bump…
may/29/2005 05:33:10 router: watchdog kill dead nstreme, 00:xx:xx:xx:17:D8
may/29/2005 05:33:10 router: 00:xx:xx:xx:17:D8 disconnected
may/29/2005 05:33:11 router: unauth or missing data sender,
00:xx:xx:xx:17:D8
may/29/2005 05:33:11 router: deauth data sender, 00:xx:xx:xx:17:D8
00:xx:xx:xx:17:D8
00:xx:xx:xx:17:D8
may/29/2005 05:33:15 router: 00:xx:xx:xx:17:D8 connected
may/29/2005 05:34:00 router: watchdog kill dead nstreme, 00:xx:xx:xx:17:D8
may/29/2005 05:39:28 router: watchdog kill dead nstreme, 00:xx:xx:xx:17:D8
may/29/2005 05:39:28 router: 00:xx:xx:xx:17:D8 disconnected
may/29/2005 05:39:31 router: 00:xx:xx:xx:17:D8 connected
may/29/2005 05:45:16 router: watchdog kill dead nstreme, 00:xx:xx:xx:17:D8
may/29/2005 05:45:16 router: 00:xx:xx:xx:17:D8 disconnected
may/29/2005 05:45:19 router: 00:xx:xx:xx:17:D8 connected
may/29/2005 10:36:30 traffic logger configuration changed by admin
may/29/2005 10:37:59 router: watchdog kill dead nstreme, 00:xx:xx:xx:17:D8
may/29/2005 10:37:59 router: 00:xx:xx:xx:17:D8 disconnected
may/29/2005 10:38:01 router: 00:xx:xx:xx:17:D8 connected
interface-type=Atheros AR5212
chip-info=“mac:0x5/0x6, phy:0x41, a5:0x36, a2:0x0”
tx-power-control=yes ack-timeout-control=yes alignment-mode=yes
virtual-aps=yes noise-floor-control=yes scan-support=yes burst-support=yes
nstreme-support=yes default-periodic-calibration=disabled
/interface wireless:
0 R name=“router” mtu=1500 mac-address=00:xx:xx:xx:5D:2A arp=enabled
disable-running-check=no interface-type=Atheros AR5212
radio-name=“router” mode=ap-bridge ssid=“router”
frequency=2437 band=2.4ghz-g-turbo
scan-list=default-ism
rate-set=configured supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=3
ack-timeout=dynamic tx-power=default noise-floor-threshold=default
periodic-calibration=disabled burst-time=disabled fast-frames=yes
dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=no hide-ssid=no 802.1x-mode=none
disconnect-timeout=3s on-fail-retry-time=100ms
nstreme:
0 name=“router” enable-nstreme=yes enable-polling=yes
framer-policy=exact-size framer-limit=4000
what does this mean and how can it be solved? We tried all combinations of v2.8.26 and v2.8.22 software on AP and client and I’m getting pretty angry about this. 3km link, point to point, -60dB signal but I have many other links - shorter and longer - that do EXACTLY THE SAME. The traffic stops, radio de-associates, then associates again and everything starts working again, but this is very annoying and TOO FREQUENT. Different ATX machines, different boards, different cards, totally stable systems (they can have 80 days uptime, but this issue is not uptime dependant, currently this log is posted from system rebooted at midnight, so it took 5 hours to appear).
In order to see this in logs, you have to turn ON wireless info in /system logging facility (set wireless-info echo=yes). As you can see, I turned off periodic calibration, but it didn’t help. Other than that, I have switched off default forwarding, set maximum station count to 3 (default: 2007) and switched on fast-frames. Whats ahead of me is turning OFF polling and trying to mess up with framer policy (it was broken some versions ago, when you set dynamic, it reported exact or vice versa).
Anyone met this before? I guess no solution is available, because this thread is totally dead.
thnx, mp3turbo.
