Hi. I have a fine working WDS bridge between a RB112 (10.0.1.3
) and a RB532 (10.0.1.2). All interfaces are on the same network, 10.0.1.X and the ADSL router is in the ip 10.0.1.1.
After enabling hotspot, the bridge isn´t transparent anymore. If i connect to RB112 i can access and ping RB532, but if i connect to RB532 i can´t connect and ping RB112. I have allready tryed to remove masquerading and make static routes, but still no luck.
you better reset the configuration and start manually config interfaces, ip address and hotspot on the bridge interface.
a week-two before we discussed a problem to put the hotspot on bridge interface. personally i culdnt start config like that, but you shuld read the topics, it can help you.
The solution i found was making ip binding. Since i am using hotspot, the MK on the other end couldn´t be seen, since it was not authenticated by default.
Just put all the MK ip´s binded, and the bridge will be transparent
