wawoo 2.9.23 5006x has been updated
hi all guys ,
just test the new version of MT 2.9.23 those guys do somthing with the 5006 chipset i noticed biiiig really big diffrent in wirless performance and TX power i push normal card to 500MW and working perfect so far pinging become very stable i dont know why
just dont miss it guys
Hi taloot,
Very interesting , how come the TX power shoots upto 500mW, on which Radio(5006) you have been tested this performance ? I Have NMP-8602 radio with me, so far i have seen that card has poor receving sensitivity.
regards,
Kutty
hmm i must test it
hmm i wondering why the are no mention about wireless update in changelog.
after tests i see that my nmp cards are working better on 2.9.23
Taloot,
In older versions did u use Tx-Power-mode= card rates and tx power=25? The problem with older versions was that at default the MT driver used to take 17dBm tx power for NM-8602. So once you do the above in old versions the peformance is same as in 2.8.23
i know ice,
no i test all the cases card rate manul TX all rate fixed
2.9.23 is diffrent
yeah right it didnt mention that in change log
NM is working fine for us in 2.9.17. Same performance compared to SR2. Plus NMP is better in 2.3ghz bands than SR2.
Will check 2.9.23 though, but if there was a change in the drivers, MT guys would have mentioned it. No reason to hide it i suppose.
i agree 100% with you
but see is better than hear
this is what i noticed try guys and lets share i have carrs vnp-8602 and another aircord branded mini-pci its rated as 20db power now running with me @ 25db with coooool performance on 11b will provide you screen shoot with 57 client connected to senao 8602 card and they working great no problems @ all
on 2.9.19 there was problems showing up when more than 25 client connected now i disable the other card and working only on 8602 to check the maxumim stable client connected you can get
:smiley: GOOOOOODDD!!!
Can you see that breaking the balls to the guys they were going to do something with this card!!! :laughing:
This night i test and comment!
Thanks and Regards!
Alessio :wink:
Alessio , we are still waiting for your comments to make MTos the bessssssssst every one must tell about general problems and improvment
i dont know why there is no compression support for the 8602 senao?
Now the card work great, have any problems with any configs but when you fix this, the card is stable and work better than other prior versions.
I have wrote theses fixes in other Post because comments about continues reboots of the router…
The reboot is because a bad wireless config to this card…
In this card i found when i put…
DFS mode=none
Country=no_country_set
Frequency mode=manual_txpower
Preamble mode=long
TX Power Mode=default
The reboot problem disappears… if continue try another changes
I hope helps you!
Regards!
Alessio
Hey,
I read all this post.
At the end the Senao :: NMP-8602-ETSI works or not?
I want move my basestation on routerboard 532 with 4 Senao :: NMP-8602-ETSI 100mW.
I want use 3 at 2.4 GHz with 3 sector antennas.
1 For 5GHz with omni to provide connectivity to other basestations.
At this moment I have 70 clients connected.
My dubts are.
Power: has routerboard support 4 Senao :: NMP-8602-ETSI with the daugthboard?
I’m changing my ild basestation because it reboot every 3 ours, so I will wondering if ater changing the equipment the problem still.
Could you tell me your experience as base station if the 6 gen of atheros are a good choose?
Ciao
Massimo
my sagguestion as tester,
its not worth taking risk to ues senao go for the SR2 its better or SR5
very proffsional company, unless mikrotik stamp on it as approvde hardware always ues what mikrotik says
I have the cards in rb112s and rb532s and I havent had one reboot or anyother problem from them.
The only thing I dont like is that the cards dont have turbo mode or compression. Not a big deal because I dont use ether one at this time, but I may want to later and it wont be there.
taloot,
is your scenario similar to the mine?
I have metropolitan area covered by my signal. It extends for 700 m of radius. Client have the transmitter mounted on the house roof, without directive antennas, only the 2 dbm house antenna.
My customers use many connection since they use p2psoftware(emule,gnutella) is this a problem for mk?
