If you're sending RouterOS syslog to Wazuh, the logs arrive as unstructured noise by default — no decoder matches, nothing fires. I put together a decoder and ruleset to fix that.
It covers three syslog topics:
Firewall: drop detection with source IP and port extraction
DHCP: assigned lease events with IP, MAC address, and client hostname
System: login failure detection and brute force detection (5 failures from the same source in 60 seconds), interface down alerts
One limitation worth knowing: RouterOS uses "->" as the separator between source and destination in firewall logs. That character is a reserved operator in Wazuh's regex engine and can't be escaped, so destination IP can't be extracted. Source IP works fine. The setup doc explains how to configure RouterOS logging for best results.
A few issues have been fixed based on feedback from the Wazuh team:
The -> separator between source and destination in firewall logs can now be matched using \p\p with type="pcre2". This means dstip and dstport are now extracted correctly - the limitation mentioned in the original post no longer applies.
DHCP decoder: the client hostname was being overwritten by Wazuh's pre-decoding phase because hostname is a reserved field. Fixed by using extra_data2 instead.
Interface-down rule now fires reliably via if_sid chaining instead of a standalone match.
Added test-logs/test-logs.txt with anonymized sample logs for all event types, ready to paste into wazuh-logtest.
