my system contents:
main app:
-rb433ah ROS 5.11 (ROS 5.12 tested but not stable with wireless clients so i downgraded to 5.11 it’s stable)
-wireless card xr2
-hyperlink omni 15 db
wds: ap bridge mode (tp-link 701,tp-link 901).
signal on wds devises betwwen -59 and -68
my problem that all wds disconnect after minutes so must reboot the wds devise to reconnect.
-i tried all ROS(3.30,4.17,5.10,5.11,5.12)
-tried B only mode ,G only mode and B/G but same result.
my wireless config
set default authentication-types=“” eap-methods=passthrough group-ciphers=
aes-ccm group-key-update=5m interim-update=0s management-protection=
disabled management-protection-key=“” mode=none name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=
XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none
static-algo-1=none static-algo-2=none static-algo-3=none static-key-0=“”
static-key-1=“” static-key-2=“” static-key-3=“” static-sta-private-algo=
none static-sta-private-key=“” static-transmit-key=key-0
supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates
unicast-ciphers=aes-ccm wpa-pre-shared-key=“” wpa2-pre-shared-key=“”
/interface wireless
set 0 adaptive-noise-immunity=ap-and-client-mode allow-sharedkey=no
antenna-gain=0 antenna-mode=ant-a area=“” arp=enabled band=2ghz-onlyg
basic-rates-a/g=6Mbps basic-rates-b=1Mbps bridge-mode=enabled burst-time=
disabled channel-width=20mhz compression=no country=no_country_set
default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0
default-forwarding=no dfs-mode=none disable-running-check=no disabled=no
disconnect-timeout=15s distance=dynamic frame-lifetime=0 frequency=2427
frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no
hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=15 l2mtu=2290 mac-address=
00:15:6D:67:DC:59 max-station-count=2007 mode=ap-bridge mtu=1500 name=wlan1
noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=
default nv2-preshared-key=“” nv2-qos=default nv2-queue-count=2
nv2-security=disabled on-fail-retry-time=1s periodic-calibration=disabled
periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=
post-2.9.25 radio-name=00156D67DC59 rate-selection=legacy rate-set=
configured scan-list=default security-profile=default ssid=
“MAGIC” station-bridge-clone-mac=00:00:00:00:00:00
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps supported-rates-b=
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power=27 tx-power-mode=
card-rates update-stats-interval=disabled wds-cost-range=50-150
wds-default-bridge=bridge1 wds-default-cost=100 wds-ignore-ssid=yes
wds-mode=static wireless-protocol=any wmm-support=enabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H
T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:
17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17”
/interface wireless nstreme
set wlan1 disable-csma=yes enable-nstreme=no enable-polling=no framer-limit=
4000 framer-policy=best-fit/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
plz help me or give an advise to fix that problem.
sorry for my english,
thanks.
