WDS Dynamic mesh - loop
Hi !
I would like to ask you for help about our problem with WDS dynamic mesh. We are using mikrotik routers rb912g-5hpnd in electro vehicles moving in city. The system is sending short periodically UDP broadcast (60B/s) between connected nodes and UDP unicast 1kB/s.
Our problem is:
two times per day is system maybe in the loop and the network is flooded by ARP, UDP packets (~5000 p/s) from random nodes(sometimes old not connected nodes).
Ethernet is connected to vehicle ECU and WLAN is used only for mikrotik wds mesh. Firmware ver. is 6.48
Thank you !
There is our configuration:
# model = 912UAG-5HPnD
# serial number = 77C9060C8947
/interface mesh
add name=Mesh-Interface
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-Ce \
    disabled=no frequency=5220 mode=ap-bridge rx-chains=0,1 ssid=XXXXXX \
    tx-chains=0,1 wds-default-bridge=Mesh-Interface wds-mode=dynamic-mesh \
    wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=ether1 ] speed=100Mbps
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik wpa-pre-shared-key=XXXXXX \
    wpa2-pre-shared-key=XXXXXX
/interface mesh port
add interface=ether1 mesh=Mesh-Interface
add interface=wlan1 mesh=Mesh-Interface
add address=192.168.110.233/24 interface=Mesh-Interface network=192.168.110.0
