Hi, which is the best solution for transparent bridge? WDS Bridge or EoIP tunnel? I mean which is the method that require much resources to the system?
Thank You
Paolo
Thank You
Paolo
We’re seeing only 50% of available bandwidth when using EoIP so stick with WDS.
believewireless
can u be precise more pls
cause i want to do transparent bridging and in wds bridge if the link disconnects it takes a long time to reconnect again
Use WDS where possible, because it allows bridging of the 1500 byte frames without having to split them into two smaller frames the way EoIP has to.
and use WDS in to ways - first - dynamic to see which links are stable and then select stable links and create static WDS environment. then disconnects will be brought to minimum.
and EoIP is more like ethernetish solution and since wireless is not duplex it hits performance pretty bad.
