think its a faulty device
Regards
Simon
