hello there…
i’m having an issue where all my wds stations disconnect from main ap :S
http://img42.imageshack.us/i/wdszo.jpg/
here’s the print of the wlan
name=“wlan1” mtu=1500 mac-address=00:02:6F:54:78:CF arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=“00026F5478CF”
mode=ap-bridge ssid=“mikrotik” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2412
band=2.4ghz-onlyg scan-list=default rate-set=default supported-rates-b=1Mbps supported-rates-a/g=36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps
basic-rates-a/g=36Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=disabled
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=static wds-default-bridge=bridge1 wds-default-cost=100
wds-cost-range=50-150 wds-ignore-ssid=yes update-stats-interval=disabled default-authentication=no default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=enabled hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 hw-retries=15 frame-lifetime=0
adaptive-noise-immunity=ap-and-client-mode hw-fragmentation-threshold=disabled hw-protection-mode=rts-cts hw-protection-threshold=0
anyone see a problem in the wireless setup???
