Watchdog and manual disagrees
Hi there,
I’m trying to setup the watchdog to automatically generate and email a supout.rif file to me. According to the manual it should be possible to leave the send-email-from and send-smtp-server fields blank and in doing so allow it to use the settings from /tool e-mail. However this is not possible with the Winbox GUI with 6.38.5. It does not allow me to leave those fields empty.
I tried doing it through the CLI as well, and could not even clear the send-smtp-server field.
[admin@ip] /system watchdog> print
watch-address: 8.8.4.4
watchdog-timer: no
no-ping-delay: 5m
automatic-supout: no
auto-send-supout: no
send-email-to: me@you.com
send-email-from: ip@you.com
send-smtp-server: 1.2.3.4
[admin@ip] /system watchdog> set send-email-to=none
[admin@ip] /system watchdog> set send-email-from=none
[admin@ip] /system watchdog> set send-smtp-server=none
invalid value for argument send-smtp-server
Hi
You need to fill out your email settings in
/tool e-mail
set address=smtp.gmail.com from=<mail@gmail.com> password=abc1234 port=587 start-tls=yes user=mail@gmail.com
I have filled that in. I am using SMTP elsewhere.
