Hi
I have some probleme with my link, I get this message in my log
00:0C:52:2B:6D:4A@VHLink2:disconnected no beacons received
00:0C:52:2B:6D:4A@VHLink2:connected, is AP, wants WDS
on this error, I have a connection all is ok
but sometimes it have connect,but I get no traffic, if I disable my Interface and then enable
then the link is running.
My wds is dynamic.
“VHLink3 - Andresen Indu” comment=“” manual-tx-powers=“1Mbps:17,2Mbps:17,5
.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps
:17,48Mbps:17,54Mbps:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-
6:0,HT20-7:0,HT20-8:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:
0,HT40-7:0,HT40-8:0”
2 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no
antenna-gain=0 antenna-mode=ant-a area=“” arp=enabled band=5ghz
basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment=“”
compression=no country=denmark default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=
yes dfs-mode=none disable-running-check=no disabled=no
disconnect-timeout=3s frame-lifetime=0 frequency=5620 frequency-mode=
regulatory-domain hide-ssid=yes hw-retries=4 mac-address=
00:0C:42:1B:3B:99 max-station-count=2007 mode=ap-bridge mtu=1500 name=
“VHLink3 - Andresen Indu” noise-floor-threshold=default
on-fail-retry-time=100ms periodic-calibration=default
periodic-calibration-interval=60 preamble-mode=both
proprietary-extensions=post-2.9.25 radio-name=VHLink3 rate-set=default
scan-list=default security-profile=vhlink00 ssid=VHLink3
station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=
1Mbps,2Mbps,5.5Mbps,11Mbps tx-power=12 tx-power-mode=all-rates-fixed
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=
bridge1 wds-default-cost=100 wds-ignore-ssid=no wds-mode=dynamic
wmm-support=disabled
signal -52dbm
TX is about 10 - 16Mbps alle the time
Hope someone now where my problem is ![]()
