WDS & Bridging - What am I doing wrong?
I’m trying to set up a bridging between a remote Linksys 54G, which is also set up only to act as a bridge. My 54G appears to be set up right. If I hook it directly into my Cisco multilayer switch the 54G bridges just fine between the wireless and ethernet. However if I put my Soekris running RouterOS. I can’t ping the gateway from the 54G. I just want RouterOS to bridge and nothing else.
Topology
MLswitch(Cisco 3550) - ethernet - MT box - WDS - antenna <----> antenna - WDS - 54G - wireless hosts
If I can just get the wireless traffic forwarded to the gateway on the switch I’ll be fine.
[admin@MikroTik] interface wireless> print
0 R name=“AP” mtu=1500 mac-address=00:02:6F:3E:20:13 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name=“00026F3E2013” mode=bridge ssid=“test-shot” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=14
frequency=2442 band=2.4ghz-b scan-list=default rate-set=configured
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=“”
basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps basic-rates-a/g=“”
max-station-count=2007 ack-timeout=dynamic tx-power-mode=manual-table
noise-floor-threshold=default periodic-calibration=default
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=static
wds-default-bridge=bridge1 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no
[admin@MikroTik] interface wireless wds> print
Flags: X - disabled, R - running, D - dynamic
0 R name=“wds1” mtu=1500 mac-address=00:02:6F:3E:20:13 arp=enabled
disable-running-check=no master-interface=AP
wds-address=00:13:10:AB:45:22
[admin@MikroTik] interface bridge> print
0 R name=“bridge1” mtu=1500 arp=enabled mac-address=00:00:24:C5:05:E0 stp=no
priority=32768 ageing-time=5m forward-delay=15s
garbage-collection-interval=4s hello-time=2s max-message-age=20s
[admin@MikroTik] ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 10.2.2.1/24 10.2.2.0 10.2.2.255 ether2
1 10.3.3.2/24 10.3.3.0 10.3.3.255 ether1
2 192.168.1.1/24 192.168.1.0 192.168.1.255 bridge1
Any help is appreciated
Mike :frowning:
Add ports in bridge.
