wds brdige on RB 532A r5 [Atheros 5213] + ovislink 5460
I can’t created wds bridge between mt (working in ap-bridge mode) and ovislink 5460 (brdge mode).
I can make WDS connection only when MT is working in wds-salve mode and ovislink in wds-repeater.
my configuration:
wlan1
 0  R name="wlan1" mtu=1500 mac-address=00:0E:8E:12:13:3D arp=enabled disable-running-check=yes
      interface-type=Atheros AR5213 radio-name="000E8E12133D" mode=ap-bridge ssid="airlive" area=""
      frequency-mode=regulatory-domain country=poland antenna-gain=0 frequency=2447 band=2.4ghz-b
      scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps
      basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
      noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60
      burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=bridge1
      wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=yes update-stats-interval=disabled
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s
      on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
wds
 0     name="wds2" mtu=1500 mac-address=00:0E:8E:12:13:3D arp=enabled disable-running-check=no
       master-interface=wlan1 wds-address=00:4F:62:08:42:AD
access i connect list
 access-list print
Flags: X - disabled
 0   mac-address=00:4F:62:08:42:AD interface=wlan1 authentication=yes forwarding=yes ap-tx-limit=0
     client-tx-limit=0 private-algo=none private-key=""
 connect-list print
Flags: X - disabled
 0   interface=wlan1 connect=yes mac-address=00:4F:62:08:42:AD ssid="" min-signal-strength=-120 area-prefix=""
brdige :
 bridge print
 0  R name="bridge1" mtu=1500 arp=enabled mac-address=00:0C:42:0A:F8:18 stp=no priority=32768 ageing-time=5m
      forward-delay=15s garbage-collection-interval=5s hello-time=2s max-message-age=20s
bridge port print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE BRIDGE  PRIORITY PATH-COST
 0    ether3    bridge1 128      10
 1    wlan1     bridge1 128      10
 2    wds2      bridge1 128      10
Logs:
ovis side:
wlan0: A wireless client is deauthenticated - 00:0E:8E:12:13:3D
mt side:
wlan1: data from unknown device 00:4F:62:08:42:AD, sent deauth
Any ideas ?
