please i need help
i have a AP-bridge setup and wds station clients when i set default WDS bridge in AP the client just keep connect and disconnect
and i need to bridge the wds to allow access to the ether1 for clients
any solution please ,
please i need help
http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks
see the link…
i am newbie also refer to that then can linked up..
im using the same way but the client keep connect and disconnect if i put default wds in wlan
and connecting if i disable default wds but not bridging between interfaces
Once you done the setting follow the wiki…
The next is, do some setting in ..
AP (Bridge Mode):
under wlan interface..
under Nstreme tab…
Client (Wds-station Mode):
That’s what i done and tested ok.
Hope it can help you, or you also can email me at .. bt.ang@mykris.net
