Hi all,
I have set up wds-bridge between two 5G radios and the connection works great. The problem is that behind one of the radios the upload is 6 MB while download is 22. This is only for TCP traffic. For UDP everything works normally. 24 on both directions. What could be the problem?
We’re experiencing the same problems…
Moreover, while monitoring separately tx and rx traffic between two same routers, you can get different results, depending on router from which you’re running the test…
Check the Data rates to get high Mbps
I have in A/G basic rates unchecked everything before 18 MB/s and it still is giving 5 MB/s , but under registration its showing 54 MB/s tx/rx
I didn’t notice any serious differences, when I’ve been playing with them…
Are you using wireless-legacy package?
Nope. Should I?
I am using it. Thought that might be the problem
Well, IMHO it could, because wireless-legacy kinda old package, but hey, I am using new one and problem still persists…
Do you have WDS also or do you use L3
Layer 2 using WDS
It seems that with station/ap-bridge mode the problem persists.
