I am attempting to do something that should be simple. I have an SXT that I want to function as a WDS AP, accepting wireless clients and a WDS repeater. The WDS repeater should accept clients and repeat. All of this should be bridged.
The repeater is not repeating. It is connecting to the wireless interface, not the WDS interface.
HELP!!
Master:
# jan/02/1970 00:27:55 by RouterOS 6.1
# software id = H07S-XF0G
add l2mtu=1600 name=bridge1 protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above country="united states" \
disabled=no distance=1 ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=\
ap-bridge ssid=NewHopeUMC tx-power=10 tx-power-mode=all-rates-fixed \
wds-default-bridge=bridge1 wds-mode=dynamic wireless-protocol=802.11
set 0 name=eth1
/interface wireless nstreme
set wlan1 enable-nstreme=yes enable-polling=no framer-limit=4000 \
framer-policy=best-fit
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik wpa-pre-shared-key=new-hope-rocks \
wpa2-pre-shared-key=new-hope-rocks
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
add name=dhcp ranges=172.17.1.10-172.17.1.200
add address-pool=default-dhcp interface=eth1 name=default
add bridge=bridge1 interface=eth1
add bridge=bridge1 interface=wlan1 path-cost=50
add address=192.168.1.2/24 comment="local ip" interface=bridge1 network=\
192.168.1.0
add address=172.17.1.0/24 comment="Local DHCP" dns-server=172.17.1.1 gateway=\
172.17.1.1 netmask=24
set allow-remote-requests=yes cache-size=8192KiB max-udp-packet-size=8192 \
servers=65.24.0.169,8.8.8.8
/ip dns static
add address=192.168.88.1 name=router
set enabled=no
add chain=input comment="default configuration" disabled=yes protocol=icmp
add chain=input comment="default configuration" connection-state=established \
disabled=yes
add chain=input comment="default configuration" connection-state=related \
disabled=yes
add action=drop chain=input comment="default configuration" disabled=yes \
in-interface=wlan1
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=wlan1 to-addresses=0.0.0.0
add distance=1 gateway=192.168.1.1
/ip upnp
set allow-disable-external-interface=no enabled=yes
/system identity
set name=NewHope-SXT-AP
/tool mac-server
add interface=eth1
add interface=wlan1
/tool mac-server mac-winbox
add interface=eth1
add interface=wlan1
Repeater
# jan/02/1970 01:42:13 by RouterOS 6.1
# software id = WYGH-XAIH
add admin-mac=D4:CA:6D:6C:BB:9F auto-mac=no l2mtu=2290 name=bridge1 \
protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n country="united states" disabled=no distance=1 \
ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=station-wds scan-list=\
2400-2500 ssid=NewHopeUMC tx-power=28 tx-power-mode=all-rates-fixed \
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
/interface wireless wds
add disabled=no master-interface=wlan1 name=wds1
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=\
passthrough mode=dynamic-keys supplicant-identity=MikroTik \
wpa-pre-shared-key=new-hope-rocks wpa2-pre-shared-key=new-hope-rocks
add address-pool=default-dhcp interface=bridge1 name=default
add bridge=bridge1 interface=ether2-master-local
add bridge=bridge1 interface=ether1-gateway
add bridge=bridge1 interface=wds1 path-cost=5
add address=192.168.1.3/24 comment="default configuration" interface=bridge1 \
network=192.168.1.0
set enabled=no
add chain=forward comment="default configuration" connection-state=\
established disabled=yes
add chain=forward comment="default configuration" connection-state=related \
disabled=yes
add chain=forward comment="default configuration" connection-state=invalid \
disabled=yes
add action=masquerade chain=srcnat comment="default configuration" disabled=\
yes out-interface=ether1-gateway
/system identity
set name=NewHopeUMC-AP
/system leds
set 0 interface=wlan1
