watch link status with dude
Hi, i’ve 3 mikrotik routerOS v4.x located 3 different cities for some tunnelling purpose.
each have 2 seperate dsl connections,from seperate ISP’s to have some relaibility.
system is pretty simple, one routerOS has l2tp servers running on each dsl lines, the other two have l2tp clients running on each dsl lines connected to the first one.
so basicly,
router A has 2 dsl lines, 4 active l2tp tunnels,
router B has 2 dsl lines, 2 active l2pt tunnels,
router C has 2 dsl lines, 2 active l2tp tunnels.
what i want is, to install dude, and watch all dsl and l2tp link status on a map.
ie if everything is fine, all lines are green, else broken lines are red.
is that possible ?
partial solution is also OK for me, for example only l2tp tunnels,or only dsl lines ?
Check out this solution for link description maybe you can modify it to meet your needs.
http://forum.mikrotik.com/viewtopic.php?f=8&t=37595&start=0
